segate hard drive connections?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys ;anybody knows for what type of desktop or motherboard is this segate hard drive,it has a deferent connection then i use to see all my desktops have pins connections
    http://www.donordrives.com/seagate-3...ard-drive.html
  • gg1978
    • Dec 2004
    • 431
    Re: segate hard drive connections?
    The AS suffix indicates it is a SATA hard drive which is the standard for computers made in 2004-5 timeframe or later..
    • ivtec
      • Dec 2008
      • 1967
      Thanks; this hard drive was given to me and i was about to throw it out cause it was all dirty and it did not fit in most of my desktops,but coincidently today i did go install a fan in my Ati Amd 6450 video card in my main lenovo pc and for my surprise the plugs fit in my Lenovo Thinkcenter m71e i knew it but i had forget it,it's what happen when one is getting old, i did connected it to test if it was good,it had Win Vista on it, but it did not boot all the way, had errors and also needed name and password, then i had Xubuntu 1310 in a USB stick booted with it and tested it and it came up good,then installed linux and now i have an extra hard drive, what a luck,also by coincidence i was looking at the ram slots and see that i can add one more slot of 4gb ram to make it 8gb, well this day was a full day of surprises.
      • cheapie
        null
        • Jul 2010
        • 849
        There are *still* people discovering SATA for the first time?
        Anyway, this is how practically all hard drives (and optical drives) come now. It's almost impossible to find IDE drives now. In fact, my motherboard doesn't even have an IDE controller (6 SATA III ports, though).
        Here's a comparison of the speeds:
        IDE (max.) - 1,064 MBit/s
        SATA I - 1,500 Mbit/s
        SATA II - 3,000 Mbit/s
        SATA III - 6,000 Mbit/s
        Even cheap SSDs can saturate IDE or SATA I, and some expensive SSDs can saturate SATA II now. (I still think they moved to SATA because it's cheaper, though)
        • Hondaman
          • Sep 2008
          • 1092
          Also, IIRC, SATA has much higher total capacity than EIDE.
          Perhaps EIDE would have gotten the larger capacities if they had continued to make them (as platter technology advanced).
          • federalhouse
            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
            by federalhouse
            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
            **Background:**
            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
            **What I've Tried So Far:**
            1. I accessed
            08-01-2024, 07:03 PM
          • tmcw
            PC case - Hard drive rails
            by tmcw
            A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
            So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
            I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
            Now, the case is a CiT Gaming Case, and...
            05-22-2022, 12:04 PM
          • madura2010
            DAY11AM6E0 hard disk drive and optical disk drive not detected
            by madura2010
            Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
            i checked the connectivity of ribbon=good communication with hard and motherboard
            changed hard disk and checked=3f0 error persist
            sata power=+5v available
            Then checked data capacitors=all good
            Then checked data lines path connectivity to pch=all good
            reflashed...
            03-12-2023, 09:09 AM
          • ash91
            Hp pavilion 15 not detect hard drive
            by ash91
            Hello gentelmen .... this is my first post and sorry for my bad english,
            so my proplem is my laptop keep losing hard drive even if i but the
            hard disk in the cady (the box that can replace the dvd rom with hard disk)
            when i turn the laptop on the massage that said no boot media found pop on
            the hard disk is fine and to be sure i try another hard
            i also update my bios to the last update
            the 5 volt is present on the hard connector on the motherboard
            the dvd rom work fine when i but a windows dvd in it
            also when i boot from flash...
            06-07-2023, 01:45 PM
          • karto95
            Repairing a Seagate hard drive with damaged logic board
            by karto95
            I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
            I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
            If anyone has any suggestions or experience with this...
            03-21-2023, 04:05 AM
