Cooler Master Centurion 5
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    This is one sick case. I think i will get another one. Pity about the 80mm front fan though. Pics came out a bit crap.
    Front panel is part aluminium. The aluminium side edges look very good. The grilles also. The panel is solid and comes off the case nicely without breaking things.
    The bay covers are grilles and they have dust filters at the rear.
    When the front panel is removed the areas for the front panel connectors and the power, reset switch and led remain attached to the case. This is very good so there is no fiddling with wires. The hdd led is a very nice blue. I did not see what the power led was yet cos it was connected wrong.
    room for some cable tidying at the side.
    the bays have a locking device on one side. its not too bad.
    single 120mm fan for the rear and 80mm for the front. both were very quiet cooler master models
    curiously you can put screws on the other side. the technician who assembled the case did so i see his faith in the locking devices......
    price : 49 euro (without psu)
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Cooler Master Centurion 5
    Why not just take your laser cutting machine and mod it for 120mm?
    https://www.badcaps.net/forum/showpo...&postcount=134
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      smartass
      • Galvanized
        • Mar 2006
        • 468
        Mod it for a 92x38...If it will fit.
        Silverstone offers 90mm fans that mount on 80mm fan holes.
        Yes, it is a nice case.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          i aint modding nothing. its not mine. The next one will be mine.....
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            I have personal experience with the Centurion 5 as well, and it's a great case to build with!
            Ludicrous gibs!
            • WNG
              • Sep 2006
              • 354
              Nice review and pics!
              Cooler Master is really catching my attention lately. The cases are very smart looking, and the design and construction looks well done. The only questionable area is the power button assembly in front of the 80mm front fan. Not only being 80mm is a negative (could be bigger for better flow/noise), but the button assembly blocks the intake, and that also cause turbulence noise.
              So, how is the steel construction? As thick as, say, In-Win, Antec cases?
              “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
              We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                not sure about the steel thickness cos i received the pc built . I doubt it is on a par with the chenbro built antec ones, seems pretty standard low end stuff. its ok though, no complaints. A Lian Li which would probably solve your cooling complaint would be instead of 49 euro, 89 euro.
                • randomchance
                  • Apr 2006
                  I got the Centurion 532 a few weeks ago to replace my old no-name case that housed my last 3 computers. Its the one with the vertical aluminum bars on the front, the buttons on the top, and a 120mm fan tucked away in front of the hard drive bays. I put another 120mm fan in the rear an mounted my hard drives with an empty bay between them. My system temperatures have dropped about 3-4 degrees C in the new case and my HDD temps have dropped by about 8 degrees. And the whole front is that cool looking black mesh with filters behind then whole thing to stop the dust bunnies from nesting in the case. Everything I have in there fit perfect and went together pretty painlessly, even the no-tool drive bays and rear slots work well. I really like the Centurion line, CoolerMaster hit the nail on the head with these cases!
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    especially the price
                    • WNG
                      • Sep 2006
                      • 354
                      Heads up!
                      Those interested in the case, it's selling for $29.99 AR at CompUSA.com
                      http://www.compusa.com/products/prod...ct_code=319347
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        its 69.99 now
                        • Topcat
                          Cooler Master ATC-S + Some other CoolerMaster Case - 2-fer in 1 Thread
                          by Topcat
                          This is a Coolermaster case double-header.... The reason this one didn't get added to my 'misc build' thread is becasue the Cooler Master ATC-S aluminum case....That case is a class-act way above & beyond anything in that thread! However, we have to get through a mediocre build to get to the treasure!
                          ...but here's the two Cooler Master cases in question; both of which were drop-offs for recycling.... The one on the left, I'm not really sure what model it is. It's nothing overly special, but it is well-made. The one on the right is an ATC-S solid aluminum, best I can determine...
                          03-12-2022, 10:58 PM
                        • anikin73
                          Cooler Master 500W atx psu repair. Total cannot start at all
                          by anikin73
                          I am attempting to repair this. Circuit is quite simple, but i a quite stuck at it for a long time. so today i try to ask for new ideas. my challenge is to under stand what mistake i made. I had repaired not lesson than 50 pcs of various brands ATX psu . main pwm chip is Cm 6805 Sip 9 .
                          5VSB is fine. When I short Pson, totally nothing happen. I check , the Cm 6805 VCC pin2 did have 16v, But totally nothing happen. I changed to a good chip from another good PSU. Same thing.
                          What other pin should I check such that it will result in no start up at all ?
                          07-07-2024, 07:06 AM
                        • dariolana
                          ATX PSU Cooler Master RS-700-pcaa-e3 shutting off after 5 seconds
                          by dariolana
                          Got this from my kid with a fault on primary side. Main power supply here is AC 220V. All caps were Ok, testing with 2 series lamp of 70W each, got a bright lamp . Checked main heatsink one by one with my component tester and found one 3 leg buddy MDP18N50 that passed away. Got same replacement after a week, tested, short was gone, now I got 310V on primary.
                          Happy as a dog, added one case fan for some load and the fan of the PSU. Tested purple wire, got 5.1V, great!. Shorted green and black, fan spins and after about 5 seconds shuts down. I was able to measure doing several iterations...
                          02-26-2024, 07:47 PM
                        • stomanata
                          Problem with PSU Cooler Master MPX-5501-AMAAB
                          by stomanata
                          Happy new year.
                          This PSU use WT7527V supervisor.
                          On purple cable i have 5V, but on #4 of WT7527V i have 0.21V.
                          If i try to start PSU with short between green and black it star for a second and stop.
                          For what other to check? I now that is needed more info but i don`t know what else to share
                          01-07-2024, 11:48 AM
                        • tony359
                          Cooler Master 1200W Silent Pro Gold - Bad power switch
                          by tony359
                          The PSU in question had a bad power switch. There was not physical feedback when switching on and - if memory serves - it was always ON even when in OFF position.
                          I researched a bit and got some replacements.
                          The replacement "got stuck" at first power up - as in "it's now always on".
                          It looks like this PSU has a pretty large inrush current as my lights flicker when I turn it on with no load.
                          Probably the switches I got are bad quality but I was wondering if someone could recommend a good replacement?...
                          06-18-2023, 11:42 AM
