Emachines T2042 *dead*
  • MadMasterM
    • Aug 2008
    Re: Emachines T2042 *dead*
    Thanks for all of the info. A very good friend of mine recently had his main box go down. I searched for only moments and stumbled across this thread. Replaced the power supply with one I had shelved, Ultra 350w. The board, cpu, memory all benchmark standard. Great site, I joined!!! Thanks guys for all of your help!!!
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      you really dodged a bullet!
      most of those evilmachines dont survive psu failure.
      plenty of empty cases of the deceased here to get stuffed in the next junk car body thats heading to the shredding hole.
      • Krankshaft
        • Jan 2007
        • 2328
        Originally posted by stevo1210
        Well, my uncle changed his PSU with an Antec Basiq 350W one and I guess everthing has been perfect so far. I think Antec Basiq units are FSP OEM?? I hope it has good caps so it lasts a while without blowing anything in his PC.
        I recently bought a High Quality (and very expensive) Thermaltake 430W PSU and it has Capxon and Su'scon caps in it... which makes me kinda worried about my expensive Intel D965LTCK motherboard that its powering.
        The Antec Basiq I believe uses Capxon caps. Not the best in the world but they should hold.
        It has a 3 year warranty that I don't want to void.
        That's what a blow dryer and a razor knife is for.
        Did I just say that ?
        But seriously check out your supply in this review at Hardware Secrets they open up the supplies and perform all types of tests including load test to see if they can really supply their rated power.
        It's fun to watch the videos of the Yum Cha supplies blowing up at less than half of their rated load .
        http://www.hardwaresecrets.com/article/332
        • Krankshaft
          • Jan 2007
          • 2328
          A very interesting tidbit from the Thermaltake review.
          "The conclusion is that according to our methodology Thermaltake Purepower 430 W NP isn't a 430 W power supply, but a 350 W model! We also could only pull 16 A from its +12 V output, while the label says the limit is 18 A.".
          When they attempted to pull the full 430 watts from the supply the over power protecton kicked in. This is normally to prevent the PSU from frying if you pull over its rated power.
          However this limit is supposed to be slightly above or at the supplies rated wattage!
          It's also manufactured by HEC (a Taiwanese Company) I seriously hope that it's not the same HEC that makes bad capacitors.
          If you don't drive the PSU really hard though it should hold up fine and on the bright side at least it shut it self down during the tests rather then blowing itself up.
          • yanz
            • Nov 2004
            • 910
            given the reputation of su'scon caps, you should want to void the warranty.. lol
            btw $120 for a 430W PSu is really too much..
            days are so short when you actually do something..
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Do you mean the "YEC" caps, which BTW have saw bad before.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • bgavin
                • Jan 2007
                • 1355
                #27
                I need a client to bring in another dead eMachine or two... I'm hunting for short cases under 15" total height.
                I just worked a live eMachine today, and found it had a Delta PSU installed. Surprise, surprise... nice to see one without a Bestec in place.
                • ElCid
                  • Aug 2009
                  #28
                  hello,
                  I am looking for a copy of the two restore cds. is there any way that I can get a set. I have lost my original set. Perhaps some how down load them
                  regards
                  Cid
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    i have a t5026 with a delta 350w. case ventilation sucks, the hard drive gets really hot all the time. i upgraded it to a p4 presscot 630 and a schythe katina cooler. btw, the psu is aftermarked, i dumped the burnt up bestec.
                    sigpic
                    (Insert witty quote here)
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      My friend's grandpa gave him his old Emachine a couple of days ago. 2.8ghz celeron D with 1 gig of ram,
                      Surprised to find a 300W Lite-on psu.
                      • Phaihn
                        • Jan 2009
                        • 842
                        that happened to me before when i tried to turn on the PC i heard and saw a spark so i replaced the PSU and it worked fine after that.
                        My Computer.
                        AMD APU A4-3300 2.5ghz 1mb cache
                        Motherboard GigaByte GA-A75M-S2V
                        Kingston HyperX Blue DDR3 8GB (2x4GB)
                        SB Audigy 2 ZS [B800] Sound Card
                        500GB WD Caviar® Blue™
                        1 Terabyte WD Caviar® Black™
                        2 Terabyte WD Caviar® Black™
                        • kleung
                          • 72
                          just to bring up a necro thread.
                          emachines with bad bestec 250atx-12e psu. partially fried motherboard; boots but both the audio chip and the usb lines seem damaged. shows up in windows but won't actually work/run.
                          also; measured the 5v line and the voltage is fine when running. however, spikes on power up.
                          • kaboom
                            "Oh, Grouchy!"
                            • Jan 2011
                            • 2507
                            Sometimes, there's diodes or a MOSFET matrix that keeps certain things powered at all times.
                            When the system's on, normal +5 is routed to audio, USB, etc. But when off, +5SB then powers those items. Needless to say, if the standby supply runs away, things will fry.
                            "pokemon go... to hell!"
                            EOL it...
                            All style and no substance.
                            guilty,guilty,guilty,guilty!
                            guilty of being cheap-made!
                            • stevo1210
                              • Oct 2006
                              • 4156
                              LOL just saw this today, been told that the e-machines is still running till this day and soon will be in retirement!
                              Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
                                ACER eMachines PT.NCAE2.071 eMachines EL1850 E5800 Specification for Upgrade or Repair
                                This specification for the ACER eMachines PT.NCAE2.071 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the eMachines PT.NCAE2.071 boardview and eMachines PT.NCAE2.071 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-12-2024, 03:36 PM
                              • double_DD
                                How can I be sure that my EC chip is dead?
                                by double_DD
                                As the title suggests, how can I be sure that my EC chip is really dead?
                                I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                03-12-2025, 07:47 AM
                              • grimacelord
                                OLD eMachines T6520 BIOS Request!
                                by grimacelord
                                I know that this is probably a long shot, but I figured if anyone could find this BIOS, it would be you guys.
                                I am working on an (old) eMachines T6520 desktop PC that might have a corrupt BIOS.
                                Model:
                                eMachines T6520
                                Motherboard markings:
                                MS-7145B0505068731
                                RS480M
                                7145 v2.1 RS480-A21+SB400-A23
                                Symptoms:
                                The computer does power on, CPU fan spins, but does not POST. No display.
                                Troubleshooting steps so far:
                                Replaced the CMOS battery (which was in need of replacing)
                                Re-seating...
                                01-12-2024, 12:43 PM
                                Acer eMachines EM355-131G25ikk Netbook 350 Specification for Upgrade or Repair
                                This specification for the Acer eMachines EM355-131G25ikk Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EM355-131G25ikk boardview and EM355-131G25ikk schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 05:27 AM
                              • disorder
                                ps5 edm-033 dead after hdmi/usb ports destroyed
                                by disorder
                                hello guys,
                                i need help to repair a edm-033 ps2
                                history : as always hdmi port and usb ports destroyed after unplugged
                                after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                so i changed it
                                now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                i don't see any projection of liquid metal on pcb.
                                01-14-2025, 12:48 PM
