Broken Samsung 2253LW
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hello I got a Samsung 2253LW for free a while back and the backlights don't work. The monitor had bad caps so I recapped and when I turned it on there were lines on the screen then it went out. The ccfl's dont work on a good board but the board wont work on good ccfl's. When I plug the ccfl's into a good board it flickers and makes bad noises then goes out. When I plug good ccfl's into the board it flashes then goes out. Is there any way I can test the inverter transformers with a digital multimeter?
    What could the problem here be?
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • Sparks88
    • Sep 2011
    • 110
    Re: Broken Samsung 2253LW
    are you testing the ccfls in the same model board?, i had one of these and changes the ccfls for led lighting (one of the tubes was fractured at the end cap, i also disabled the power to the inverter board as the brightness control was done by the seperate power board.
    • canadaboy25
      What is normal?
      • May 2013
      • 509
      No the board is a different model. Does this matter? I have ccfl's that will work in other boards.
      canadaboy25
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        You can test some transformers pic of top and bottom of it would help and part number.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • C152Heavy
          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
          by C152Heavy
          Summary for TL-DR readers:
          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
          • Have obtained Samsung schematic & service documents - Can upload if helpful.
          • Have read ALL applicable threads
          • C1818 and CP820 replaced as low hanging fruit
          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
          09-07-2024, 05:50 AM
        • Nicktronic
          Samsung Power Supply Board BN44-00874F
          by Nicktronic
          Hey everyone,
          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
          Anybody...
          03-17-2025, 06:20 AM
