Livestream is driving me crazy...
  • Maxxarcade
    • Jul 2006
    • 973
    Anyone else been having issues with Livestream crashing Flash regardless of browser used? Every time I load up a channel, the ad will play, and then the video window goes black. Within a couple seconds, it locks the browser until I stop the Flash plugin.
    Seems I'm not the only one having this problem according to the Livestream forum, but nobody has found a solution yet.
  • 3d0
    • Jan 2014
    • 159
    • BiH
    Re: Livestream is driving me crazy...
    Works fine for me. Both on IE and FF.
    Cant wait for supercross to start
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Are you running Flash 13x?
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
        • 31144
        it's your flash version.
        they ALL have bugs - just different bugs.
        flash is a joke - adobe is a joke.
        if it's not flash being fixed, it's the pdf reader.
        • Maxxarcade
          • Jul 2006
          • 973
          Yep, on Windows 8.1. Same problem on all browsers.
          • ivtec
            • Dec 2008
            • 1967
            I have also problems with streaming lagging in Mozila FF28 but in Linux Ubuntu 14.04, i've installed Google Chrome and all is good,i guess flash player in firefox28 has bugs on my end.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Probably because it's 11.2x. You're required to have Chrome to get later versions of Flash under Linux.....
              Arc A770 16 GB
              • ekozeko333
                by ekozeko333
                🧠 What I’ve Done So Far
                Flashed...
                06-21-2025, 02:48 AM
              • corrize
                Nikon D800 camera - flash don’t work and capacitor don’t charge
                by corrize
                Hello, I'm stuck in troubleshooting…
                The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                10-01-2022, 10:02 AM
              • spmetroil
                Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                by spmetroil
                I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                I have a CH341A programmer and I already attempted the following steps:
                1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                08-19-2025, 09:23 AM
              • abajor
                Canon VIXIA HF S10 A read data from inernal flash memory.
                by abajor
                Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                I think my best shot is to figure out a way to read the internal flash memory outside...
                07-20-2024, 12:04 AM
              • Ihandyrepair
                4 red flash led 65X950G boot Sony and android logo but then black
                by Ihandyrepair
                HI guys
                I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                here is the issue
                I have Sony and android logo. but then 4 led red flash lights front of the tv
                I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                but then I get black screen and 4 red flash light at the front LED
                but I get 3 led flash on the LED driver board.
                I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                so I tried...
                07-11-2024, 01:45 AM
