Supermicro curse strikes again
    • 31199
    Re: Supermicro curse strikes again
    there is, i cant remember the detail but there is a header.
    i remember from doing some bios ripping.
    something relating to winphlash, it may be data to pre-load the cmos.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      The bigger question is how to convert it into something uniflash/flashrom can use...
      sigpic
      (Insert witty quote here)
        • 31199
        maybe you can load it into winphlash and then save it out again as a bin?
          • 31199
          looking at the foto's
          the extra crap may be the DMI table.
          http://support.lenovo.com/en_US/deta...cID=SF10-D0004
            • 31199
            found a pdf.
            it makes a reference to command-line mode.
            and an option to not flash the bios but to save the bios "code"
            hmm.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              gave things another go, no dice. This time I tried copying the bootblock from the bootable chip to the intel chip, gave verification errors and still no boot.
              Topcat, if you still have your X5DAL-TG2 running, if you could run uniflash from a dos floppy and have it write the bootblock to disk (under the advanced submenu), and attach/email me the .boo (zipped or raw), things may be better over here.
              It's also possible I have a dud chip, this one was desoldered from a gateway rebadged p4 board.
              sigpic
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                the only one I have left is my shipdesk computer, which was built from a new hotspare board I had based on the old Big Mama hardware after I stripped it and gave you the board out of it. I had 3 of those boards for servers way back when.... Its in an antec solo case and no floppy.....so I'll have to dig it out and see how horrible it will be to plug a floppy in, the case is packed pretty tight....scsi ya know...
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  No USB floppy?
                  If it's too much trouble, then never mind... I may see what the going rate for these on ebay is...
                  edit- put a bid on this:
                  http://www.ebay.com/itm/SUPERMICRO-S...torefresh=true
                  I'll probably be outbid but if not, IIRC they use the same BIOS image... and before you ask, the x5dal's are still $100+ a board...
                  sigpic
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    No USB floppy?
                    I dont have one........lol... Go figure. I almost never use floppies anymore. You can get the BIOS chip from supermicro I'm sure, a lot cheaper than another board. Glad a board this old holds its value that well. Apparently not easy to find.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Scored for $51 shipped... If nothing else I have another board lol.
                      But last I checked supermicro wanted an arm and a leg for a chip, if they even had them. like $50 or so. Hence why I max bidded at $60.
                      Even if all it has is a good boot block, I can hotflash the chip into working... and if I ever find the original x5dal chip (I'm sure I'll find it someday) or the ebay chip that was the wrong layout and can't be reflashed (wrong model chip, bios program refuses to flash it) happens to work in the x5DAE, then I'll have another board and CPU's to play with/sell/trade/rehome.
                      sigpic
                      • Compgeke
                        • Feb 2014
                        • 524
                        Man, people still want Socket 604 stuff? I've a couple Tyan S2735 boards here I need to get rid of.
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16958
                          I'll take 'em. Still have a couple 604 systems in my fleet, they do just fine.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Other than the lack of x64 (on these, later 604's had it), they're nice indeed... had I not made the jump to 940 opterons I'd still use it full time.
                            sigpic
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              The E7525 chipset S604's supports x64, DDR2, PCI-e, 800FSB, and if you find the right board they also support the Paxville dualcore Xeon's as well. Not too shabby!
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                http://www.ebay.com/itm/111465365869
                                I scored that today.... The SM e-ATX case is what I was after and well worth that... When it arrives, I'll see if I can get the BIOS you need, the G and the TG2 use the same BIOS.
                                Team : 49813
                                Join in!!
                                Team Stats
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Nice. Same bios. Want to trade the mobo for my X5DAE I ordered? It's the same as what you ordered only EATX with 6 DDR slots and iirc more PCI slots. I don't have another EATX case so I only bought it for the bleeping Bios chip.
                                  Edit- shit, the X5DAE has just one gLAN (iirc the x5dal-g does too?) and has on board audio and as a result uses a different I/O shield which isn't included...
                                  Also, boot block writing isn't working on uniflash at all so a .boo is useless. My only hope is a fresh chip from either board.
                                  sigpic
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    I might consider it....too bad theres no IO shield with yours.... Let me see what I have to work with, and if this one I've got coming even works....but I'm sure the BIOS will be ok. listing says it beeps....but theres no GPU or RAM in it, so thats probably why its beeping. I paid $80 for it....didn't realize it didn't show that....but I was logged in when I copypasta'd the link.
                                    My plan for that case is developing a supermicro system that will run my pair of paxville dual core S604 CPU's. there's only a handfull of boards that support those.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      So either board is a dust collector to you?
                                      sigpic
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16958
                                        I'd find something to use it in, if it works....too nice of a setup to not use.... It just won't be in that freight train of a SM eATX case!!
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          Yeah, EATX cases are beasts. Love them.
                                          sigpic
                                          • ugamazing
                                            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                            by ugamazing
                                            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                            08-31-2022, 07:34 AM
                                          • feherhollo
                                            WSON8 NEW Bios Chips READ, ERROR, ETC.
                                            by feherhollo
                                            I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                                            I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                                            For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                                            11-26-2023, 09:33 AM
                                          • Prott
                                            [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                            by Prott
                                            Hello dear badcappers!
                                            The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                            Backstory:
                                            After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                            If there is a way to narrow down which memory module is faulty it would make my life much...
                                            06-03-2024, 12:05 PM
                                          • LukeDavis
                                            Is there a list of known dodgy ATI Radeon chips?
                                            by LukeDavis
                                            Hello again! (People are likely going to get tired of seeing posts from me lol)
                                            I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                                            While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                                            1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                                            2. ATI Mobility Radeon X1600 and the...
                                            02-16-2024, 04:34 PM
                                          • piernov
                                            NVidia bumpgate
                                            by piernov
                                            Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                            Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                            May complete this post at a later date with more details.
                                            Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                            03-27-2021, 10:34 AM
