virtualbox crashing the host HDD need help with it.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    on my Linux laptop when i start a sun-virtualbox VM my host HDD goes all wonky and starts crashing the heads, but without one running its fine. can you help me?
    Follow the white rabbit.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: virtualbox crashing the host HDD need help with it.
    Check the logs, see what it says.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      which log? kernel/vbox/SMART/USB/VM/RAID/disk management?
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        What do you have for distro?
        uname -a: ?
        What virtualbox version do you have?
        Any log that has information related to your problem.
        We do have a code function on this forum.
        [CODE] [/CODE]
        Also sun was bought out by oracle.
        • Time2Retire
          • Aug 2012
          • 256
          In whatever directory you have the VM image saved, you will also find a folder named "Logs". That may be what you are looking for.
          Also, if you start virtualbox from a terminal window, you can invoke options such as "debug". Here is a list of those options:
          Code:
          $ virtualbox --help
          Oracle VM VirtualBox Manager 4.1.14
          (C) 2005-2012 Oracle Corporation
          All rights reserved.
          Usage:
           --startvm <vmname|UUID>  start a VM by specifying its UUID or name
           --seamless         switch to seamless mode during startup
           --fullscreen        switch to fullscreen mode during startup
           --rmode sdl|image     select different render mode (default is sdl)
           --no-startvm-errormsgbox  do not show a message box for VM start errors
           --dbg           enable the GUI debug menu
           --debug          like --dbg and show debug windows at VM startup
           --debug-command-line    like --dbg and show command line window at VM startup
           --debug-statistics     like --dbg and show statistics window at VM startup
           --no-debug         disable the GUI debug menu and debug windows
           --start-paused       start the VM in the paused state
           --start-running      start the VM running (for overriding --debug*)
          Expert options:
           --disable-patm       disable code patching (ignored by AMD-V/VT-x)
           --disable-csam       disable code scanning (ignored by AMD-V/VT-x)
           --recompile-supervisor   recompiled execution of supervisor code (*)
           --recompile-user      recompiled execution of user code (*)
           --recompile-all      recompiled execution of all code, with disabled
                         code patching and scanning
           (*) For AMD-V/VT-x setups the effect is --recompile-all.
          The following environment variables are evaluated:
           VBOX_GUI_DBG_ENABLED    enable the GUI debug menu if set
           VBOX_GUI_DBG_AUTO_SHOW   show debug windows at VM startup
           VBOX_GUI_NO_DEBUGGER    disable the GUI debug menu and debug windows
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            here is the logs. i think i found somthing on vbox.log.3 in the cpu-dbg. but it cold be it using the host I/O cach so im stumped!
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              I'm not seeing much, the only thing that peak my interest was this:
              Code:
              00:00:02.782120 DrvBlock: Flushes will be ignored
              00:00:02.782187 DrvBlock: Async flushes will be passed to the disk
              00:00:02.782250 DrvBlock: Flushes will be ignored
              00:00:02.782278 DrvBlock: Async flushes will be passed to the disk
              00:00:02.783352 DrvBlock: Flushes will be ignored
              00:00:02.783407 DrvBlock: Async flushes will be passed to the disk
              Basically write-back mode caching, so you shouldn't be having "HDD goes all wonky."
              The other thing is, PAE is enabled and you only allocated 768MB of ram to your windows VM. It's not a bad thing, you could disable it to run a 32bit VM and see if that has any effect.
              Also why 768MB of ram?
              Virtual-box is not throwing errors, so we need to go to the other logs and see why your HDD is going nuts? check messages or syslog in "/var/log/".
              • Zilicon
                Please, help: HP Elitebook 1030 G2 keeps crashing and turning on automatically
                by Zilicon
                i've been working on the above PC for some time now, but the fault remains unsolved.
                Behavior:
                less than 2 weeks after the battery and keyboard of the pc were changed, the pc started crashing and restarting on its own. it keeps doing that at approximately an hour intervals, at times, it becomes shorter than that.
                When it crashed, there was no BSOD of any kind; the power button did not misbehave; the pc did not overheat either.
                what I have done:
                cleaned the ME of the BIOS firmware, changed the thermal paste, removed all peripheral devices- (keyboard,...
                11-03-2025, 10:31 AM
              • corbyn
                MSI Modern 15 B7M - MS14-JK1 (14JK1) - Intermittent Crashing - iGPU?
                by corbyn
                Hey all,
                This laptop came in with hard resetting crashing, not even blue screening after a few minutes on the desktop, same result with Linux Mint.
                Strangely it seems stable plugged in on compatibility mode (nomodeset llvmpipe) which tells me I think the AMD Ryzen 7530u Radeon iGPU is cooked, but it also points to something strange with the buck converters or VRMs maybe.
                Inspecting the board under the scope there's nothing obvious.
                Crashes on charger and battery in iGPU Radeon drivers
                Crashes on battery in no driver mode
                Seemingly Stable in charger and...
                05-01-2025, 08:04 PM
              • ivtec
                install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
                by ivtec
                Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
                01-17-2025, 12:54 PM
              • survivalbloke
                Xbox Series X - crashing to dashboard shortly after launching games
                by survivalbloke
                Hey all! I've got a XBOX Series X which came in with the complaint of games crashing to the dashboard after launch. I've tested a few games so far. Red Dead Redemption I observed will load up fine and sit on the menu no problem, but once I actually load into the world, it will not complete the load-in, and crash, stating something about an error must be sent to Rockstar, etc.. Truck simulator seemed to work fine. Minecraft loaded up and zoned into a world, but within a few seconds, it too, crashed to the dashboard. Where are the logs stored? What should I check?​
                09-18-2024, 11:54 AM
              • Rimeyrep
                Acer Nitro 5 AN515-55 - Undetected Battery + Crashing under heavier load
                by Rimeyrep
                Board: Compal LA-J891P rev.1.0B
                Battery not detected
                Working only with AC adapter plugged in
                What happened:
                Notebook crashed under load randomly. After several crashes throughout the week (after each crash it got worse and worse meaning crashes were happening more often) i found out it works just fine not plugged in AC charger only powered by battery so i was using it that way until battery was drained to 5%. When i plugged AC charger in battery wasn't charging so i restarted the machine...
                05-16-2023, 02:48 PM
