Need a New DVD Drive
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Need a New DVD Drive
    I have a NEC DVDRW, works great. later model plextors are junk, sorry Per.... I went through 3 of them in as many months, they just stop reading for whatever reason. If you want a slot loader, go with Pioneer. I have a pioneer slot DVD ROM, its 4 years old, still works great!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • shadow
      • Feb 2007
      • 732
      Originally posted by Junk Parts
      I kind of expect for products to be made by the Company that put their names on them. This is kind of like my car you know. Its says Suzuki on it and it is a 100% Japanese built Suzuki car with a Suzuki engine. Some other people have bought Chevys that are rebadged suzuki cars, or are GM built cars with a Suzuki engine in them, and paid a lot more than I did for the same crap!
      I have found Sony burners to be particularly guilty for this sort of behaviour. Sony burners almost always cost more than other burners, yet many are just rebadged units from other companies. I remember when I bought my first DVD burner (which I still have and works fairly well), I ended up buying a Lite-On burner (this was before their burners started to have problems). However for $40 more or so I could of bought a Sony burner, which was just a rebadged version of the Lite-On which I bought!
      I am not sure how Lite-On burners are now, I know they had some problems with some later models after the one I bought. However I am not sure whether these problems got rectified and if they make decent burners again.
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        Did I fix my SONY DRU-800A? I can't believe this but I think I did. I did a basic thing and checked the firmware version of my unit. It was at KYO1. Sony is up to KYO6 for this unit now. Reflashed the thing to KYO6, and I'm burning the living "Heck" out of DVD's again! No Coasters as of yet, and I've burnt three in a row. As soon as I get done here I will go for number four! It running cool too. Thanks to all for the good info and I hope this thing holds. Now I need to go write down all the drives you all said were good ones just in case the SONY craps again. As for me not checking the firmware ver first I also ran the sony drive check test and my drive came out clean and green in all areas.
        Mark Twain
        John Paul Jones
        Rod Serling
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Ok, thnx for the info, we will see how it goes
          What I want is a new slot-in drive, but I've already got a Pioneer DVD-ROM, I want a writer... A black slot in DVD writer, preferably black (else I'll have to paint it)
          It would be nice if it was SATA too, but IDE or SCSI also works
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            i had a pioneer slot in drive. lasted about 2 months what a POS.
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              I was going to do a firmware update to the other DVD drive too. I don't know who the heck made it now after that search! It looks like its an A-Open, Artec, Ultama VOM-12E48X. The update I found is a DOS mode thing to make it ver.100D. Mine should be at 100A but XP Pro says its 1008. Maybe I should look again. That 8 could be a "B." The real problem is that I'm no Pro at this crap. Just can't figure how to boot this Dos mode thing in or before XP boots! I did just get an idea! If I remove the hard drive from the boot loop wouldn't this let me run this Flash EXE right from a floppy? I'm going to try it! Sometimes I can see a "Format C:\" before I even needed it done....LOL
              Mark Twain
              John Paul Jones
              Rod Serling
              • Paul S
                • Sep 2006
                • 326
                #27
                You can make a DOS boot disk, and add your flash program to it. Sometimes, if you run the flash program in widows, it will make the floppy bootable. Weren't there any instructions with it?
                To make a DOS boot disk:
                1) Insert the floppy into the drive.
                2) Open Explorer and right click on the floppy drive icon, select "Format..."
                3) Select "Create an MS-DOS startup disk".
                4) When it is done formatting, add your program to the disk.
                5) Reboot the computer and enter the BIOS. Change the boot order so that the floppy is first.
                6) When you restart, DOS should start up. Type in the name of the program you want to run: FLASH.EXE
                You actually may be able to do it from the command line, without rebooting. Have you tried that?
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  #28
                  dont do it from anything but a clean boot disk.
                  and make double damm sure you have the right firmware so you dont brick it.
                  • shadow
                    • Feb 2007
                    • 732
                    An alternative way if you wish (I think it is a better way) is to download the "Driver Free Disk For BIOS Flashing" available here and run the application. It will prompt you to insert a floppy disk and it will format it appropriately. Then just follow from steps 4 to 6.
                    Advantages of using this method is that the bootable floppy is bare. It does not have any Windows crap or additional drivers that may load up by default with a Windows bootable floppy. This also leaves more room for your flash program and firmware file.
