Need a new drive?....a fast one?
  • 308nato
    • Feb 2007
    • 14
    Y'all don't have a Hot Deals section but here is one for you.....Best Buy has the Western Digital 10,000 rpm Raptors best price ever with no rebates necessary.....74gig for 101.99 and 150gig for 169.99. I think they are sold out online but in stock at many stores.
    Just an FYI if you need the speed.
    Old Age and Treachery Defeat Youth and Skill Every Time
  • Cubes
    • Dec 2006
    • 23
    Re: Need a new drive?....a fast one?
    Not sure how the 2 drivers reflect in the real world but I recently bought a Seagate II NCQ drive that in HD Tach performed just as well. :S
    Say no to Fuhjyyu!
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      great for those stuck with ide.
      everything here is 15k scsi.
      • gonzo0815
        • Feb 2006
        • 1600
        From my experience, there is not mutch comparable with an 10000rpm Raptor.
        I can assure you, that HDtach does not refleckt the real world speed of anything.
        There are some discusions abouth that topic burid in this forum, and all who have had real experience with a Raptor have come to this conslusion.
        Well 15000rpm SCSI, hm either you have the money or not mutch data, this stuff is far too expensive for my personal use.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          infact 15k rpm SCSI drives are not faster than the Raptor 10k rpm drives when used for single user dekstop usage scenarios...
          For server usage it is of course the other way around...
          The reason is that the SCSI drives are designed for mulit user usage, while the raptor has been designed for single usage patterns...
          All raptors are SATA ;-)
          • cook
            HP Power Supply 6632A: Fast Mode vs Normal Mode?
            by cook
            FAST MODE vs NORMAL MODE
            I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
            I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
            06-07-2020, 05:32 AM
          • SevenOFF
            Denon AVR-X4000 – Fast red blinking after 2nd relay
            by SevenOFF
            I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
            According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
            Here’s what I’ve done so far:
            • Fully opened and cleaned the unit (a lot of dust inside)
            • Removed and visually inspected the AMP board → nothing visibly damaged or burned
            • Testing is done with
            06-18-2025, 09:54 PM
            TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
            FF Series (Very Fast Acting), 0603 Size
            Features
            ● Very fast acting at 200% overload current levels
            ● Low DCR
            ● High inrush current withstanding capability
            ● Fiberglass enforced epoxy fuse body
            ● Copper termination with nickel and tin plating
            ● Halogen free, RoHS compliance and lead-free
            Applications
            ● Notebook computers and tablets
            ● Digital cameras
            ● Memory cards
            ● Toys
            ● Bluetooth earphones
            ● Portable electronic devices​...
            10-07-2024, 05:50 AM
          • paparazzo79
            fast charging vs normal charging cellphone,damaging battery?
            by paparazzo79
            Hi friends.
            I see there are many clever people here.
            I purchased used Note 10 plus phone,and it doesn't have good battery cuz it's been used probably more then a year.
            Since I'm not an expert into phones but my own thought is that fast charging with high current wears out battery more quickly and damages cells compared to regular charging.
            I don't need fast charging at all so I disabled that option in phone,since I don't care if my phone will charge 1h or 2.5 h (with regular charging).
            But want to ask does fast charging damage the battery cells as time passes...
            05-16-2021, 03:27 AM
          • Caimano
            hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
            by Caimano
            MB G7AD-2G DAG7ADMB8D0 REV D
            Processor i5 8265U
            AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
            Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
            Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
            02-06-2024, 10:14 AM
