Kid killed while working on computer
  • Phaihn
    • Jan 2009
    • 842
    Re: Kid killed while working on computer
    thats a load of bull if a psu only costed $20 id buy one. i cant even get a used one for less then $50.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      You can get new ones for $10... They may be a gutless powmax with LED fans though...
      sigpic
      (Insert witty quote here)
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        I think there is a chance the PSU was so fucked up it kept a charge that was waaaay too high and didn't discharge it. Ether way, I've worked on computers with them plugged in and on.
        I can't see how a 'burn' can kill. I bet he got burnt and died otherwise. A single "burn" would indicate the electricity would not move across his chest to actually cause arrhythmia.
        • Phaihn
          • Jan 2009
          • 842
          well in my town and even if i ordered something online the shipping would kill off any savings.
          My Computer.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5085
            • New Zealand
            May be? Certainly would be
            -David VanHorn
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              #26
              There are allot of errors in this video, but at the same time I think you guys are playing it down too much aswell.
              Sure a working bleeder resistor will discharge the primaries in less than the time it takes you to disassemble the PSU, but if those are not working then it can surely hold a charge for several hours.
              And they where afterall talking about $20 crap powersupplies so who knows if it even had a bleeder resistor to begin with, I bought a charger on eBay for an old camera, no point in shelling out $$$ for it because the camera is very old anyways.
              The damn thing did not have bleeder resistors or protection diodes on the primary inputs.
              When I disconnected it from the wall I accidentally touched the power cord and got zapped by the cord plugs, like wtf China!?
              As for the electrical burns I am highly skeptical that is the reason, a burn is created when power enters and leaves the body at points in close proximity, I have an old electrical burn on my right underarm, from accidentally touching a live heatsink in a powersupply when measuring it with a multimeter.
              Sure that was not so nice but then again not that bad that it even scared me much.
              What once scared me and I am sure could have killed me was when I was holding a PSU by it's chassis and touched it's heatsink to see if it was hot, little did I know that the heatsink was live so current passed into my left arm and out of the right arm directly to a perfect ground.
              Let me tell you this was a very very scary feeling, I could feel the electricity in my collarbones, thankfully the electricity took that path instead of via my heart... But my point is that this shock did not leave any permanent visible marks...
              So is the story possible?
              Well sure he could have a weak heart or some other condition where it would be enough with the charge held by the primary capacitors to kill him if their bleeder resistors where broken or not installed.
              It is more likely though as others said that the PSU actually was plugged in while he where working on it and when he got shocked he pulled the PSU with him as he fell to the floor thus unplugging it.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                I agree. The PSU was probably plugged in the outlet.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • MMH3
                  Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                  by MMH3
                  i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                  Never ever i experienced problems with that.
                  Now i have one 5050sff machine, where this jumper isnt working at all.
                  I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                  The history of the machine is that i used it in my office...
                  03-23-2025, 09:28 PM
                • DynaxSC
                  GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                  by DynaxSC
                  I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                  There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                  The board is generally working now, all PCIe ports are working, Windows installs normally.
                  However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                  The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                  03-10-2025, 12:27 PM
                • obelix24
                  Macbook Air 2020 (a2179) - touch id not working
                  by obelix24
                  Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                  I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                  02-09-2025, 12:57 PM
                • hopkok
                  Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                  by hopkok
                  Hi masters, I need your help.
                  I am working on Lenovo Legion 16ITHg6
                  Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                  INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                  My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                  AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                  Power LED is not working as well, power button working well.
                  UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                  Motherboard...
                  05-04-2025, 09:35 AM
                • bociub
                  laptop freezes, usb 2.0 not working, usb 3.0 working
                  by bociub
                  Hi there,
                  It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
                  Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
                  08-25-2024, 03:44 PM
