need help finding windows key in recovery disk
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    i have a OEM recovery disk from powerspec that has had damage to the outer sectors of the CD so i cant install from it and i heard that they use some sort of auto install config with the key in it but i cant find it i listed the output from 'ls' of the root of the disk and the 2 subdirs in hopes you can help
    drive root
    Code:
    English.zip Master.log RCBoot.sys WIN51IC.B2  WIN51IP.RC2 XGA
    GRAPH    MENUND   USTIME   WIN51IC.RC1 WIN51IP.SP1
    GRAPH16   MOVE    WIN51    WIN51IC.RC2 WIN51.RC1
    HPCD.sys   NTFS    WIN51.B2  WIN51IP   WIN51.RC2
    [COLOR="Blue"]I386     PRELOAD[/COLOR]   WIN51IC   WIN51IP.B2  WINBOM.INI
    PRELOAD
    Code:
    ALL.CRC   BASE_06.INP BASE_17.INP DATA5.INP   DATA9_05.INP DVD
    ALL.FIL   BASE_07.INP BASE_18.INP DATA6.INP   DATA9_06.INP LANG.W32
    ALL.I32   BASE_08.INP BASE_19.INP DATA7_01.INP DATA9_07.INP SPLIT.LOG
    ALL.ITR   BASE_09.INP BASE_20.INP DATA7_02.INP DATA9_08.INP WINDOWS.CRC
    ALL.MDF   BASE_10.INP BASE.DAT   DATA7_03.INP DATA9_09.INP WINDOWS.DAT
    ALL.W32   BASE_11.INP BASE.INP   DATA7.INP   DATA9_10.INP WINDOWS.FIL
    BASE_01.INP BASE_12.INP CD0     DATA8.INP   DATA9_11.INP WINDOWS.I32
    BASE_02.INP BASE_13.INP DATA1.INP  DATA9_01.INP DATA9_12.INP WINDOWS.ITR
    BASE_03.INP BASE_14.INP DATA2.INP  DATA9_02.INP DATA9_13.INP WINDOWS.MDF
    BASE_04.INP BASE_15.INP DATA3.INP  DATA9_03.INP DATA9.INP   WINDOWS.W32
    BASE_05.INP BASE_16.INP DATA4.INP  DATA9_04.INP DESC.TXT
    the contents of I386 are so long i piped them into a text file. can anybody tell me where this darn install config is?
    Follow the white rabbit.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: need help finding windows key in recovery disk
    if it's not in a file called Unattend.txt, it's probably slp bios or OEM Preinstallation Kit buried on the disc.
    • bluto
      • Oct 2007
      • 560
      I assume this is XP you are talking about... It also appears that POWERSPEC was a royalty OEM for XP (on the same level as HP, DELL, etc.) In XP, the SLP 1.0 pre-activation scheme needs three things. 1. The manufacturer specific product key for the edition of windows (Home, Pro, etc.) 2. The computer must have the appropriate OEM string in the BIOS (quite literally something to the effect of 'DELL COMPUTER'). 3. These 4 files that correspond to items 1 & 2: OEMBIOS.BIN, OEMBIOS.CAT, OEMBIOS.DAT & OEMBIOS.SIG. Note that they might be in compressed form with a '_' in the last character of the file name. You can install any edition of XP and then use a program called 'OEM BIOS Changer' to convert the license to Powerspec OEM SLP. Or you can use a tool like nLite to create a new XP install disc with items 1,2 & 3 already in place via an un-attended install script.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        thanks for the quick response
        thsi system runs a generic Intel BIOS, no SLP key to be found.
        theirs a file called Unattend.txt in the I386 folder is that the key? im trying to run these in VMware workstation 9 will it work in there?
        • mockingbird
          • Dec 2008
          • 5484
          If it's not on th CD, you will either need to use a good OEM key and then activate it, or use an SLP enabled BIOS for VMWare.
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            yer, i found the Unattend.txt file and the key, can i use this in VMware?
            • mockingbird
              • Dec 2008
              • 5484
              Theoretically yes. After installation, activate either online or by phone...
              It shouldn't ask you for a a key during installation, since this is an unattended install.
              If the key is blacklisted by Microsoft, then you'll need to use an SLP modded BIOS for VMware.
              VMWare 10 is out by the way, in case you didn't know. I haven't seen that much of a difference. I installed it over a month ago. Don't forget to install the "extensions" or supplemental drivers or whatever they're called in VMWare for the enhanced drivers/features, and make sure virtualization is enabled if you're using a VT-capable platform.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                oh! i forgot something, the disk is f*cked and testdisk was only able to get some of the data, the txt file included. im going to have to install from a disk with another key and change the key before i go online.
                how silly of me to forget crucial information.
                • Uniballer
                  • Jul 2013
                  • 334
                  Can't you just buy a [similar] recovery disk on ebay?
                  • mockingbird
                    • Dec 2008
                    • 5484
                    No need for expletives...
                    Yes, make sure the disk is also an OEM disk, and after installation run "c:\WINDOWS\system32\oobe\msoobe.exe /a" (Yes, I want to activate by telephone, change product key, then run it again and activate online).
                    • Sparks88
                      • Sep 2011
                      • 110
                      xp does not have any slic keys for activation, slic licences started with vista and then win7 and now win 8 uses a totally different way to activate, you will also need an oem disk of the same version (oem xp sp1 or 2 or 3) for the key to be accepted and then you may also need to do the phone activation as well.
                      • mockingbird
                        • Dec 2008
                        • 5484
                        As I understand it, XP does have a similar system to SLIC called "SLP"... Apparently, activation does check for a string in the bios and activates it without phoning in or connecting online.
                        • Nitro468
                          • Oct 2013
                          • 65
                          Looking thru my slipstreamed files.. wow 7000+ files..I'll let you know if I find anything.
                          I have a few OEM install disks, I will peek at them and see.
                          • Nitro468
                            • Oct 2013
                            • 65
                            For future reference if you use Nlite, the key is stored in Last session*.ini
                            • DynaxSC
                              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                              by DynaxSC
                              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                              The behaviour is also really very strange, i.e.:
                              • The disk shows always up in BIOS - so it is recognized, so far so good
                              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                              02-23-2025, 01:33 PM
                            • duwane
                              A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                              by duwane
                              Hi All.
                              Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                              The issue:
                              Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                              10-26-2022, 07:02 AM
                            • volinakis
                              Chromebook recovery failed - how to fix it
                              by volinakis
                              So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
                              Finally I found a site where they suggested to try with an older image and ... it worked!
                              What I did:
                              - when β€œChrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
                              09-18-2023, 03:26 PM
                            • gizaha
                              by gizaha
                              02-13-2024, 07:18 AM
                            • 24gsm
                              MacBook Pro A1708 install macos fail
                              by 24gsm
                              hi to all
                              i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                              after enter to recovery and format hdd 1to .
                              after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                              can help please
                              Serial Number: FVFXP0U0HV2J
                              Config Code: HV2J
                              Find My Mac: OFF
                              04-16-2025, 03:57 AM
