Funky USB stick problem?
  • Logistics
    • Apr 2007
    • 721
    So my Paps bought a 4-pack of Kingston DataTraveler 2.0's, years ago; 4GB ones. He finally busted out the fourth one the other day and the thing won't work.
    When he opens it it shows a blank page, when you Properties it it shows 0 used and 0 available. When you go to Format it, nothing ever comes up. I can use MBR to see it as well, but it says there's 0 space, no MBR, no partitions. HDD LLF can't even see it, and I have the version that can do USB drives, I've done it to my 1 of those 4 sticks and recovered some bad spots.
    It just acts like it has literal hardware problems; internal component failure. Never seen this happen before.
    Any ideas?
    -Jay
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Funky USB stick problem?
    That's strange....Maybe for some weird reason the disk needs to be initialized in Disk Management?
    • Logistics
      • Apr 2007
      • 721
      Disk Management sees it, but just lists it as 0 space and you can't do anything with it, can't right click on it, can't perform any actions on it. So weird.
      • japlytic
        • Oct 2005
        • 2086
        With memory cards and USB drives, there are a number of fakes going around - could that be the problem?
        • lti
          • May 2011
          • 2547
          Maybe it does.
          • Gariarto
            • Jul 2012
            • 151
            If every other flash drive works fine in the PC you're trying it in, then its reasonably safe to assume the problematic one is defective. Iti may be correct in saying its DOA.
            One thing you could do if you want to persue it, is contact Kingston and ask them for any specific software recovery tools they might share with you. I'm a Patriot man myself for preference, they have such things on request to attempt to revive problematic flash drives. Worth asking. For what a 4gb thumb drive is to them they may well just give you another !
            @ japlytic. A fake one in a pack of 4 ?
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
            • perzyk23
              Lenovo T580 - LCD Panel problem - error 0288
              by perzyk23
              Good morning,
              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
              10-25-2024, 12:42 AM
            • SDNarcia
              Dell 15R-5521 keyboard problem (KBC?)
              by SDNarcia
              Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
              As additional information,...
              07-20-2024, 10:47 PM
