The Great Capacitor Showdown - Rubycon vs Panasonic vs Samxon
    Re: The Great Capacitor Showdown - Rubycon vs Panasonic vs Samxon
    on psus with disastrously bad caps...
      Originally posted by Cubes
      Would it have been possibly quicker to obtain results by recapping a few PSU's with the above caps?
      Perhaps but this test is aimed presumably at motherboard capacitor installations...
      Glad to see the SamXon's still going strong, the ones I used to rebuild my Antec TP380 back in 07-25-2006 are still going strong with 24/7 use
      Viva LA Retro!
        My guess is that Rubycon will take it in the long run , while Panasonic will edge out Samxon. I think that if you could place some ENYA's in the testing after Nichicon's you would have a good basis for reference , while Sanyo could come in to compare or exceed at long last as a good example.
        I have come across some Stone caps I think might compete well if you get the chance.
        Great test , but on older boards failure is not an option , with what appears to only be a 2 x AGP video card application. I'd like to see at least the newer 8 x AGP cards push the processor to it's heights and the reading thereof.
        Update : I pulled the Sanyo's off of my old 266mhz EPOX ( EP-61LXA-M ) , it has the same video card slot as your test boards but will be fitted with Rubycon's to see that it gets the best before deciding where to stop pushing it. This EPOX is a much smaller board and would probably make an ideal testbed for heat and failure testing. Problem is it is "rock solid" and the caps required extreme heat to be removed like I almost needed to cut the board or use a torch to get them off. Everything on this board is all the same , throw it at the wall , and I'll bet it would still work fine due to it's apparent thickness or stiffness.
          We lost teh sanyo box to a lightning strike. The others are still going, nobody has degraded so far.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
            I don't think the existing caps would degrade, since they are older computers that don't push the caps to their limits (like a P4 or newer motherboard).
            How about stop the test and announce the simple outcome, it'll be 20 some years or more before one cap in one of those systems decides to pop.
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
              Originally posted by Topcat
              We lost a system today. The Sanyo system is out of the mix.
              how many times you lost that sanyo?
                Two
                Mann-Made Global Warming.
                - Dr Seuss
                  killed twice.
                  overkill!
                    I was just playing CountCAPula.
                    If your kids never watched Sesame Street you won't understand.
                    - Dr Seuss
                      Pcbonez, yea and hehehe. The old Sesame Street is excellent, the new version meh.
                      Cheers, Wizard
                        obviously it was mentioned twice. brilliant deduction!
                        Team : 49813
                        Join in!!
                        Team Stats
                          >killed twice.
                          overkill!
                          LOL!
                            bump
                            is the test still going or have we decided they all rock?
                            sigpic
                            (Insert witty quote here)
                              I'm actually leaning more toward Sanyo WG's over Nichicon's. I don't have a source for them though....
                              www.bdent.com
                                Sanyos probably died on their own. Most likely why Sanyo bowed out of the aluminum electrolytic business. Good luck selling garbage Sun caps Jim W.
                                  Any proof?
                                    i have seen only a very few failed sanyo's.and i figured they died due to heat as the system had 3 bad fans.
                                    tc's sanyo test boxes died of lightning strike/surge.
                                    cant blame the caps.
                                      Was the box with the Sanyos on a separate circuit that the other machines? Most of the Sanyos I have seen have been dead. I haven't seen too many machines with those that still worked so I have avoided them and assumed that's why Sanyo was focusing on POSCAP and OS-CONs and dumping the lytics on Sun.
                                        Sanyo have always been as good as Rubycon, possibly better.
                                        Too bad you didn't read the PDF you posted.
                                        Sanyo sold the lytics branch to Sun ,,, who is the Sanyo subsidiary that has been the ACTUAL MANUFACTURER of Sanyo lytics for ages.
                                        They will be manufactured by the same people in the same facility they always were. - The only thing that's changed is the name on the sleeve.
                                        - Dr Seuss
                                          What's the status of the systems now?
