Sick PS'c
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Sick PS'c
    Hi All!
    I got a question here. For the past six or seven weeks I've been trying to fix my crashing problem with my "Junk" PC. She would last an hour or two on a clean install of Windows XP Pro then go into a hard lockup. Everytime after getting restarted most of the desktop icons would not execute their programs ever again. I changed the mobo and CPU....same problem, changed the PSU....same problem. Put some of my stuff including my hard drive in a Compaq. Same problem again but it took 24 hours to go down. Got pissed and bought a used Dell Optiplex GX 150 w/o a hard drive. I put mine in it, and reprogramed. She lasted about three hours before the crash. For shits and giggles I used the Western digital utillity cd and rewrote the MBR on the hard drive. The Dell has now been back up for three days and running strong. In rewrtting the MBR did I kill some sort of MBR sector virus that may have been the root cause of all these problems? Oh P.S. the drive that I use is a Western Digital WD Caviar SE WD800 Model WD800 JB. It was brand new in March! Going to see if I can get Circuit City to warranty it next weekend!
    Mark Twain
    John Paul Jones
    Rod Serling
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Sick PS'c
    looks like you found the turd that was causing all that grief!
    seems that wd drives get cranky like that just before they eat their firmware and start clicking.
    back it up now!
    might have beed wounded by that craptastic raidmax psu too.
    • federalhouse
      **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
      by federalhouse
      I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
      **Background:**
      I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
      **What I've Tried So Far:**
      1. I accessed
      08-01-2024, 07:03 PM
    • ash91
      Hp pavilion 15 not detect hard drive
      by ash91
      Hello gentelmen .... this is my first post and sorry for my bad english,
      so my proplem is my laptop keep losing hard drive even if i but the
      hard disk in the cady (the box that can replace the dvd rom with hard disk)
      when i turn the laptop on the massage that said no boot media found pop on
      the hard disk is fine and to be sure i try another hard
      i also update my bios to the last update
      the 5 volt is present on the hard connector on the motherboard
      the dvd rom work fine when i but a windows dvd in it
      also when i boot from flash...
      06-07-2023, 01:45 PM
    • madura2010
      DAY11AM6E0 hard disk drive and optical disk drive not detected
      by madura2010
      Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
      i checked the connectivity of ribbon=good communication with hard and motherboard
      changed hard disk and checked=3f0 error persist
      sata power=+5v available
      Then checked data capacitors=all good
      Then checked data lines path connectivity to pch=all good
      reflashed...
      03-12-2023, 09:09 AM
    • odie34
      Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
      by odie34
      I am a hobbyist (not a professional) so please be gentle...
      I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
      I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
      02-18-2024, 09:11 AM
    • kjchatman
      how to recover data from a western digital passport
      by kjchatman
      I was trying to recover the data from a 4tb drive that was bought last september and it stopped working after a couple months. I bought a drive of the same model with the intention of using the pcb but after swapping the firmware, it still isn't recoverable or even usable. both pcb boards will work with the new drive as long as the firmware from the new drive is used. In disk management, the size of the drive doesn't show at all. is this corrupt firmware or worse?...
      04-11-2022, 02:38 PM
