Hard Disk:Samsung SP1604N - Pcb: BF41-00076A
  • teppei
    • Aug 2012
    • 51
    • italy
    Greetings to all!
    This time I have to try to fix this Hard Disk: SAMSUNG SP1604N - PCB: BF41-00076A that has the problem that will not turn on.
    This hard drive has a component in fact destroyed that certainly does not feed properly the entire circuit .....
    I know it's an impossible task but you component is??
    on the circuit are the polarity ... so I guess it's a caps ... what do you think??
    Thank you!
  • riotpack
    • Jul 2008
    • 27
    Re: Hard Disk:Samsung SP1604N - Pcb: BF41-00076A
    i think it's a diode - I had the same thing happen when I plugged in the wrong power adapter into an external drive (swapped the +5 and +12 rails) I found one on an old 40GB drive which I soldered into place and my 1TB drive worked fine.
    Thats not a Fuhjyyu I used in your antec PSU its a HITACHI!! rofl lol lmao funni gui!
    • riotpack
      • Jul 2008
      • 27
      Have a look here - or do some research on Hard Drive TVS diodes
      http://forums.seagate.com/t5/Barracu...p/33577/page/2
      • teppei
        • Aug 2012
        • 51
        • italy
        Riotpack, thanks for your answer ..... but I think we are close to solving the problem as they are able to get a picture of the offending part!!
        Of that component's this??
        Thank you all!
          master hoarder
          • May 2008
          • 12175
          Either a capacitor for extra filtering or a diode for protection. The drive will likely work without it, regardless of which of these it is.
          First thing to do is to remove it. Next, check what each pad on the board for this component is connected to. If one pad is ground and the other is 5V or 12V, then it's likely either a capacitor or a diode as I mentioned above - in which case the drive will work fine without it.
          • teppei
            • Aug 2012
            • 51
            • italy
            I thank everyone for their cooperation, but I decided to restitutire the'' hd to their rightful owner because I do not live together even the operation of the head, in order to prevent further damage.
            thanks
            • federalhouse
              **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
              by federalhouse
              I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
              **Background:**
              I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
              **What I've Tried So Far:**
              1. I accessed
              08-01-2024, 07:03 PM
            • Alimash
              op amp circuit function?
              by Alimash
              I am repairing a ups which doesn't turn on ,it has the following ICs:
              SG3525 used to drive inverter mosfets.
              couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
              A LM358 and TL074 for control mechanism and of course the uController.
              The SG3525 is shutting down every time the ups is turned on.
              I want your help to know the function of LM358 and TL074 in the system.
              I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
              07-31-2025, 07:45 AM
            • Astonished
              Fixing the Charge Circuit of the Batteries of the DC Motor
              by Astonished
              Hi friends of electronics
              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
              Please help me fix this circuit.
              (the datasheet of the IC: https://pdf.datasheet.live/28...
              01-28-2025, 06:24 AM
            • rddube
              Lenovo L490 Ram voltage circuit malfunction
              by rddube
              Hello friends,
              Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
              I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
              07-15-2025, 04:41 PM
            • ash91
              Hp pavilion 15 not detect hard drive
              by ash91
              Hello gentelmen .... this is my first post and sorry for my bad english,
              so my proplem is my laptop keep losing hard drive even if i but the
              hard disk in the cady (the box that can replace the dvd rom with hard disk)
              when i turn the laptop on the massage that said no boot media found pop on
              the hard disk is fine and to be sure i try another hard
              i also update my bios to the last update
              the 5 volt is present on the hard connector on the motherboard
              the dvd rom work fine when i but a windows dvd in it
              also when i boot from flash...
              06-07-2023, 01:45 PM