                    • Paul S
                      • Sep 2006
                      • 326
                      #30
                      Yes, I should have mentioned to do this at your own risk. It could turn the drive into a useless piece of junk, or as kc8adu says, a brick.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #31
                        http://www.bootdisk.com/
                        Here you can find clean bootdisks, I use drdflash.exe, it's Dr-DOS based but it's still compatible with everything else... ("Driver Free Disk For BIOS Flashing")
                        • Junk Parts
                          Court Jester
                          • Jun 2006
                          • 8953
                          I didn't get any "destructions" with the 100D Flask exe. I did find that I needed a "Loader" to run 100D in XP. I got the Artec 5.2.0.0AFlash Tool. Its neat little progie that runs in windows. All you do is pick the drive to flash, then pick the folder with the flash exe in it and the progie does the rest. Yes I almost bricked it too. My ????Vom-12E48X can't run with the 100D flash. The Flash Tool was good enough that it prompted me with this fact, and wouldn't reflash the unit unless I forced it to. Thats a good thing, and I didn't force it. Now in doing more reading on this drive I found that a few had Sony chip sets in them. The only way I can see to come up with a real ID of this drive is to open the pc and get the FCC ID# from the drive, and go from there. The drive does work with almost no probems so I think I should just leave it alone Mates. The only fault I have with it is that it can't ID some of the newer blank media but it still burns on it fine at 4x. I use the 16X Sony for the movie burning anyway. The Vom-12E48X is the reader. I did learn a few good things. I can force this PC to boot from any device in the boot loop. On the next boot it will ask me if it should boot this way again or go back to a normal boot. Maybe this will allow me to load my
                          bought, and paid for OTC copy of XP pro corp with Sp2. This PC doesn't like that copy for some reason. Right now I have to load the old ver with SP1 then add SP2. We also learned that the ???VOM-12E48X is a POS in some ways but it works. There is no such thing as "support" from Artec, Altima, whoever. I think Artec should farm out their support page to Badcaps. We could just tell everybody, "No you can't do that" then charge them money.
                          Mark Twain
                          John Paul Jones
                          Rod Serling
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            #33
                            Got that Plextor PX-810SA
                            It's really a rebranded Pioneer DVR-212, I posted some pics on cdfreaks: http://club.cdfreaks.com/showthread.php?t=224142
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              #34
                              rebranded? yuk i hope they put some fancy firmware
                              • bgavin
                                • Jan 2007
                                • 1355
                                #35
                                So far, Pioneer is giving me by far the best/longest service, and Memorex is pure merde. I've seen three Memorex drives go south... died young. Much too young.
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  #36
                                  Yea, I only have one Pioneer drive but it's really old. I think over 5 years now
                                  Still reads all discs with no problem, scratched and all...
                                  The Plextor uses it's own firmware, however it might just be that it has it's own name, I have not bothered with trying to download it and compare with the real Pioneer firmwares... Pioneer seems to release many new firmwares for the drive so it does look well supported... I would recommend you the Pioneer drive, it is half the price of the "Plextor" too
                                  • willawake
                                    Super Modulator
                                    • Nov 2003
                                    • 8457
                                    • Greece
                                    #37
                                    Plextor PX-716 bit the dust. forgot the error it was making, something like power calibration. cleaned the lens with methanol, it made one burn and then the next one same error. so i switched power supplies between computers. same shit. whatever.
                                    i was going to get another liteon LH-20A1H but got a samsung SH-S202N
                                    • acstech
                                      GrumpyModerator
                                      • Jul 2007
                                      • 1432
                                      I think you'll like the Samsung. I've always had good luck with 'em.
                                      A man convinced against his will is of the same opinion still.
                                      • willawake
                                        Super Modulator
                                        • Nov 2003
                                        • 8457
                                        • Greece
                                        #39
                                        yes i did. i have burnt quite a few dvds now, hope the longevity is good.
                                        i got the external SE-S204 as well, for service use and also to use with the hp notebook (prefer to give its internal drive an easy life and also dont like the typical low quality burns of internal notebook drives.
                                        • willawake
                                          Super Modulator
                                          • Nov 2003
                                          • 8457
                                          • Greece
                                          #40
                                          well i am not happy at all with this internal samsung. it needs a coroner
                                          • federalhouse
                                            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                            by federalhouse
                                            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                            **Background:**
                                            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                            **What I've Tried So Far:**
                                            1. I accessed
                                            08-01-2024, 07:03 PM
                                          • reformatt
                                            Intel iMacs, 3rd party SSD failures and Fusion setups
                                            by reformatt
                                            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                            12-18-2024, 10:34 PM
                                          • perfm2
                                            HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                                            by perfm2
                                            So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                                            Steps taken in my usual process.
                                            Reset security settings in the BIOS
                                            Ensure existing HD comes up into the OS
                                            Shut down the laptop and disconnected the main battery
                                            Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                                            Replace battery connector and close up the laptop
                                            Insert my USB drive with my Windows 10 image I've...
                                            03-21-2023, 08:45 PM
                                          • goodpsusearch
                                            Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
                                            by goodpsusearch
                                            Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
                                            First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
                                            05-05-2024, 02:04 PM
                                            HP EliteBook 840 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 840 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 840 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                                            09-06-2024, 08:50 AM
