Sound card headers
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Sound card headers
    this will sound dumb...
    but i may be buying a sound-less mobo for a system with fron sound headers (headphone/mic).
    it is of the "ac 97" type:
    (not my pic)
    What I wonder is if there were ever any decent PCI sound cards with the conenction for such header... and if so, what model(s)?
    even better, if somebody (US/CA preferred) had one they were wanting to sell/trade, that would work too.
    sigpic
    (Insert witty quote here)
  • mariushm
    • May 2011
    • 3799
    Re: Sound card headers
    I don't understand what you really want.
    That connector is for an onboard sound chip to output stereo sound and take in microphone from jacks usually mounted on the case.
    It's unlikely you're going to find a sound card with those connectors because it's a an onboard sound/CODEC specific thing - a sound card would have processor and all jacks on the bracket.
    So I don't get what you want to do... do you want to connect the jacks in the case to a standalone sound card somehow, because the motherboard has no sound at all?
    If so, the pinout is easy enough:
    The one on the right is the old AC'97 layout, which is probably what the case connectors were designed for.
    Get two of these :
    http://www.monoprice.com/products/pr...seq=1&format=2
    and two of these
    Plug one jack in the back of the sound card, cut the other end and solder the wires to the wires from the case connector.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Get two of these :
      and two of these
      it was the AC 97
      copied the wrong pic... I forgot that there was a similar HD on.
      the board has no sound at all... the chipset has it, but the board does not (blame supermicro)
      I would rather do this elegantly, as I have a hatred for inside to outside kluges like you suggested...
      I Have not bought the board yet... but it is from a "buddy" around here (you know who you are) and he gave me a pretty decent offer...
      the board is a supermicro x5DAL-tg2
      I'll do some searching and see... IIRC i once saw a card with it... I bet there has to be an OEM who used one (like the SB Live! cards with dell headphone headers)
      sigpic
      • mariushm
        • May 2011
        • 3799
        Apparently this one did have the connector:
        http://www.newegg.com/Product/Produc...82E16829156005
        but it's about 120$ new.
        This one looks like it has the place for a 10pin header but you have no guarantee that's really ac'97 or that the traces are there
        http://www.newegg.com/Product/Produc...82E16829111003
        There are some cheaper Startech cards that have the header but on one of the cards it's silkscreen-ed "GAME1" by the connector. But the Diamond card above HAS the game connector AND the header holes.
        This one has both: http://www.newegg.com/Product/Produc...82E16829265001
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          I have a cheapo card that had the connector silkscreened... ages ago I added the pins to make it a header... it didn't work, but I might have gotten it upside down.
          it is one of these in green (recapped too):
          http://uk.eetnordic.com/product.aspx...RD-5.1-CHANNEL
          sigpic
          • c_hegge
            • Sep 2009
            • 5219
            It is probably also missing some small surface mounted components.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              yeah, the header is no good... tested it, as soon as I plugged in my headphones, it shorted soemthign because the system did a hard reboot.
              I see this may be an uphill battle... there were plenty of cards that had the HD header but AC97 is looking bleak... I assume the MX_Link On my old diamond mx300 wouldn't be of use?
              sigpic
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                its out of stock, but this is the cheapest one I can find
                http://www.newegg.com/Product/Produc...82E16829132020
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Good job. Manual says it will do either jack.
                  looks like a good card too
                  maybe I can snare one on ebay...
                  ebay's cheapest is $30 shipped:
                  http://www.ebay.com/itm/ASUS-XONAR-D...item3cc321759a
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    found why that port failed
                    look at this:
                    http://www.newegg.com/Product/Produc...82E16829265002
                    it has the same chip (or similar) and the port is installed.. it is listed as optical in/out
                    no wonder....
                    sigpic
                    • japlytic
                      • Oct 2005
                      • 2086
                      Some computers with this audio header may have a BIOS option of selecting "AC97" or "Azalia".
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        this one doesn't... there is no audio coonetions on the PCB. not even silkscreened:
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          It looks Iike I will do the asus xonar DG if I get the board... I may use a different card initally and hold out a bit to see if I can snare one for cheap...
                          they also seem to have decent linux support from what I have seen...
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            problem solved!
                            another BCN buddy (you too know who you are) has oen of these:
                            http://www.facebook.com/l.php?u=http...F9&h=6AQEX0wju
                            (recapped, too)
                            if I get the board, I'll buy it off him...
                            sigpic
                            • Christos Tsiligiannis
                              Marian Trace Alpha sound card repair help
                              by Christos Tsiligiannis
                              Hello to the forum.
                              My name is Christos, I am new to the forum here and i am posting from Greece.
                              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                              So i tried asking for a schematic from the company and they would not give me one. Instead they...
                              11-18-2024, 05:26 AM
                            • FZG
                              EVGA Nu Audio Sound Card - Not Working
                              by FZG
                              I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                              The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                              I found...
                              03-07-2025, 11:44 AM
                            • paparazzo79
                              sound card dead after graphics card installation
                              by paparazzo79
                              Hi guys.I own Z690 F Strix board in one of my PCs....everything was working fine with integrated graphics card.I turned off power from it, installed graphics card from another PC, connected all the peripheral cables, optical sound cable of course when everything was switched off.Then I powered on the machine and integrated soundcard is dead.How did this manage to happen and if there is a way to diagnose and replace damaged component?
                              The new pci-e soundcard costs here 80 euros which is half of money I spent on motherboard.
                              I still can not believe that I am such a looser and don't know...
                              07-23-2024, 12:22 PM
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • alpersen
                              Modding, adding usb/c audio pcb to laptop with faulty sound card/chip, Lenovo L340
                              by alpersen
                              Hello
                              After months of trying I gave up my laptops sound card. I plan to solder a sound card on pcb inside my laptops case, probably connecting to usb ports inside. Do anyone has an experience to recommend pcb type audio/sound card suitable installing inside a laptop? Probably should have some type of amplifier for connecting to internal speakers ( speakers ).
                              Thank you
                              11-19-2023, 09:34 AM
