HP Recalls Notebook Computer AC Power Cords Due to Fire Hazards
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: HP Recalls Notebook Computer AC Power Cords Due to Fire Hazards
    Thank you for this thread my brothers laptop had this chord, wasn't showing any signes of failure but good to know its now prevented
      master hoarder
      • May 2008
      • 12175
      Originally posted by goontron
      i remember seeing the name "Longwell"
      I really like Longwell cords. They always seem better built that the others.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Surveying the "cloverleaf" cords I can see now...
        I see some I-Sheng, some Longwell, a Volex, and the particular ones that I have that may be under the recall seem to be made by Linetek. I have two of them (one from my personal ultrabook, other from my work laptop). Luckily I have one I-sheng spare that I can use for my work laptop for the time being, and I'll just use the Targus brick for my personal laptop.
        I don't quite get that some of these cords are rated 2.5A and others are 7A... though they all look very similar on the outside. These Lineteks look fairly well made too, the cable itself is even stamped(instead of printed) Linetek. Maybe they aren't affected? Unsure.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          volex makes Dell cords, so i dont think it would be them.
          the linetek on this toshiba charger in my hand feels pretty nasty...
          Follow the white rabbit.
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            well, theres all she wrote. the toshiba cord burnt up.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Oh dear, what you do with your cords to wear them out so fast!?
              Muh-soggy-knee
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I've yet (knock on wood) have a power cord burn up... There are some that have weak contacts but never burn up...
                • lti
                  • May 2011
                  • 2557
                  Re: read this.
                  Toshiba and Lenovo have recalled the same cords.
                  http://www.cpsc.gov/en/Recalls/2015/Lenovo-Recalls-Computer-Power-Cords
                  http://www.recalls.gov.au/content/in...itemId/1066015
                  OTOH I did have random crap Chinese cords spew flames at the end that plugs in the charger. Cheap insulation got ripped due to regular wear and tear and the cord shorted out.
                  I've heard of that happening to the two-prong power cords that come with newer Toshiba laptops (made by H.R.Silvine-CMC). My laptop uses that cord.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    That picture is weird in the Toshiba recall notice, it's using a round cable instead of a flat cable like all the other LS-15 cords I've seen. I wonder if that's a stock photo or it's really round?
                    The Lenovo cable looks the same as the HP cables however.
                    • JF-Caps
                      • Dec 2014
                      Before I was able to get my replacement cord, my HP G60 died. I have another cord that worked with another HP laptop, so I knew it wasn't the cord on my G60.
                      • kaboom
                        "Oh, Grouchy!"
                        • Jan 2011
                        • 2507
                        Surprised there wasn't anything about the load-side cable, where it comes out of the PS.
                        All too often, many of the strands of the wires break, leaving too little ampacity for the connected load.
                        Had one from a junk dv-whatever on the dummy load a few weeks ago. Voltage dropping from 19.5 to just under 18 at rated output current.
                        Strain relief and a few inches of outgoing cable got a little warm. If I held it just right, the voltage came back up.
                        After "busting" it open, it wasn't that great inside. The heatsinks were this heavy copper "foil" material, and I wasn't sure if I broke the transformer core, so bye-bye it went.
                        Originally posted by cpsc
                        Hewlett-Packard and Compaq notebook computer AC power cords.
                        Haha. "hp" and compaq. "hp" is compaq- the same in every way, right down to how junky both are.
                        "pokemon go... to hell!"
                        EOL it...
                        All style and no substance.
                        guilty,guilty,guilty,guilty!
                        guilty of being cheap-made!
                          • 31204
                          that's build quality, not electrical safety.
                          recalls are only a legal requirement if they can cause a fire or kill someone.
                          • kaboom
                            "Oh, Grouchy!"
                            • Jan 2011
                            • 2507
                            A good one:
                            Here's a power supply where some were assembled w/ line and neutral reversed. Some of these "HAM" supplies do not return the secondary side to chassis ground- the entire secondary floats.
                            Since the supply is unfused with the wiring reversed, a ground fault to the secondary side will leave you with line voltage either sitting there, or returning via an external device with a path back to the source. But w/o a fuse to blow, what do you think will happen?
                            Those are insulated binding posts- they're not gonna clear it by returning the fault to the chassis.
                            If the output common were bonded to the chassis, even a pri-to-sec transformer short, with reversed line wiring, would not present a shock hazard. Not only does this one not bond the secondary, the output on my Manson also floats.
                            The fact that these had a serious latent hazard w/ the wiring reversed further suggests the output floats.
                            A common computer supply, with its output common bonded to the case, would just blow its fuse during a pri-to-sec fault.
                            If L&N were reversed, it would either burn the fault clear or trip the branch ckt bkr. As well as any GFCI/RCD, if present, since current leaving on the hot would not be coming back on the neutral/grounded, but the GND/grounding instead.
                            With a reasonable return impedance there's a shock hazard during a major (bolted) fault until the bkr trips. The case will go up to half the supply voltage. One half dropped across the line wire, the other half dropped across the gnd wire- this assumes there are no other parallel paths from the case of the power supply in question. These would reduce the voltage rise considerably.
                            http://www.cpsc.gov/en/Recalls/2008/...d-Fire-Hazards
                            There were also computer supplies with reversed line wiring, deers and antec stupid-powers. Now there was the fuse as the above supply, but there was also an NTC thermistor.
                            So if line wires were reversed, instead of L to fuse and N to thermistor, you'd have L to thermistor and N to fuse.
                            A major fault in one of those would blow the fuse or thermistor, the latter taking more to clear.
                            EOL it...
                              HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                              This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-07-2024, 07:12 AM
                              09-07-2024, 06:40 AM
                              HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                              This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                              09-07-2024, 05:50 AM
                              HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                              This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
