PSU nearly starts fire
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProTags: None -
Re: PSU nearly starts fire
Look at the HS in the 1st pic. Ah, the the "T" HS of doom.
That must have been really flimsy metal to burn through like that. Must have had some zinc added (zinc burns... some compounds of it will burn at room temp even).
This is why I hate noobery...
I just hope the guy learns his lesson... although I think he'll buy another cheapie with a different brand name (read: overpriced ripoff) slapped on it. Lemming.Last edited by ratdude747; 11-26-2012, 11:45 PM.sigpic
(Insert witty quote here) -
I just hope the guy learns his lesson... although I think he'll buy another cheapie with a different brand name (read: overpriced ripoff) slapped on it. Lemming.Comment
I recently load tested a PSU (made by CoodMax) with those heat sinks. Once I was done killing it, I broke the heat sink into a few pieces with nothing but my bare hands.
I do find it a bit unusual that it actually caught on fire, though. I've seen lots of cheapies blow up, but I'm yet to see one actually start a fire. My pet theory is that there was some dust in there which caught fire as one of the switchers blew.Last edited by c_hegge; 11-27-2012, 04:19 AM.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
...and that look I get from people when I use old Hipro/Delta units from Dell computers... they must think i'm insane cause i'm using old parts in my new PC instead of the newest made-in-china PSU that only costs $15!!! WHAT A BARGAIN! NOT.Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - AnonymousComment
Once I was done killing it, I broke the heat sink into a few pieces with nothing but my bare hands.PeteS in CA
****************************Comment
Interesting! Was it multiple sections of extrusion that were interlocked or riveted together? Or maybe powdered metal pressed into shape like particle board? The former would have terrible heat transfer from one extruded section to another. The latter would be relatively light and probably lack the physical mass/integrity to be an effective heatsink.sigpic
(Insert witty quote here)Comment
They are stamped extrusions like any other heatsink...PeteS in CA
Were those computer parts were built to less stringent flammabililty standards? Because several years ago, someone involved in circuit board production in the Far East said they used different fiberglass resins for boards, depending on where the products would be sold, and products for the US market had to be the most fire resistant. Also a German website bought identical brand TVs around the world and burned them, and the ones for the US were the hardest to burn.Comment
Another reminder about cheap power supplies, the old saying is: you get what you pay for.
Were those computer parts were built to less stringent flammabililty standards? Because several years ago, someone involved in circuit board production in the Far East said they used different fiberglass resins for boards, depending on where the products would be sold, and products for the US market had to be the most fire resistant. Also a German website bought identical brand TVs around the world and burned them, and the ones for the US were the hardest to burn.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
by chaos-theoryI have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and... -
by jczarniakHi,
Is there available any Android Fire TV ROM backup ( Fire TV Firmware ) which I can download, save on USB stick and then load into the TV ?
I have got JVC LT-50CF810 Fire TV with firmware not working properly.
Thank you very much for any support.
Regards. -
by arabex21Hello everyone. I have been reading this forum for a long time - I really appreciate the amount of very interesting materials and information in the field of electronics.
I have a problem with this configuration:
ASUS PRIME B450M-A
RYZEN 1300X (I replaced it with ATHLON 200GE - the same behavior, the processors are functional, tested on another board)
When the entire set is installed (CPU, RAM, ATX connector and 12V 8 pin CPU plug), the board starts up for a while (about 1-2 seconds), the CPU fan starts and the board turns off immediately. When I disconnect... -
by ShobosHi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
Any help is welcome. Thanks !07-29-2025, 03:53 PM -
by IamPriteshI have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
Some very important points :
- Laptop does not auto starts after shutdown if adapter is connected.
- It will only auto start after shutdown if the laptop is in BATTERY only mode.
- I have tried replacing batteries with a known
- if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
- Loading...
