Mysterious armada problem
+ More Options
Posts
  • pentium
    • Mar 2006
    • 2778
    The other day i spotted for $10 a compaq armada 1700 laptop. When I got it home i pushed the power button....and got little response.
    You hear a pop from the speakers and two or three led's light up (including the power led) . other than that it is completely silent. Power is not applied to drives, the fan don't spin and no post. I opened the case and discovered the cmos battery had recently been replaced. It looks like the old one leaked and reached the mobo!
    I can see one small chip with corrosion on it and the odd other place on one corner and one side of the board. This system uses a built in ac adapter meaning that you just plug 120 volts into the back and the battery is pretty much perfect.
    What do you think? corrosion has caused open connections?
    Find Nedry!
    Check the Vending machines!!
  • gs3
    • Sep 2006
    • 15
    Re: Mysterious armada problem
    I don't know but, man, my monitor is kind of dark, .. please tell me your avatar is not what it appears to be.
    • arneson
      • Sep 2005
      • 1267
      It is!
      His dick has ears.
      Jim
      • Shroomie
        • Apr 2006
        • 356
        It has a whole face!
        Coming from someone with a slightly rusted network card, this isn't particularly helpful, but although that leaked battery acid probably isn't conductive, it's worth cleaning that up if you haven't. I'm not an expert, so I can't tell you where to go, really.
        You know there's something wrong when you open up a PSU and are glad to find Teapos.
        Why I don't buy cheap cases!
        • gonzo0815
          • Feb 2006
          • 1600
          Well fluids in laptops are always nothing good, and your battery fluid is highly conductive. I have recently one repaired, wich was soaked in coffee. Unfortunately my repair seems to be not perfect, as the battery woudn`t charged anymore, but his could be another issue.
          Any way, i cleaned the whole board cpu, ram everything wich was afeckted and wich i trusted to stand up against some harsch cleaning solvents (i used water and some grease cldeaning fluid) an brush.... I suggest to buy some decent elektronic cleansing foam, this is usually sold at your local elektronic shop. Or use some other fluid, wich should not be corosive (at least it should not disolve your laptop imediately ). Remove any battery and any other energy storage device (even the CMOS batery). Especially the 110V PSu contains capazitors with high voltage. After clean away the dirt whit a brush or only by the foam rinse it carefully with water and for the last rinse take some distilled water or some pure alkohol (i used some vodka....).
          The alkohol is only for faster drying, as it mix with the water especially under those mall BGA chips i think it is dryinbg a lot faster than with pure water.
          Then let it dry in a warm and not humid environment. I put it in the central heating room, always 35°c and absolutely dry air. Depending on the temp i suggest at least one or two days. If all is absolutely dry, you can try it. Rember, for this prozedure it is esentially to disassemble the device untill there are no spaces in wich the water could left withouth drying. It is some work, but this is IMBHo the only posibility. If only a small are is affekted, may be you can celan it without taking the whole thing under water.
          • pentium
            • Mar 2006
            • 2778
            Okay, When I get the time I will try cleaning it.
            Also...
            My avatar is a .gif of my stress toy.
            You squeeze it and the guy's eyes and ears pop out, just like the one nedry had on jurassic park.
            Find Nedry!
            • arneson
              • Sep 2005
              • 1267
              RRighht,
              Dick toy has ears and name is Nedry, UhHum.
              Oh, and that's a welcome from me too.
              Jim
              • gs3
                • Sep 2006
                • 15
                My monitor works fine for text but pictures are way too dark. I am not about to change it yet and I am not sure I can tinker with it to make the picture brighter. It is a HP Ergo 1280. Well, now I am spending time trying to find the schematic diagram online.... not much luck though
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  the hp ergo had blue label samsung tubes which were very short lived.
                  try turning up the screen/g2 which is the bottom pot on the flyback.
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • Zeonalbasta
                    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                    by Zeonalbasta
                    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                    09-13-2024, 01:17 PM
                  • Gibon378
                    Problem with stopping audio and video for no reason
                    by Gibon378
                    PC Specs:
                    • CPU: Ryzen 5 1600
                    • GPU: GTX 1080 Palit JetStream
                    • MOBO: ASRock ab350 PRO4
                    • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                    • PSU: XFX 650W (don't remember what model)
                    • OS SSD: ADATA SP920
                    • OS: Windows 10 21H2
                    Problem description:
                    Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                    11-19-2022, 09:41 AM
                  • perzyk23
                    Lenovo T580 - LCD Panel problem - error 0288
                    by perzyk23
                    Good morning,
                    I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                    10-25-2024, 12:42 AM
                  • SDNarcia
                    Dell 15R-5521 keyboard problem (KBC?)
                    by SDNarcia
                    Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                    As additional information,...
                    07-20-2024, 10:47 PM
