Intel D945GTP VRM Cooling mod
  • c_hegge
    • Sep 2009
    • 5219
    While I have generally had pretty decent luck with C2D and newer Intel boards, some of the P4 era boards, like my D945GTP, had problems with hot-running VRMs - especially when using 125W Pentium D CPUs, like the one in this board. Standing the FETs up certanly doesn't help with this, but - it does make it kind of easy to fix.
    I found an old PSU heatsink in my stash and broke off some of the fingers. I then used some thermal epoxy to stick them to the FETs. I then used some RAM heatsinks (which came with a GPU cooler, but didn't get used) on the coils - which also get quite toasty on this board. The next step is to do something about the 12V side FETs. Those are soldered to the board, but also get hot. There are blank spaces next to them all (which are in parallel). I'm thinking that, If I can find some identical ones, I might solder a few more in parallel (and maybe stick some RAM heatsinks to them as well)
  • Majestyk
    • Nov 2013
    • 96
    Re: Intel D945GTP VRM Cooling mod
    One of the reasons why the additional cooling is necessary might be the absence of the original Intel "box-CPU-cooler". The original Intel coolers produce an airstream at their bottom reaching - and cooling - all the components around the CPU-socket while the passive cooler on the board does nothing like that.
    So the thermal design of the board relies on the Intel cooler-specifications. If the Intel-specified cooler is missing, the whole thermal management is at stake.
    • c_hegge
      • Sep 2009
      • 5219
      You'd think so, but it doesn't help that much. I've seen similar boards with cooked VRMs even when the stock cooler is used. Those Pentium D CPUs get so hot with the stock cooler that the air coming off it doesn't actually cool the VRM that much.
      • Majestyk
        • Nov 2013
        • 96
        The tremendous heat loss of those CPU is obviously the culprit.
        If this is 100W and more the fan must "cool" the VRMs with air that is 50 - 60° C hot already. So either the fan would have to spin at 10000 rpm or the vrms get boiled.
          • 31204
          but the problem is the bios by default runs the fan real slow.
          i'v got a few and you need to change the bios settings to fan-full-on all the time.
          • Majestyk
            • Nov 2013
            • 96
            That´s surprising since Intel are always aiming at the enterprise / workstation market where (long time) stability is more important than silent computing.
            I would have expected more conservative defaults here.
            They provided a rocksolid cooling for the MCH and obviously neglected the VRMs.
            And indeed - the way they soldered the MOSFETs standing up with one leg bent 90° is quite unconventional and not state of the art.
            • mockingbird
              • Dec 2008
              • 5484
              Those Fujitsu FPCAP come in both 2,000 hour and 5,000 hour versions. I still haven't found any method of differentiating between the two merely by the markings on them.
              • c_hegge
                • Sep 2009
                • 5219
                That does all contribute, but the root cause of the problem lies with the VRM itself IMO. Most other motherboards have no problems with the VRM cooking itself - regardless of the CPU used, the cooler or the fan settings.
                • Majestyk
                  • Nov 2013
                  • 96
                  Originally posted by c_hegge
                  ...the root cause of the problem lies with the VRM itself IMO. Most other motherboards have no problems with the VRM cooking itself - regardless of the CPU used, the cooler or the fan settings.
                  Everyone else has their MOSFETs soldered flat to the PCB and allows efficient cooling by the copper-layers.
                  When unsoldering the MOSFETs or even capacitors from larger copper-layers we get an idea about how efficient this cooling can be.
                  Intel has chosen a different - inferior - way here and solderd the MOSFETs upright without any cooling except for the airflow.
                  I would consider this a thermal-design fault.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    I've seen many other boards done like that - Asus and Biostar are two examples that come to mind. I agree that it is poor thermal design. But hey, they're using MOSFETs rated for operation at 175C, so it should work fine, shouldn't it? At least it made it past warranty.
                    A working TV? How boring!
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Awesome mod, c_hegge. These boards seem to last a long time with high TDP CPU's as it is. So even without adding additional FETs, those heatsinks should make a significant difference.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        The blank spaces I was referring to are on the VRM high side (see the picture). It was the low side that got the heatsinks.
                        I ended up scavenging some FETs from another dead board and replacing them, as well as adding the extra ones. I forget which parts I used but they have a slightly lower RDS-on than the originals, and they seem to run cooler.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          And as a final mod, that lone 1200uF Nichicon HD on the VRM high side got replaced by three 470uF 16V OSCON SEPC polies. Pics coming soon...
                          • TELVM
                            • Oct 2012
                            • 547
                            • Spain
                            While you're at it I'd also sink the drivers, they get even hotter than the FETs :
                            • Ace Perception
                              Samsung R530 Bremen motherboard cooling
                              by Ace Perception
                              I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
                              I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
                              So I went in pursuit of...
                              07-21-2020, 03:05 PM
                            • BleedCap
                              OLD Socket 478 custom bracket + NEW generic cooler
                              by BleedCap
                              I already posted this on vogons.
                              Its a 3d printed custom bracket for socket 478.
                              I used this AM4 bracket as a base design.
                              Its to be use with cheap generic clip based cpu cooler.
                              Reason for doing this is:
                              - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                              - New generic cooler is cheaper and can use bigger fan (less noise)
                              I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                              The processor that I was using is P4 2.4Ghz prescott....
                              11-05-2023, 08:09 PM
                            • Hondaman
                              Liquid cooling?
                              by Hondaman
                              I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
                              (After previous generation hardware [Gigabyte] didn't...
                              05-08-2025, 09:37 PM
                            • Ede2001
                              I am looking for a wiring diagram or boardview EVGA GTX 780 Ti SC w/ ACX Cooler
                              by Ede2001
                              I am looking for a boardview file or schematic for the EVGA GTX 780 Ti SC w/ ACX Cooler video card.
                              08-26-2025, 03:14 AM
                            • mikey5791
                              Help repair Panasonic fridge not cooling
                              by mikey5791
                              Hi all forum members,
                              Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                              After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                              07-16-2025, 02:01 AM
