I wonder why this RAM module failed
  • mariushm
    • May 2011
    • 3799
    Re: I wonder why this RAM module failed
    eBay is your friend.
    A few weeks ago, I've sold about 20 512 MB ddr1 sticks for about 5-8$ a piece if I remember correctly.
    I can buy 512MB ddr1 sticks at a local store for about 14$. 1 GB DDR1 with ECC sticks are more expensive at around 35$ at this store.
    • cheapie
      null
      • Jul 2010
      • 849
      Maybe I could ask around and see if anybody has some partially defective sticks.
      • ahmedtou
        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
        by ahmedtou
        help me please
        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
        I will share all the details with you, including the disc information.
        Code:
        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
        Current Profile: BD-R
        Disc Information:
        Status: Empty
        State of Last Session: Empty
        Erasable: No
        Free Sectors: 12,219,392
        Free Space: 25,025,314,816 bytes
        Free Time: 2715:27:17 (MM:SS:FF)
        Next
        08-27-2025, 08:49 AM
      • AlexVG
        Replacing the WiFi module on a vacuum cleaner iROBOT i7
        by AlexVG
        I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
        I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
        (This board does not respond, only the LEDs light up in a circle.
        The liquid damage is catastrophic and restoration is impractical).
        (I bought this board to get the WiFi module and camera).
        The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
        If...
        10-22-2024, 07:20 AM
      • repair-it
        TOSHIBA DLP 52HM95 How to reset timer module on bulb
        by repair-it
        I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
        Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
        10-11-2023, 07:18 PM
        Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
        So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
        The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
        You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
        09-07-2024, 07:26 PM
      • DriversScrew
        Omnitronic TUNA-NET Internet Radio - M1088 Module - any information or software?
        by DriversScrew
        I've got an Omnitronic TUNA-NET internet radio with an all in one module built around an esp32. The module must be a M1088 from ALD Ltd.
        The device shows only a white display screen pulsing every second. Seems to have some kind of boot issue. All voltages and the pcb thermal signatures look good.
        Any information about the M1088 module, schematics or firmware would be helpful....
        10-04-2025, 04:33 PM
