i have a OEM recovery disk from powerspec that has had damage to the outer sectors of the CD so i cant install from it and i heard that they use some sort of auto install config with the key in it but i cant find it
i listed the output from 'ls' of the root of the disk and the 2 subdirs in hopes you can help
drive root
PRELOAD
the contents of I386 are so long i piped them into a text file. can anybody tell me where this darn install config is?
drive root
Code:
English.zip Master.log RCBoot.sys WIN51IC.B2 WIN51IP.RC2 XGA GRAPH MENUND USTIME WIN51IC.RC1 WIN51IP.SP1 GRAPH16 MOVE WIN51 WIN51IC.RC2 WIN51.RC1 HPCD.sys NTFS WIN51.B2 WIN51IP WIN51.RC2 [COLOR="Blue"]I386 PRELOAD[/COLOR] WIN51IC WIN51IP.B2 WINBOM.INI
Code:
ALL.CRC BASE_06.INP BASE_17.INP DATA5.INP DATA9_05.INP DVD ALL.FIL BASE_07.INP BASE_18.INP DATA6.INP DATA9_06.INP LANG.W32 ALL.I32 BASE_08.INP BASE_19.INP DATA7_01.INP DATA9_07.INP SPLIT.LOG ALL.ITR BASE_09.INP BASE_20.INP DATA7_02.INP DATA9_08.INP WINDOWS.CRC ALL.MDF BASE_10.INP BASE.DAT DATA7_03.INP DATA9_09.INP WINDOWS.DAT ALL.W32 BASE_11.INP BASE.INP DATA7.INP DATA9_10.INP WINDOWS.FIL BASE_01.INP BASE_12.INP CD0 DATA8.INP DATA9_11.INP WINDOWS.I32 BASE_02.INP BASE_13.INP DATA1.INP DATA9_01.INP DATA9_12.INP WINDOWS.ITR BASE_03.INP BASE_14.INP DATA2.INP DATA9_02.INP DATA9_13.INP WINDOWS.MDF BASE_04.INP BASE_15.INP DATA3.INP DATA9_03.INP DATA9.INP WINDOWS.W32 BASE_05.INP BASE_16.INP DATA4.INP DATA9_04.INP DESC.TXT
