Ceramics near CPU socket.
  • linuxguru
    • Apr 2005
    • 1564
    This has probably been mentioned elsewhere, but this is what I did to an MSI 7061 (KM4M-V) board to permit a stable overclock of an Athlon XP2000 (266 FSB) to an XP2600 (333 FSB). I populated the six 0603-outline ceramic bypass capacitors directly below the socket with 4.7uF/6.3 X5R ceramics with measured ESR of ~0.4 ohms each. The ESR specs aren't great, but six of them in parallel very close to the pins of the CPU appear to help greatly. Not only does it overclock stably, the idle CPU temperature dropped from 60c (too hot) to 57c (still hot, but better) with no other changes.
    I'm not sure if these ceramics bypass Vcore or 3.3Vdd, but they seem to work regardless.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Ceramics near CPU socket.
    Yup, but pics please
    https://www.badcaps.net/forum/showthread.php?t=1493
    • linuxguru
      • Apr 2005
      • 1564
      Messy soldering, but here is the pic of the underside of the socket:
      • Agent24
        I see dead caps
        • Oct 2007
        • 5085
        • New Zealand
        They probably found that those capacitors weren't critical for operation and figured they could save 1 cent per board if they didn't fit them!
        -David VanHorn
        • linuxguru
          • Apr 2005
          • 1564
          Yeah, or they sell a Pro- version of the board priced at 2x, which has better electrolytics, VRM and all these ceramics populated, and validated with higher-FSB processors. I'm fine with that, as long as they're up-front about it - Intel has been doing similar stuff from the era of the 487SX, and later with the Celeron.
          • nehal
            • Nov 2014
            How big would a 820uF 6.3V capacitor be? What kind of ESR would you get?
            nehal
            Save your time and get on 117-202 in wikipedia and testking University of Wisconsin - Madison exams by using our latest CHECKPOINT and other superb exam pass resources of examsheets and IBM
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              it would be a big brick if it was an mlcc.
              even a poly would be too big.
              btw 2.5v rated parts would do here.if vcore exceeds 2v you got big problems!
              • mariushm
                • May 2011
                • 3799
                Next time, use ceramic capacitors rated for higher voltage or use C0G/NPO rated ceramics (which don't have voltage bias issues).
                A 4.7uF 6.3v rated capacitor will barely be 2.5-3 uF with 2-3v on it. And those locations are for decoupling capacitors, something like 100nF, not >1uF. High capacitances are unlikely to matter that much there, just the mere existence of something there helped.
                As for bulk capacitance on the other side, such boards don't get much benefit from polymer capacitors but if you do want to use some, 680-820uF 4v rated polymers would work just fine.
                • Isabella91
                  Possible to convert eMMC Socket to a micro SD Card socket?
                  by Isabella91
                  I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
                  Read/Write a Micro SD Card from an eMMC Socket.
                  I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
                  Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
                  Not to remove...
                  01-14-2024, 05:10 PM
                • warsztat
                  Acer AN515-57-577G JDIMM1 socket not working.
                  by warsztat
                  Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
                  11-18-2024, 09:13 AM
                • AJ847.63e
                  LGA 1700 Socket Replacement Tips & Tricks
                  by AJ847.63e
                  Hi All,
                  Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
                  I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
                  07-24-2025, 06:57 PM
                • Spudgun
                  Why doesn't current just bypass faulty capacitors.
                  by Spudgun
                  Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                  04-01-2025, 10:33 AM
                • Geomih
                  CPU socket replacement soldering profile
                  by Geomih
                  Hi All - I am hoping someone can help with some pointers (complete noob here!)
                  I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
                  My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
                  The simple stuff like a small memory module isn't a big deal because there are
                  12-11-2023, 11:07 AM
