AMD inside Dell desktops
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Dylan McGrath
    EE Times
    (08/17/2006 6:51 PM EDT)
    SAN FRANCISCO — Three months after finally acknowledging that it would roll out new servers based on microprocessors from Advanced Micro Devices Inc. (AMD), Dell said Thursday (Aug. 17) will launch its first desktop computers with AMD processors in September.
    Dell (Austin, Texas) said it would launch Dimension desktop computers with AMD processors next month and will introduce a two-socket and multi-processor server using AMD Opteron processors by the end of the year.
    The embrace of AMD chips in the world's No. 1 PC vendor's desktop systems deals a further blow to Intel Corp., which had been essentially the exclusive supplier of microprocessors to Dell until the May, when, following months of speculation, Dell said it would roll out new servers based AMD's Opteron line of 64-bit processors by the end of this year.
    PeteS in CA
  • arneson
    • Sep 2005
    • 1267
    Re: AMD inside Dell desktops
    Would that be the 11th Dimension?
    Must have a more creative name for a new machine.
    Jim
    • Shroomie
      • Apr 2006
      • 356
      Hey, even XPS is recycled...ironically, from old Pentium IIs.
      What gets me is that before, Intel had an inefficient processor that put out a LOT of heat without the performance to match. Now that Intel's released a truly competitive product, we're offered a choice. Go figure...
      You know there's something wrong when you open up a PSU and are glad to find Teapos.
      Why I don't buy cheap cases!
      • tiresias
        • Feb 2006
        • 489
        Indeed - how old is that "Dimension" brand name anyway?
        My first "real", "very own", computer was a Dell Dimension XP, with a fearsome 80486 CPU @ 66MHz. And that was when I turned 14 in 1993.
        • arneson
          • Sep 2005
          • 1267
          A small dose of drivel,
          Let us see, 14 carry the 93 add the 06 and 2 = 1 so, your not even 30 yet!
          I am a lot older than heat sink dust.
          Jim
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
          • F R 2568
            Dell Latitude 5420 does not start (no post) need help to find the reason why
            by F R 2568
            Hello all,
            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
            If the laptop is only connected to the AC adapter (battery removed):
            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
            The power/battery...
            01-08-2025, 05:45 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • lalle-
            Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
            by lalle-
            Hello!
            I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
            [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
            I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
            The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
            I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
            08-11-2024, 02:01 PM
