rtx 3090 passes mats, wont run mods or install driver
  • davetheshrew
    • Aug 2022
    • 17
    Hi
    Got a gigabyte eagle 3090 that had a blown 12v vrm and two fuses so fixed them both, card boots.
    It passes mats mem test no problem but if I run any mods test I get black screen and no response. Same if I put it on windows, install driver, black screen, nothing.
    Any ideas? I checked all resistances and voltages and all seems good, its very confusing.
  • davetheshrew
    • Aug 2022
    • 17
    Re: rtx 3090 passes mats, wont run mods or install driver
    ok mods log is saying
    pci device dropped off the bus
    nvrm: assertion failed: 0x0000000001d957df
    bp @ <fileid:0x003a3>:1922
    starting to wonder if either the gpu is dead (even though it displays) or if when the vrm blew it caused a short somewhere under the gpu. Think a reflow might help? or full reball? or am I missing something and its not the gpu at all?
    • davetheshrew
      • Aug 2022
      • 17
      ok can someone just tell me one thing, are the vrms on a 3090 in pairs? so two per phase? Wild guess but if they are then its likely the one next to the one that blew is bad also? anyone chime in please?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        check phases with scope, it will show u if any is bad
        • Maxim Bojko
           Palit RTX 2080 Super Jetstream Mats/Mods help
          by Maxim Bojko
          I have a RTX 2080 that is broken, but interesting thing is that the card works how it should work, but when playing the card crashes, black screen fans go to 100% and nothing happens anymore. I changed thermal paste because I thought it was overheating, but no. So I checked with gpu z and here is what I had.
          After a while a dude I got friends with told me to underclock the gpu via msi afterburner. First to underclock the core speed by 200 then open the chart for the mhz and voltage and said that I should change the mhz at 0,9v to 1900mhz. Since then I doesn't crash...
          09-18-2024, 04:18 PM
        • chronic519
          Mats / mods: detected and repaired GPU fault. Cant seem to test after!
          by chronic519
          Hello.
          GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
          Found issue with a RAM block
          Replaced, green lines gone.
          Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
          Used a good card to test and same results low errors 32+.
          I am just search for some form of command to do a full test on the GPU.
          I just ran the mats command with my good GPU and passed after roughly 40 min.
          The repaired one, ran...
          05-20-2025, 07:56 PM
          NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
          The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
          10-02-2024, 08:52 AM
        • 00__Nomad__00
          About MODS & MATS
          by 00__Nomad__00
          Do MODS & MATS work with older nVidia GPUS, specifically the G71 M ?
          I've tried versions 173.48, 400, and 455, but it can't detect the GPU, even though the GPU is detected in Windows and functioning properly. I couldn't find any lists of supported GPUs.
          11-12-2023, 04:12 PM
          DELL OptiPlex 3090 OptiPlex 3000 i5-1145G7 Specification for Upgrade or Repair
          This specification for the DELL OptiPlex 3090 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3090 boardview and OptiPlex 3090 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
          09-12-2024, 03:44 PM
