Supermicro curse strikes again
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Supermicro curse strikes again
    Crap, lost the orginal chip.
    I'll probably order a replacement... Topcat, you need not risk the life of your board for my board... as then we'd have TWO dead ones.
    edit- ordered... Wish me luck... if not, Tocat may get a free backup chip for his board (and I'll have a partial system to do something with )
    sigpic
    (Insert witty quote here)
      • 31269
      i'm amazed that nobody statesside on this forum has a programmer.
      i could prog a few, but i dont know what the postage would be.
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        #43
        5 dollars and 3 weeks.
        • brethin
          • Dec 2008
          • 1907
          I have never needed a programmer to flash what I need flashed and I flash about 6 times a month. Rarely do I need to remove or replace the chip and when I do it is socketed so I just use a older motherboard to force flash it with whatever bios it needs. I guess in a way my old asus p4p800 is my programmer.
          • brethin
            • Dec 2008
            • 1907
            You don't need the original chip. Send me one of the others you have (when you ship that hard drive) that you said were the same and I will flash it with the factory bios and send it back to you.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Already ordered a chip (preflashed)... so unless I get a dud, I won't need another chip flashed.
              sigpic
              • brethin
                • Dec 2008
                • 1907
                Doesn't hurt to have a backup, ESP if you are trying to mod one. Anyway when you ship the hard drive if you have any chips you need flashed just send them with it and I will make you some backups.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  will do... may be a while, busy weekend. Hopefully no more than a couple days.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    chip came in, fixed it. They used a different model from what I was trying to force flash... which makes me think I was trying the wrong model.
                    I may try hotflashing... maybe.
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Fuck it...
                      It's unstable as hell... won't escape POST with 8GB installed (tried 2 sets of modules)... and with less (even 4 modules worth, say 5GB total) it will boot half of the time (POST hangs the other half).
                      Also, the chip included isn't flashable (model isn't reconized by every pheonix flash DOS utility I've tried) and hotflashing was no good (some file block was missing?). They used what appears to be an off branded 49F004T for the chip...
                      IDK if it's humidy or what... the basement is pretty humid.
                      Any suggestions or is this thing a goner?
                      sigpic
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Fuck it...
                        Don't give up yet. It also could be the DIMM contacts. First thing to do is give the board a Topcat-style cleaning!
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          before all this it was working fine...
                          sigpic
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            #53
                            were you wearing the right shirt?
                            Yup, I had another supermicro die... this time it's my X5DAL-TG2.
                            What happened was I on a SLIC 2.1 mod streak and like some other units (Including my Tyan Thunder K8WE) I flashed a modded bios I rolled my self.
                            What happened was the BIOS installed correctly but then on reboot it froze during the really slow first boot (before optimizing settings)... I hard resetted, now it spins fans.
                            I suspect it's a faulty BIOS chip, as in the past it's:
                            -randomly reset settings, even on a known good (brand new) CMOS battery
                            -radomly died for a few hours, fixed after time (or reseating memory)
                            Would ebaying a replacement (pre-programmed) for $16 be the way to go, or is there a low cost (<$50) programmer out there for such PLCC chips (I have dead boards to source chips)? Or does this not even sound like a bad flash chip?
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              The warranty was voided a LONG time ago... that shirt doesn't do the crap I pull justice!
                              hack hack hack hack hack...
                              sigpic
                                • 31269
                                http://www.rom.by/book/Uniflash
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Tried uniflash... found out the chip supplied was a 128x4K chip... and not the correct size for the rom! WTF?
                                  After some googling, I found out this:
                                  Originally posted by intel datasheet for the stock chip
                                  4 or 8 Mbits of flash memory for platform
                                  code/data nonvolatile storage
                                  - Symmetrically blocked, 64-KB memory
                                  sections
                                  - Available in 8-Mbit (Intel 82802AC) and 4-
                                  Mbit (Intel 82802AB) densities
                                  - Automated byte program and block erase via
                                  an integrated Write State Machine (WSM)
                                  The bolded model is my stock chip.
                                  So, those are the specs I need in a chip... looks like a digikey order is needed (so I can uniflash a proper chip).
                                  sigpic
                                    • 31269
                                    same capacity.
                                    126x4=512
                                    4m/8=512
                                    just different sector size
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      same capacity.
                                      126x4=512
                                      4m/8=512
                                      Yup, confirmed, as I desoldered an intel chip from a junk p4 gateway board and tried it... all the "stock" flash tools see it when hot flashed (and program it) but the result is a non-booting system (boot block issue?). Uniflash however doesn't work as the .rom is 3kb above 512kb... and it sees the image as the wrong size (I added trailing zeroes to make it 1mb and tried it on some junk 1mb chips... uniflash liked it but it wouldn't obviously boot)
                                      sigpic
                                        • 31269
                                        round 2
                                        DING DING
                                        http://www.flashrom.org/Flashrom
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          Same issue. 3kb file difference (the image being larger) trips it up...
                                          There must be some headers added by pheonix or something... I checked, it's not 3kb of 0's at the end of the file.
                                          sigpic
                                          • ugamazing
                                            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                            by ugamazing
                                            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                            08-31-2022, 07:34 AM
                                          • feherhollo
                                            WSON8 NEW Bios Chips READ, ERROR, ETC.
                                            by feherhollo
                                            I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                                            I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                                            For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                                            11-26-2023, 09:33 AM
                                          • Prott
                                            [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                            by Prott
                                            Hello dear badcappers!
                                            The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                            Backstory:
                                            After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                            If there is a way to narrow down which memory module is faulty it would make my life much...
                                            06-03-2024, 12:05 PM
                                          • LukeDavis
                                            Is there a list of known dodgy ATI Radeon chips?
                                            by LukeDavis
                                            Hello again! (People are likely going to get tired of seeing posts from me lol)
                                            I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                                            While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                                            1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                                            2. ATI Mobility Radeon X1600 and the...
                                            02-16-2024, 04:34 PM
                                          • piernov
                                            NVidia bumpgate
                                            by piernov
                                            Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                            Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                            May complete this post at a later date with more details.
                                            Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                            03-27-2021, 10:34 AM
