The hard drive failure thread
    replied
    Re: The hard drive failure thread
    Originally posted by eccerr0r
    I also got a used laptop disk from Microcenter with a lot of miles on it. This time it's not POH but rather hundreds of thousands of load/unload cycles. The drive apparently was in a machine that was turned on and off frequently and the SMART rating for this has dropped considerably (I think it's in the 30s where threshold is 0). Likewise it is still working, but who knows when it will fail.
    What model drive was this? I know the WD Greens will rack up an amazing amount of those. My old (but trusty?) Hitachi DK23EA-20 also does - you can hear it click like every 5 to 10 seconds if the HDD is idle.
    Load/unload cycles is not the same as power cycle counts, though.
    Power cycle counts is for how many times the power was cycled ON and OFF.
    Load/unload cycle count is *usually* for the number of times the heads have parked (which for some drives is the same as the PCC above, if the HDD parks its heads only when OFF). High load/unload cycle count is (again, usually) only bad for drives with head ramps.
  • eccerr0r
    replied
    Originally posted by fzabkar
    MTBF is not what you think it is. It is not telling you how long the manufacturer reckons an individual drive will last on average. Rather, it is telling you the average time between failures in a large population of drives.
    So much for pedantic replies, but the claim is still true for this single 10 year old drive - it is still a craps shoot and could fail any time as it already has likely gone through at least 7 of its 9 lives. If the MTBF rating was 2M hours, then statistical failure is farther away. It still could die tomorrow, after the buyer hooks up +12V to +5V.
    BTW I see nothing wrong in selling a drive with 70K hours provided that the buyer is made aware of this. Just attach the SMART report. In any case some buyers might want the drive just for the PCB.
    Why do eBayers need to advertise this when Microcenter does not? I'd think that if asked, this data should be supplied (barring "but I don't have the tool, I don't run Linux, I don't trust freeware SMART tools...") - but if not asked, there's no reason to post it, just like Microcenter.
  • mariushm
    replied
    I have four drives in my system right now. I had more drives but I gave them away (a 250 GB Seagate and a 400 GB WD Black) while they were still working fine.
    The Seagate is the only one I had back luck with, quite a few of bad sectors but luckily they're isolated to a region of about 20-30 GB, so I just created a partition for that area and left it unformatted.
    The WD 1TB Green just recently developed a few sectors according to SMART data, but it works perfectly fine. With the Seagate, the drive was noticeably slower when writing data to that region with bad sectors.
    I just love my Hitachi NAS 4TB drive, behaves and works wonderfully so far. I think it's worth paying extra over drives like WD Green but while I wouldn't mind still buying WD Green, I'm staying away from Seagate or WD purple or other non-NAS drives. (even though i don't use them in raid or a nas box).
    I keep my computer running 24/7, basically restarting it only when antivirus pushes me to reboot or I accidentally install some Windows updates.
    For a drive that ran 42980 hours (1790 days or 4y 330 days), i really don't mind that i may soon have to retire it (or change its role to storing music or tv shows i don't care if they get corrupted or lost)
    The Seagate doesn't have the same excuse, yeah it's close to 40k hours but it developed bad sectors months after warranty was over (2 years), not just now like the WD.
  • diif
    replied
    You're right momaka, i got confused between the two. i'm blaming agonising shoulder pain for my oversight.
    replied
    Originally posted by ChaosLegionnaire
    thats really not very nice esp from an ebay seller! selling off a drive that is about to hit the 100k hour mtbf! u'd think they'd be transparent and post smart screenshots of the drive to inform potential buyers...
    That wasn't from an eBay seller. I got the HDD from MicroCenter. Either way, it was cheap and it works so I can't complain (I paid $5 or $6 for it).
    Toshiba acquired some of Hitachi's storage technology. In particular, some of Toshiba's 3.5" models are really Hitachis.
    Good to know.
    Probably why their 3.5" models may have less problems then. I still wouldn't trust them, though. If you get a drive that is made by Toshiba and not Hitachi... good luck with your data!
  • fzabkar
    replied
    But if it clearly says "USED" is it really that incorrect of an advertisement? Just so happens to be well-used... Then again 100K hours POH != MTBF... I think most of these drives are in the 300K-500K hour MTBF, but all that means that it's nearing failure time
    For example, let's say the MTBF is 500K hours and that you have a datacentre with 1000 drives. In this case you can expect that there will be, on average, one failure every 500 hours. If you had 10,000 drives, then the failure interval would be 50 hours. Note that this MTBF spec applies only to new drives. This means that the MTBF may fall to 250K hours by the second year, and 50K hours by the 5th year.
    Edit:
    Notice that the raw value of Power-On Hours for the Toshiba HDD is 3085, and that the normalised value has dropped from 100 to 93. This means that the drive has lost 7 points in racking up those hours. It may have just recently lost the 7th point, or it may be just about to lose the 8th point.
    This means that we can calculate how many hours the drive will have logged by the time it loses all 100 points.
