Sas backplane sp410423/412736 pinout
  • wasureppoi
    • Feb 2013
    • 35
    As HP technical support were unable to help I wonder if anybody out there would have any idea what the voltage requirements are for the DL380 G5 and ML150 G3 backplanes are? I have tried 12v/5/3.3V every which way but loose to no avail.
    Helppppppppppppppp.
  • shadow
    • Feb 2007
    • 732
    Re: Sas backplane sp410423/412736 pinout
    I'm a little bit confused with what information you are after. Can you give us some further information, perhaps even an image. What backplane are you talking about? I assume the backplane to the hot-swappable hard drives which I would have assumed would be 12V/5V.
    • wasureppoi
      • Feb 2013
      • 35
      In the pics I have attached each backplane board has a molex female 10 pin plug. I would like to know the pinout for these. Indeed it may only be 12 and 5 V that is necessary but in what arrangement is the 64 dollar question.
      • shadow
        • Feb 2007
        • 732
        I have an old proliant server...when I have some time I will open it up and take a photo of the molex connection. Hopefully that will provide some insight.
        • wasureppoi
          • Feb 2013
          • 35
          Thank you for your offer.
          I did not include a photo of the cable because regrettably all wires are brown thus not at all helpful.
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            Wish I could help out, but all my G5's are still in production. I didn't think the ML150 G3 would be SAS... isn't that SCSI?
            Ludicrous gibs!
            • wasureppoi
              • Feb 2013
              • 35
              Fraid its Serial Attached Scsi. Maybe my close ups arent close enough. Some servers offer both. I have SCSI backplanes coming out of my ears!
              • seanc
                • Nov 2008
                • 1319
                I've got a dead ML350 G5 but if they're all going to be brown that won't help. I have a suspicion some are yellow.
                • wasureppoi
                  • Feb 2013
                  • 35
                  We all know how manufacturers constantly often subtly modify their production lines. If you have yellow and brown it might help but if it is dead you may not want to disturb it.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    why do you want to know? does it not work? are you trying to adapt it for something else?
                    • wasureppoi
                      • Feb 2013
                      • 35
                      Without power they cannot work. I have far more SAS drives than I have working SAS controllers to utilise them. I confess I am a storage freak. I am trying to adapt to something else as I like to set them up as stand alone. Regrettably I was about to measure the voltages on one of the backplanes but fate intervened before I had a chance. The other one came from a dead server anyway.
                      • sidewinder69
                        • Nov 2010
                        • 8
                        • Singapore
                        Hope these helps.
                        http://forums.bit-tech.net/showthrea...=158206&page=8
                        http://forums.overclockers.com.au/sh...d.php?t=962776
                        • wasureppoi
                          • Feb 2013
                          • 35
                          Thanks heaps.
                          At a glance it looks fantastically informative.
                          Hope to be able to get back to you with success at my end. The molex plug pics alone are awesome.
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            that first link would nail it for me.
                            great.now you can use yours and i know what to do with the cage/controller i was offered.
                            • wasureppoi
                              • Feb 2013
                              • 35
                              I found that I had my 5V and 12V connections correct but had not been using the 3.3V.
                              Without actually connecting it to a SAS-controller-attached system yet I am still getting what I had before though namely all the LED's lighting up and SOLID on power up. This as I say without any data cable connected. This has turned me off from the outset because whilst they normally flash on they should go off (I think until the controller is reading them.). I am wondering whether my experimentation has stuffed this particular backplane (of which I only have one). I will be connecting it properly soon if only to confirm my suspicions but I am still delighted to be able to get such feedback.
                              • pickledegg
                                Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
                                by pickledegg
                                Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
                                I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
                                10-02-2024, 04:54 PM
                              • maleksa
                                Korg Kross2 Service Manual and LCD pinout
                                by maleksa
                                The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
                                However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
                                Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
                                From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
                                10-11-2024, 05:54 AM
                              • AlexVG
                                SAMSUNG UE65HU8500 ONE CONNECT pinout connector request
                                by AlexVG
                                I came across with
                                SAMSUNG UE65HU8500
                                ONE CONNECT BN41-02135
                                Chassis GOLF_UHD_1MP_JACK
                                TV can not recognise ONE CONNECT box, so I need to know the pinout of the CN 3301 connector.
                                Moreover, on the main is written A5V. However, cable connected this pin to the GND.
                                Maybe somebody have an experience with the same issues?
                                I need your help.
                                Thank you....
                                06-08-2025, 06:49 AM
                              • Arashiak
                                QY6-8002 Canon 2410 2010 inkjet (head pinout) HELPPPP eeprom
                                by Arashiak
                                Dear all friends
                                I am going to read the eeprom inside this printer head i need some help from some expert that work with the canon printers
                                1. what chip they use inside the head that i mention in title?
                                2. Is there anyone helping me identifying the pinout
                                Thanks in advance to all the people that cooperate and Badcaps.net staff.
                                05-26-2025, 06:09 PM
                              • oldham50
                                tcl t-con board 30840-000035 looking for datasheet or ribbon pinout
                                by oldham50
                                I have a TCL Roku 43" tv that has no picture or sound with vertical lines. I have replaced the main board which solved the no standby voltage problem. I have checked all the voltages on the T-Con board and they are ok. I suspect the VGH voltage is not present on the 2 panel boards but i can not find any marking where this voltage is identified. I am attempting to trace the VGH voltage thru the ribbon cables but need the pinout.
                                05-06-2025, 01:40 PM
