Funky laptop problem
  • stevo1210
    • Oct 2006
    • 4156
    I have a clients Dell Inspiron 710m here that was dropped down a flight of stairs. The exterior is pretty much destroyed. Anyway, it still boots and works (albeit broken LCD).
    Only problem is this... when I put another 2.5" PATA HDD in, it doesn't spin up. I've tried 3x different HDDs to no luck at all. However the original Fujitsu HDD will spin up but not get recognized in the BIOS but when I move it to another PC it works fine so I recovered all the files from there.
    What's going on here?
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • selldoor
    Slow Learner
    • 7870
    Re: Funky laptop problem
    I know its a daft thing to suggest but does this model use the dell hard disk connector adaptor and are you putting one on the disks you try?
    • stevo1210
      • Oct 2006
      • 4156
      Yes I put the adaptor thing on each hard drive I inserted. No go
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Maybe the fall cracked some of the solder joints on the laptop's hdd connector?
        sigpic
        (Insert witty quote here)
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          After a fall down a flight of stairs, there's no telling. Cracked PCB or broken solder joints would be my guess...
          How does one drop a laptop down a flight of stairs!? Must be some bozo like one of the M6300's I was recently given......some chick managed to slam the screen portion in the trunk of a car....the end result there wasnt pretty...
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • selldoor
            Slow Learner
            • 7870
            Another daft idea - What size replacements were you using I believe some models will only take a 120gb disk or one with OS on 120 gb partition
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              ok did you guys hear him say 'spin up'? thats whats confusing me. I'm thinking power, but if it was a power solder joint...why does the original spin up?
              • stevo1210
                • Oct 2006
                • 4156
                That's the bit which confuses me badly. Only the Fujitsu drive will spin up. The others won't budge.
                And in response to TC, neither can I understand how one drops a laptop down some stairs... and yes, owner is a woman!
                • ahmarzo
                  Acer TMX314-51 laptop battery problem
                  by ahmarzo
                  I have acer laptop tmx314-51 with part no 6050A3020501.
                  The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                  But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                  I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                  The schematic is not available...
                  04-11-2025, 09:14 AM
                • PacoGT
                  HELP!! Dell E6440 laptop with problem does not turn off and turn itself on help
                  by PacoGT
                  A few days ago my laptop gave me problems, when I wanted to turn it on to my surprise without charging so I did not put much importance on it, after that I turned it on with a charger, it turned on and charged the laptop, the problem with the laptop is that when it is turned off it turns to turn on after seconds, sometimes at 2 or sometimes at 8, other than that it works normally, I already checked many things, I changed a mosfet at the charge input to a pnp but it remained the same, after that I checked and I did not find anything outside Normally, before that, it had a failure where I changed...
                  07-11-2023, 09:31 PM
                  Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                  This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                  09-06-2024, 09:30 PM
                  Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                  This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-06-2024, 08:47 AM
                • versionlab
                  Weird problem, laptop stays on when connected to another pc
                  by versionlab
                  Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
                  Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
                  After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
                  10-26-2022, 03:43 AM
