SATA RAID Hdd suggestions
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    I have a 3ware 9500 4 port raid card in my current system and in the future I am thinking of finding 2-3 used SATA drives to build a RAID 0 array. Currently, I am using a single 320gb WD caviar blue, which will not do RAID from what I understand.
    So, in the world of used SATA hdds, which ones are good candidates for RAID and long term relaibility? I do know that the seagate 7200.7 series is bad (I've had 2 of 3 drives die, the 3rd rarely sees use).
    On a side note, is there any place where one could get really short SATA cables? as in 3"-5" long? My case is such that the hdds are right next to the controller...
    sigpic
    (Insert witty quote here)
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: SATA RAID Hdd suggestions
    Bad idea.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Originally posted by shovenose
      Bad idea.
      well, with a RAID card and 3 HDD bays, what else could I do?
      if I had 4 bays. then I'd raid 01 or 10 it... but I only have 3.
      There is Raid 1, but really? I take backups of anything important on my external hdd / server...
      sigpic
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        your hard drive can do raid, there are some drives that are manufactured with optimizations for it...
        and there are a few hard drives that have firmware problems that might cause issues in certain raid configurations. Raid 1 is probably one of the most compatible. 5 and other parity striping usually the least
        wish I would of rma'd a wd blue 320 I had but I believe its out of warranty
        if you want raid 0 optimized drives go for the WD RE series, but they're expensive, black would probably work too
        • smason
          • 1652
          RAID 0 with SATA is a recipe for data loss, unless you get drives with TLER or equivalent.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I was wondering if perhaps seagates had more flexible firmware?
            also
            would maxtor maxline 5 250gb units be any good? I have one in my imac g5 that never sees use... I could always swap them if needed...
            about raid 0 data loss- I understand the risks... but I also understand that my main system is not mission critical... all of my really important things are done on my laptop (collge stuff). To me, it is like overclocking- there is a risk but also a return.
            sigpic
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              where do you come up with this? I've seen this done ALOT with sata, never ran into data loss other then when a drive crashes
              and he also has a hardware controller...should he use PATA? I've used raid 0 on a vtrak 15100 on drives that do not support TLER and was perfect
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                its also SATA controller... a 3ware 9500s-4lp to be exact (supports SATA-150, fast enough to keep up with most HDDs).
                sigpic
                  master hoarder
                  • May 2008
                  • 12160
                  3 drives isn't a whole lot, you know. Perhaps just bad luck on your part. The 7200.7 is actually one of the most reliable series.
                  We have about 100-120 computers at my old work, and most of them (probably about 3/4, if not more) still have these 7200.7 drives (the IDE version, though). Sure a handful of them have started developing bad sectors, but they are all still working reliably. In the 2 years that I was working there (part time), we've had exactly only 3 drop out. Now don't forget that most of these drives are over 5 years old, most with 8+ hours/day workload (some even 24/7 or close). That's a pretty good record if you ask me.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    I see... out of my 3, 2 were 80gb IDE drives and one was a 160gb SATA:
                    80gb #1- came in an HP d530 tower, handed around to a few differnt boxes before it ended up in an eMac, where it currently exists.
                    80gb #2- came from a used goodwill-found external enclosure. placed in the d530 for a while before it was put in a shuttle XPC box, where it died. It caused randome computer issues, which were fixed when a new HDD was installed. Since it was in an aluminum enclosure, it is possible that the harsh enviorment may have contributed to its lifespan.
                    160gb SATA- bought used from a computer shop to go in a "Newly aquired" Imac G5. Also caused random issues, which were corrected upon replacement of the HDD.
                    The two dead ones had the exact same symptoms... random issues... but no other signs (noises, etc). I still have both drives in runnable condition, but unless there is a "magic" FW update, they are likely trashed.
                    sigpic
                    • Wrog
                      • Oct 2009
                      • 472
                      RAID 5 can use 3 drives.
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        raid 5 uses a MINIMUM of 3 drives, and since he has a hardware sata card, there is no way to raid 5 with some pata drives without using windows/linux software raid
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          why would I want PATA drives? They are cheaper but it would undermien the whole point of using my hardware RAID card.
                          In addition, my card doesn't have a BBU installed, nor do I have space for one w/o moving the card to from the 100mhz to the 66mhz slot (If it makes a difference in the case of the 9500), so RAID 5 is out, as without a BBU, the write hole becomes an issue; the chances of a hard reset are quite high compared to a the chances of a HDD failure.
                          sigpic
                          • Mad_Professor
                            A Mech Warrior
                            • Feb 2011
                            • 1587
                            uh.... Battery backup? fsync?
                            mdadm is very stable, unless you have hardware issues. I'm running a mdadm raid 5 and I recently had the whole array drop out because of that shitty p5n-d and quadcore combo. Luckily nothing was being written and I was able to force the array to assemble and I haven't come across any damaged data yet.
                              master hoarder
                              • May 2008
                              • 12160
                              See, that's the problem with used drives - you don't know how they were handled (read: likely thrown around). All of the machines I mentioned above were either new or second hand bought in bulk (but usually handled well).
                              If you haven't done so already, check (and even post, if you like) the SMART logs of those drives.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                IIRC the 80gb had bad sectors, and that was the only thing that SMART indicated as being bad. the other drive I never checked...
                                http://en.wikipedia.org/wiki/Raid_5#...k_failure_rate
                                w/o a BBU, if you have a power outage or the like, there is a decent chance that the write hole could occur... there is usually 1-4 power outages a year around here... so that could be a real issue.
                                sigpic
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  iirc the 80gb had bad sectors, and that was the only thing that smart indicated as being bad. The other drive i never checked...
                                  http://en.wikipedia.org/wiki/raid_5#...k_failure_rate
                                  w/o a bbu, if you have a power outage or the like, there is a decent chance that the write hole could occur... There is usually 1-4 power outages a year around here... So that could be a real issue.
                                  ups ftw
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    ups ftw
                                    Don't have one...
                                    sigpic
                                    • gerg
                                      • Nov 2010
                                      • 278
                                      http://blog.techally.com/2011/04/3wa...e-hard-drives/
                                      there is a good chance that you should stay away from seagate drives for this setup
                                      I had these issues it took me a long time to figure out what was going on.
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Sounds more like one should update the HDD firmware first... Plus that is a 9650SE specific issue; I have a 9500s.
                                        sigpic
                                        • DynaxSC
                                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                          by DynaxSC
                                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                          03-10-2025, 12:27 PM
                                          HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
                                          This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-12-2024, 03:28 PM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
                                        • canadaboy25
                                          Getting Windows to boot after changing SATA from RAID to AHCI
                                          by canadaboy25
                                          Hey guys I'm wondering if anyone has any ideas on how to get Windows 10 to boot up and install drivers after changing the bios settings for the sata port from raid to ahci.
                                          My motherboard is an Asus M5A99FX pro R2.0 and when I built the PC I set all of the sata ports to raid mode. There is one setting for ports 1-4 and one setting for port 5 and the esata port. I currently have 4 drives set up in two raid 1 arrays on ports 1-4. My ssd containing Windows 10 is plugged into port 5. I also have an external esata enclosure with a 2tb drive that I use as a Windows backup plugged into...
                                          12-02-2018, 02:17 PM
                                        • canadaboy25
                                          Drive SMART status not showing up through RAID controller?
                                          by canadaboy25
                                          Hey guys,
                                          I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
                                          Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
                                          I rebooted...
                                          09-24-2021, 01:56 PM
