no bad sounds from harddisk.i connect via exteranal.. but not showing drivers
my 5oo harddisk not decteting
Re: my 5oo harddisk not decteting
What do you mean by external? You are connecting the drive using a USB cable?
Is this a laptop or desktop?
If it's a desktop and it's a bare drive, much better to test it by opening the machine and hooking it up to a sata cable. Remember to connect the power to the drive too.
by KYBOSHI picked this one up today.
Previous owner says no signs of life.
TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
The TV model is QN65LS03BAFXZA - version: CB06
The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
Will keep you all... -
by An-klammHello!
I have a TV that I can't get any further with.
It is a Samsung UE 55HU8590 with one connect box.
When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
Since the TV works without ocb, I assume that it can't be the PSU?!
I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
Is there... -
by japlyticIn a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
Tried (only with keyboard/mouse connected):- BIOS + database update
- Using latest Windows 11 image built with official image creation tool
- Previous setup version for Windows 11 installer
- Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
- TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
- Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
06-19-2025, 04:59 PM -
by Track4207Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
What happens:- TV appears to operate normally, for an indefinite amount of time until a problem image appears
- The problem image is displayed very briefly, then the
by RudolflHi all
This is an all-in-one machine. Power supply OK.
I can turn it on, but PC part does not start. Monitor turns on and goes into standby. There is a button that control video input to the monitor. Button is on the main board. When pressed, I can see selection on screen. If I switch into "cast mode", I am getting display showing QR code to connect. So, monitor works, power works, some functionality on main board work as well. I am not sure if it uses main CPU or a controller on board for this sort of things.
Fans are starting, CPU heatsink gets warm.... - Loading...
