Heatsink fan replacement
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    Ok...I have a couple of these Cooler Master HCC-002 copper heatsinks. I've had them for what seems like an eternity. One of the fans is making noise and I feel that its not long for this world. The original stats for the HCC is here.
    So....what I need is a reliable replacement for that fan. Anyone have a good source??? I checked a couple of usual sources, but there weren't any fans. I don't want to replace the heatsinks since they are good and a while back I lapped both the heatsinks and the CPUs. Ok....I was in ND and bored.
    Any ideas?????
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
  • tylerlough
    • Dec 2005
    • 96
    Re: Heatsink fan replacement
    stretch, have you tried peeling back the sticker on the center of the fan to put some oil on it. I have done this to several case fans and my northbridge fan and now they are working well. Can't remember the name of the spray lube I used on them, but I believe it's the stuff with teflon.
    • bgavin
      • Jan 2007
      • 1355
      Delta fans are well known for being loud. They spin fast (6800 rpm) and move a lot of air. This model has ball bearings, so noise will increase but it probably won't seize as soon as sleeve bearings.
      Unless you need the air flow, look into a Panaflo fan at a slower RPM. They have oil sealed bearings and run silent for a very long time. I install Panaflo fans in all my client machines.
      I use www.heatsinkfactory.com as one source for Panaflo fans. There is a PDF available that shows all the models and specs for Panaflo.
      Link to Panaflo PDF Files
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        i think its a 60mm fan. probably the best bet would be to get a 60-80mm adapter and put an 80mm fan on it.
        i second the panaflo choice.
        • stretch0069
          • Oct 2003
          • 2658
          This one gets loud, then quiet, then loud again. Does that at about 2 or 3 minute intervals....or there abouts.
          I'll look into the Panaflos.
          Anything to get rid of this noise.
          • Galvanized
            • Mar 2006
            • 468
            If You have the room (I like will's idea and have done it) use a 60 to 80mm adapter and a 80X38mm fan.
            According to this http://gizzo.8m.com/fans/fan60.html your 60X25@6800rpm is probably around 40cfm. The on again off again is probably thermal cycling.
            For thermal protection the CPU's fan must have a for real sensor wire, many three wire Chinaflos lack this. They will have a third wire(generally yellow) but it is a dumby. (The need for a sensor wire can be turned off in the BIOS but why do it? )
            Not cheap but consider http://www.sidewindercomputers.com/de80ef1.html All the EFB Deltas are real three wire fans. I am fond of and use the 92X38s in low and medium speed whenever I can. Triple bladed fans have a deeper more pleasent sound and work well in free air or on sinks with wide fin spacing, as your sinks have. For real tight finned sinks the 7+ bladed fans are best.
            I would not reduce cfm no matter what fan you select and would use ball bearing fans inside PSUs or on CPUs because of the high temp enviroment.
            Bronze sleeve bearing fans don't do well with lots of heat. Ceramic bearinged fans might be hard to find in the cfm you need but would do well in heat.
            Excuse me if you know this stuff...I just felt like BSing.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              thats what my stock intel p4 fan does. time to replace. the next case i get i will look into dust filters. i dont think dust is very good for the fans.
              i need a decent heatsink for s478 that will allow an 80mm fan to be attached. there is 100% overclocking bs available here, all the ~1kg specials.
              • stretch0069
                • Oct 2003
                • 2658
                Galvanized, your input is much appreciated. Don't assume I know anything....like Will with sex, I fake it real well.
                Yeah....the case is pretty dusty. I'm sure thats what brought this on. If I kept better house-keeping of the cases, it probably wouldn't have happened.
                Oh well.....the cost of being lazy.
                EDIT: hey Will.....where can i get an adapter, or do i need to make one?
                sorry Will.....I just can't resist a piss
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  sex....i think i remember that
                  just search for "60-80mm adapter"
                  check it is a 60mm though first.......
                  • Fizzycapola
                    • Oct 2006
                    • 423
                    Rubycon Rubycon Rubycon
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      so what is the manufacturer of the best one and where did you obtain?
                      • tazwegion
                        • Jun 2006
                        • 444
                        IIRC Akaska make/made fan adapters
                        Here's some fan adapters @ The Cooler Guys
                        Viva LA Retro!
                        • Fizzycapola
                          • Oct 2006
                          • 423
                          Make doesn't matter as much as style. The first sort I have for their lower depth only.
                          General rule for applying an adaptor onto a square heatinks is to use a square adaptor.
                          Although trimming is possible to make round more square I've done this with my old heatsink and it knocked 2oC off CPU temp.
                          Quick google found the best one for $1 here http://www.coolerexpress.com/akfanad60.html
                          All I can say is Wow! I just ordered 50 of them but had to cancel realising they don't deliver to UK.
                          I recommend ordering as many as fit in your pockets at that price lol.
                          • emil_t
                            RTX3090 working fine but fans not spinning
                            by emil_t
                            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                            04-12-2024, 06:54 AM
                          • eccerr0r
                            Shipping PCs with heavy heatsink/fans...
                            by eccerr0r
                            For people who have shipped PCs with huge heatsink/fans through UPS/USPS/Fedex... do they survive?
                            How does one ensure that the heatsink stays attached and does not rip itself off the motherboard?
                            Or do they tend to stay in place just fine?
                            04-13-2022, 11:24 PM
                          • b-slayer
                            Asus Strix-G15-G513RM fans don't work
                            by b-slayer
                            I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                            The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                            (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                            (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                            ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                            09-04-2025, 04:58 AM
                          • harp
                            Metod for removing glued heatsink from fragile component
                            by harp
                            I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                            06-23-2025, 02:01 PM
                          • johnnylotto
                            System76 partial power-on, VDD1.05 out fail
                            by johnnylotto
                            Laptop:
                            Hello, I have a System76 Gazelle laptop (model gaze14) which now only partially powers on and does not boot properly.
                            History:
                            This laptop has served me well for a few years. It's always been a bit noisy with the fans and recently became much more so on both fans, where just opening a vim/notepad session would cause the fans to spin up loudly and make a grating sound, like the ball bearing were mechanically wearing out. So after blowing the dust out of the fans out didn't help, I ordered replacement fans and heat sink component from System76 which were sold...
                            09-18-2022, 01:06 AM