    Expected Lifetime is less than or equal to (3085 hours / 7) x 100 = 5.03 years
    ... and greater than or equal to (3085 hours / 8) x 100 = 4.4 years
  • eccerr0r
    replied
    But if it clearly says "USED" is it really that incorrect of an advertisement? Just so happens to be well-used... Then again 100K hours POH != MTBF... I think most of these drives are in the 300K-500K hour MTBF, but all that means that it's nearing failure time (But anyway, this is worse, Microcenter selling a clearly marked "used" 100K hour drive versus buying a 100K hour drive on eBay?)
    I guess my drives are similar, I have two that are around ~70K POH. One has 300 and other one probably has 1100 power cycles on them, both have zero reallocated and zero bad sectors. I have two others from that RAID5 that are a bit younger as I grew my array, but one of them has two reallocated sectors on it.
    Should I "trust" this brand of hard drive with 70K POH? Even though I had to RMA one of them (massive bad sectors)? Hard to say. (Brand = Maxtor, bought out by Seagate.)
    My current array has HGST drives in it, a 500G. I even had to RMA one of these too (it stopped detecting too!!!) Luckily it was a RAID5 member and no data loss.
    I'm still trying to test out the 2T disks that will replace the 500G/disk array. We'll see if these 500G disks hit the 70K hour mark before I swap them out, they still have thousands of hours to go...
  • fzabkar
    replied
  • ChaosLegionnaire
    replied
    Originally posted by lti
    Toshiba drives suck. I'm surprised that my laptop's Toshiba drive hasn't failed yet. It's three years old.
    same. my mom has a three to four year old sony vaio laptop with a toshiba 640gb drive in it. surprised its still running with no reallocated sectors last i checked several months ago.
    Originally posted by momaka
    I did buy an 120 GB IBM ICA-something model (I think) from MicroCenter. Turns out, it had nearly 100k power-ON hours (995xx to be exact), but ZERO bad and reallocated sectors, and only like 20 or 30 power cycle counts. I checked the time counter to make sure that it counts in hours and not minutes (beware that some older 2.5" Hitachi HDDs did do that) - but no, it does count in hours. I thought I saved the SMART log somewhere on my main PC here, but I guess I didn't. Anyways, the computer in which I put that IBM HDD in is used maybe once a year or so for a few weeks. So it will probably be a few years before it gets to 100k hours. Still, I call that reliable!
    replied
    Originally posted by Compgeke
    Anyone ever had good luck to Toshiba? I've come around to using the name Toshita, I've never had a Toshiba drive last more than 2 years of use, even if it's a stationary laptop.
    Me neither.
    When I used to work in a electronics repair shop, laptops and PS3s with failed Toshita HDDs were common sight. I think I still have a dozen of them in a box somewhere in my closet. Mostly 120 GB to 1 TB. I don't think any of them had more than 5000 power-on hours.
    Originally posted by diif
    I know Backblaze rate the Toshiba above other drives.
    Where did you get that from their article? If anything, HGST (Hitachi) is the one getting praised.
    I've also had nothing but good luck with Hitachi myself. Heck, even their old IBM "Deathstars" (prior to the Hitachi-IBM merger) were more reliable than the aforementioned Toshita HDDs. I can probably pinpoint only two specific models/lines that are problematic: the DTLA-3070xx line (IBM) and DK23AA-12B model (Hitachi). That last one should not be mistaken with the DK23EA-20 model, which is actually reliable too. Go figure.
    And I wonder if anyone would take their chances with a 70K POH drive on eBay
    Maybe not from eBay
  • lti
    replied
  • ChaosLegionnaire
    replied
    last week one of my beloved and no longer being produced hitachi p7k500 500gb ide drives died... literally.
    was copying some files over and went afk for an hour. came back and tried to copy more files but the drive started clicking and froze the system. hit the hard reset button. drive could no longer be detected by bios. tried power cycling the drive. bad idea and even worse epic phail! drive wouldnt spin up and still cannot be detected.
    i thought it might be a stiction problem as its used infrequently for backup. i tried taking it out and spinning it left and right horizontally while holding it in one hand. no dice. still wont spin up. gonna have to try the exotic freezer trick some time later when i have the time... oh my data... 500gb!
    this is the first time ever i got a completely dead undetectable drive. previous failing drives i've had would still be detectable once i leave them running enuff and they give up and come out of error recovery mode and come back online again thus i could proceed with data recovery. not this one... i hope i didnt kill the drive dead when i power cycled it while it was clicking...
    also got another two hitachi 7k3000 hds723020bla642 2tb failing. one has 105 reallocated sectors, 1 pending sector and 1 offline uncorrectable. the other has smart failure due to seek error rate failure. that seek errored drive is purchased second hand. i think it must have had a drop in the past based on previous experience in this forum with another guy who dropped his seagate drive.
    damn i thought hitachis were the most reliable... i've hoarded like 6 of those drives due to their legacy format 512b sectors as im sticking to winxp. sad to see 2 or one third of them fail after 3 years. now i'm forced to buy into this advanced format bs since none of the drives being sold in my country now are legacy format.
    some Advanced Format drives report the Reallocated LBA Count rather than the Reallocated Sector Count, ie a logical sector count instead of a physical sector count. The actual number of reallocated physical sectors is obtained by dividing the logical sectors by 8. The numbers 11056 and 2008 are both divisible by 8 ...
    thats why i hate that advanced format bs. if u have a bad sector on an AF drive, i can twist my words and say that advanced format drives cause 8 times as much data loss when a bad sector occurs compared with legacy format.
