Basic question regarding PWM-controlled fan headers
  • tiresias
    • Feb 2006
    • 489
    Dear Sirs,
    Some background info:
    I have recently gained possession of a number of fantastic Sanyo Denki fans (by courtesy of our forum's "Galvanized"), sized 120x38mm and rated at 2600rpm at 12V. Two of these fans have now been running without incident powered by the PWM-controlled fan headers on a dual opteron Tyan K8SR serverboard, and one attached to my Tyan K8E.
    Which brings me to my question:
    Is it possible, by inspection of the circuitry or otherwise, to estimate the amount of power one can safely draw from such a motherboard fan header for long-term usage?
    The motivation behind my question is that I was planning to replace the rather cheap and cheerful "Made in China" 120mm fan in my wife's machine with the remaining one Sanyo Denki. She is, however, using a MSI Neo2, which unlike the Tyans I mentioned, is certainly not a board designed to deal with 5 or 6 15000rpm 40mm screamers in a 1U rackmount unit.
    For the record, these Sanyo Denki are a variant of this model, with identical current rating (0.52A): http://sanyodb.colle.co.jp/product_d...master_id=1140 .
  • Galvanized
    • Mar 2006
    • 468
    Re: Basic question regarding PWM-controlled fan headers
    Generally, desktop boards are speced at 8W per fan jack but I would not load all four ports at 8W. I had to really dig a bit in the ASUS manual to find the wattage rating for the fan jacks. Generally, server boards have about twice that rating, maybe more.
    After 5 minuets, I gave up on down loading a MSI manual. Thier site is slow.
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      Be careful of DC fan current ratings. That .52A fan actually draws current in pulses that may be 1.5A-3A, but the average current is .52A.
      PeteS in CA
      • gonzo0815
        • Feb 2006
        • 1600
        To pic up the question, i think yes it is probably possible to do a educated guess on sutch a circuit. If the layout of the board is given, probably with some math this could be a very accurate guess.
        I think the most interesting questiuon is the absolut power rating of the mosfets, and the cooling area of them.
        The next thing is the absolut area of the coper traces and the thickness of the cooper laminate, to calculate the power.
        • Rainbow
          • Aug 2005
          • 1374
          The power to the fan connectors is often switched by tiny SMD transistors which can't withstand too much.
          • gonzo0815
            • Feb 2006
            • 1600
            Yes, but in recent (especially AMD C&Q) boards there are some not that small mosfets (those 2 to3 mm long rectangular, soldered like the bigger mosfets in vrm with the hs to the pcb) which may be can handle up to severall amp`s. The limiting factor would probably the heat transfer from thos devices. But with PWM there arent that mutch losses and therefore not that mutch heat.
            • tiresias
              • Feb 2006
              • 489
              Interesting. Would you like me to take pictures of the headers and surrounding area in question on the two motherboards I was talking about?
              • gonzo0815
                • Feb 2006
                • 1600
                Well, no problem. if the device is identifiable i could easily look into the datasheet and give a roughly guess what this could be handle. For the more accurate guess i am not shure if i am educated enough to do it on a safe way.
                • cj_reha
                  Mystery 80s Sanyo cap - perhaps polymer?
                  by cj_reha
                  Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                  01-06-2023, 09:24 AM
                • toddw65
                  Sanyo DP5834 - Gray Screen
                  by toddw65
                  Hey All,
                  I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
                  Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
                  Thanks,...
                  10-31-2024, 10:37 AM
                • hugocarmo
                  Sanyo VHR-D4710G VCR no sound.
                  by hugocarmo
                  Hi again guys.
                  Today I have a problem with this Sanyo VCR.
                  I bought it online, It worked sometimes.
                  I recap the Power supply and it started working fine.
                  Image is perfect and all digital effects too.
                  All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
                  I have no sound on playback, on tuner, or aux in.
                  On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
                  On one of the sound processing...
                  01-23-2024, 12:58 PM
                • swofra
                  Basic electronic knowledge resources
                  by swofra
                  Hey all,
                  I've got a few XBOX power problems but don't know much about anything concerning electronics troubleshooting outside of replacing caps. Instead of coming on here and wasting people's time being confused when they say check rectifier, transistor, resistor, etc or whatever it may be and then having to ask "what is that?", I wanted to learn and build up a knowledge base first so I'm not completely clueless and can apply the good advice people give without confusing the situation more by not knowing what i am doing.
                  Is there a good thread or source, either on this...
                  11-07-2023, 06:52 PM
                • m4a2t0t
                  50's Sanyo monitor
                  by m4a2t0t
                  What type of caps can I use to replace these Rubycon (K) caps? Can I use a film cap? I cant find any aluminum electrolytic caps that go that low. They are .033 uf and .047 uf
                  06-16-2025, 07:04 PM
