Shipping PCs with heavy heatsink/fans...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    For people who have shipped PCs with huge heatsink/fans through UPS/USPS/Fedex... do they survive?
    How does one ensure that the heatsink stays attached and does not rip itself off the motherboard?
    Or do they tend to stay in place just fine?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Shipping PCs with heavy heatsink/fans...
    Old world ones attached to the little plastic clips on ZIF sockets and some P4's were bad about breaking in transit. Things that are screwed into metal (modern stuff), I've never had a problem.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      So the stock S775 hs/f don't survive? Hmmm. wonder what it'd take to reinforce it to survive...
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        Those sinks are horrible....but the upside is they're light....they tend to stay put. I usually break them trying to remove/reinstall them.
        Team : 49813
        Join in!!
        Team Stats
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          hmm... as a HS/F the stock S775 ones seem to be nice and quiet as well as the fans seem quite long lasting - haven't had one die yet. Unlike the aftermarket ones I've dealt with...some of which are quite loud (though haven't had one of those fans yet die yet), but they have a back (or front, for the Zalman S478 to S775 retrofit) plate and actually screwed to the board. Not sure if I will have to use one of the aftermarket ones or will the stock ones survive...
          • emil_t
            RTX3090 working fine but fans not spinning
            by emil_t
            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
            04-12-2024, 06:54 AM
          • harp
            Metod for removing glued heatsink from fragile component
            by harp
            I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
            06-23-2025, 02:01 PM
          • Ven
            Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
            by Ven
            I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
            The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
            I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
            If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
            07-08-2024, 09:32 AM
          • JayPoorJay
            Hot Water Rad - A Few ECU Fans and a Timer Switch
            by JayPoorJay
            Good Afternoon, Good People.
            I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
            I REALLY would appreciate y'alls help.
            This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
            10-29-2024, 12:54 PM
          • piernov
            Core 2 "gaming" build with SLI
            by piernov
            My turn to post a build I guess, wasted way too much time on this one…
            First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
            Everything done with random parts I had lying around.
            Specs :
            • CPU: Core 2 Quad Q9450
            • RAM: 2x2GB KHX6400D2K2
            • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
            • MB: P5N-E SLI
            • PSU: Antec Basiq Power 550 Plus
            • HDD: Hitachi Ultrastar A7K2000 1TB
            • ODDs: DVD ROM, DVD RW
            • Case: not sure
            Cooling:
            • 92mm rear fan
            • 120mm front fan
            • Additional heatsink on southbridge
            05-20-2023, 11:38 AM