  • fzabkar
    replied
    That being said I wonder if the raw number is actually the wrong endian, wrong bit order, or even if there are sub bit fields in that number. You can't necessarily trust the number in "raw value" because it is manufacturer (and model) specific. The only numbers that you can trust is making sure the VALUE number is greater than THRESH; the only other indication is if VALUE has decreased since it was new. Note that this number for VALUE can go up and down so it's really hard to tell what's the disk lying about... Then again there are a lot of pending reallocates...
    I've seen a LOT of SMART bugs. ISTM that the Toshiba drive's raw Reallocated Sector Count is correct, but the normalised values are telling lies. That said, some Advanced Format drives report the Reallocated LBA Count rather than the Reallocated Sector Count, ie a logical sector count instead of a physical sector count. The actual number of reallocated physical sectors is obtained by dividing the logical sectors by 8. The numbers 11056 and 2008 are both divisible by 8 ...
  • eccerr0r
    replied
    Wow that was an old post of mine, must have been my 120G disks for my old RAID... I've since decommissioned that RAID but the drives were still working just fine when I took it apart.
    Oh well, I guess it won't hit 100K hours unless I decide to use the disk somewhere else... And I wonder if anyone would take their chances with a 70K POH drive on eBay
    Toshiba MK3275GSX, failed from bad sectors. Made on Feb 29th, 2012. Surprised the thing even let me load Windows, with 11,000 reallocated sectors.
    I've actually had decent luck with Toshiba disks. The old ones are slower than the "usual brands" but haven't had one fail as I simply haven't had many of them. The other brands I've had failures on pretty much all of them as I've went through more of them.
  • fzabkar
    replied
    So, it's still working.
    Exactly what do you mean? Are you suggesting that a drive with a shorted TVS diode will still function? Or do you believe that an open TVS diode (I've never seen this BTW) will somehow affect the drive's performance?
  • RJARRRPCGP
    replied
    Impossible. The drive is still working.
  • fzabkar
    replied
    The data recovery professionals favour Toshiba and Hitachi drives at the moment. Seagate's 2TB and 3TB DM drives are at the bottom of the heap, although their 4TB drives appear to be good.
  • fzabkar
    replied
    Sounds like maybe a failed diode on the HDD board.....
  • RJARRRPCGP
    replied
    After a power outage and a few hours of operation, my 70K-hour drive appeared to have kicked the bucket
    Still not 100% convinced it's dead but it it just got kicked from the RAID array for I/O errors. Though I have had this happen before due to a bad cable...
  • diif
    replied
    I know Backblaze rate the Toshiba above other drives. https://www.backblaze.com/blog/best-hard-drive/
    Drives tend to fail more in laptops than desktops due to the bumps they get. An ideal time to upgrade to an SSD, for speed and reliability.
  • federalhouse
    **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
    by federalhouse
    I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
    **Background:**
    I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
    **What I've Tried So Far:**
    1. I accessed
    08-01-2024, 07:03 PM
  • tmcw
    PC case - Hard drive rails
    by tmcw
    A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
    So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
    I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
    Now, the case is a CiT Gaming Case, and...
    05-22-2022, 12:04 PM
  • reformatt
    Intel iMacs, 3rd party SSD failures and Fusion setups
    by reformatt
    I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
    As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
    So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
    12-18-2024, 10:34 PM
  • madura2010
    DAY11AM6E0 hard disk drive and optical disk drive not detected
    by madura2010
    Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
    i checked the connectivity of ribbon=good communication with hard and motherboard
    changed hard disk and checked=3f0 error persist
    sata power=+5v available
    Then checked data capacitors=all good
    Then checked data lines path connectivity to pch=all good
    reflashed...
    03-12-2023, 09:09 AM
  • ash91
    Hp pavilion 15 not detect hard drive
    by ash91
    Hello gentelmen .... this is my first post and sorry for my bad english,
    so my proplem is my laptop keep losing hard drive even if i but the
    hard disk in the cady (the box that can replace the dvd rom with hard disk)
    when i turn the laptop on the massage that said no boot media found pop on
    the hard disk is fine and to be sure i try another hard
    i also update my bios to the last update
    the 5 volt is present on the hard connector on the motherboard
    the dvd rom work fine when i but a windows dvd in it
    also when i boot from flash...
    06-07-2023, 01:45 PM
