DVI-D to HDMI home made lead??
  • gilly1984
    • Jun 2012
    • 751
    As the title says, will i be able to make one?
    I have a dvi-d lead and a spare hdmi lead.
    I only ask because i want to connect a pc to my tv but dont have a spare vga cable.
    Thanks.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: DVI-D to HDMI home made lead??
    c/p
    All you need is the DVI cable and blank HDMI connector.
    The schematic for DVI and HMDI is found here: http://www.networktechinc.com/technote.html
    Make all the TDMS and DDC connections and the VDC and gnd and you are good to go.
    • gilly1984
      • Jun 2012
      • 751
      Originally posted by t.j.
      c/p
      I'm halfway there. The cheapo hdmi i am using that i have sliced up is strange.
      All the wires are different than they should be, I'm guessing the tdms wires should be the shielded wires but they are not, its like they just stuck any wire anywhere? Me and my New Cheapo DMM have mapped all the wires out, just need to map the DVI-D wires out so i can connect them together.
      Do i connect them all up to the same wires or reverse them like when making a crossover cable out of an ethernet?
      • t.j.
        • Apr 2010
        • 383
        • canada
        from what i have read straight conect pin for pin, no reverse! so take dmm an match pin to wire, mark them an connect! placement has to be the same as it is universal!
        • severach
          • Aug 2007
          • 1055
          Why are we making a cable that factories are pounding out every day for next to nothing? A DVI to HDMI cable is readily available.
          sig files are for morons
          • gilly1984
            • Jun 2012
            • 751
            Because i like to make things.
            It didnt work so i will just buy one.
              master hoarder
              • May 2008
              • 12170
              Knowledge? Fun? Seeing if it can be done by yourself? Nothing better to do on a rainy day?
              All are good reasons if you ask me. Yes I can get a cheapo cable from China for under $1, but if I have all of the parts and I'm curious, why not, right?
              • aliougm
                Marantz SR4003 AVR HDMI board issue, seeking for help
                by aliougm
                I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                Connection as below:
                Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                If I bypassed AVR then HDTV screen color be good.
                I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                I replaced all...
                04-30-2022, 12:21 PM
              • japlytic
                Certain DisplayPort-HDMI cables can disable HDMI CEC communication
                by japlytic
                With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
                An examination of the HDMI CEC wiring...
                07-10-2022, 09:48 PM
              • spleenharvester
                Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
                by spleenharvester
                I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
                I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
                03-12-2025, 03:42 PM
              • RossMoodley1967
                LG LCD TV HDMI PORT FAULTY
                by RossMoodley1967
                LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
                02-28-2024, 08:38 AM
              • RatherLoopy
                Pioneer VSX-44 receiver HDMI dropouts
                by RatherLoopy
                I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                05-26-2023, 03:54 PM
