PC sleeps and wakes fine but Windows Update is a bitch
  • pentium
    • Mar 2006
    • 2778
    Got the ShuttleX media center finally setup and tweaked well enough with S3 mode that I can go from dead silent and no power to up and ready in five seconds and from off to booted and ready in 30 seconds.
    Only problem is that Windows Update is f%*@ing around and keeps waking the system up according to its own schedule.
    Initially I had the system setup to check for updates every monday at 10AM. It would wake up every morning at 10AM for four minutes, then go back to sleep. I tried moving this to a later time like 1PM so it was not always waking me up but that just completely broke everything and now no matter what time I tell it to check (again, it does not matter what day I set) it will wake up and stay awake.
    I decide the hell with automatic updates and selected DISABLE AUTOMATIC UPDATES and it STILL wakes up at whatever the last preset check time was.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • Toasty
    • Jul 2007
    • 4171
    Re: PC sleeps and wakes fine but Windows Update is a bitch
    What OS?
    Does the service show as Started - Automatic when you run services.msc?
    XP = Automatic Updates
    Win7 = Windows Update
    Is your clock set correctly and for the correct time zone? (Have to ask... )
    Can you run updates manually and does it work?
    Take a look at this: http://support.microsoft.com/kb/943144
    The part about the Windows update agent download. Or, try the Fix it.
    Ignore what the stated problem heading is. There are other issues (malware) that can screw with WU.
    Toast
    veritas odium parit
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Scheduled Defrag and Virus Scans/Updates can do this too...
      • pentium
        • Mar 2006
        • 2778
        Windows XP Media Center Edition 2005. No virus scans or defrags are scheduled.
        Automatic Updates was set to Automatic and Started. Because not much comes out of Windows Update anymore, I disabled the service.
        Trust me. It's not Malware or any garbage like that.
        Find Nedry!
        • pentium
          • Mar 2006
          • 2778
          10AM: It wakes up.
          Son of a bitch.....
          Find Nedry!
          • Toasty
            • Jul 2007
            • 4171
            Since you said you turned it off, then it's not the update service.
            Look at LAN connections - adapters. Are they set to wake up system on activity? Any other systems tied to this via LAN?
            Oh, wait. You disabled it. Did you STOP it too?
            veritas odium parit
            • pentium
              • Mar 2006
              • 2778
              Oops. I didn't stop it.
              Okay, lets see if I'm woken up tomorrow.
              Find Nedry!
              • pentium
                • Mar 2006
                • 2778
                IT woke up.
                But then it went back to sleep.
                Find Nedry!
                • Toasty
                  • Jul 2007
                  • 4171
                  Take a look in the event log and see if that shows anything.
                  http://www.microsoft.com/resources/d....mspx?mfr=true
                  veritas odium parit
                  • pentium
                    • Mar 2006
                    • 2778
                    For the last two days it was behaving like it should, then this morning it woke up and the system hung. Remotes did nothing and the IR receiver was ignoring the remotes.
                    Event log is telling me that the Bonjour Service is crashing and burning a lot. The error is constant:
                    Code:
                    Task Scheduling Error: m->NextScheduledSPRetry nnnnnnnn
                    Where n is a numerical value.
                    It seems to do it at random times during the day but it ALWAYS crashes and burns at 9:59 AM every day.
                    I'll uninstall iTunes and see what happens NOw that I know that Media Center can link to my music library, I don't really need it anymore.
                    Edited: Oh, it's apparently NOT part of iTunes.It's just stuckware that hangs around after you uninstall.
                    Service has been disabled, confirmed it's no longer active by rebooting and checking the log. Lets see what this does.
                    Find Nedry!
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      manually remove the stuckware...
                      sigpic
                      (Insert witty quote here)
                      • b700029
                        Banned
                        • Sep 2010
                        • 640
                        I would check the hard drive and memory.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Don't forget to make sure that "wake on LAN" is disabled in the BIOS.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • pentium
                            • Mar 2006
                            • 2778
                            Uhhh, why?
                            Find Nedry!
                            • Sparkey55
                              • Jan 2010
                              • 1523
                              Try using a good registry cleaner or manually search the registry for anything related the Bonjour Service and other deleted programs.
                              • pentium
                                • Mar 2006
                                • 2778
                                Okay, disabling Bonjour fixed that part of the problem, now however Media Center Scheduler and Media Center Guide are waking the system up to download listing information. That I am not sure how to change.
                                Find Nedry!
                                • b700029
                                  Banned
                                  • Sep 2010
                                  • 640
                                  Originally posted by pentium
                                  Uhhh, why?
                                  Make sure the hardware is good before suspecting the software.
                                  If the memory or hard drive is randomly flipping bits, all bets are off on what you experience.
                                  • pentium
                                    • Mar 2006
                                    • 2778
                                    I'm optimistic of drive or ram issues considering both were well tested before used (DBAN and memtest). It's more that something is not configured properly.
                                    Find Nedry!
                                    • akwky
                                      by akwky
                                      Hi!
                                      04-14-2025, 01:56 PM
                                    • TheUser
                                      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                      by TheUser
                                      Hello to everyone ,
                                      This is my first post here, and i would like to share with you a small story in case you can help me.
                                      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                      02-10-2024, 02:07 PM
                                    • mecha1166
                                      KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                      by mecha1166
                                      KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                      11-25-2024, 05:22 PM
                                    • CapLeaker
                                      Dell ATX PSU won’t start, but forcing it works fine?
                                      by CapLeaker
                                      Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                      Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                      10-28-2024, 06:59 PM
                                    • iMuhtaseb
                                      A1706 2017 critical update
                                      by iMuhtaseb
                                      this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
                                      we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
                                      One weird symptom is it takes too long to power on and show the Apple logo for some reason..
                                      I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
                                      08-13-2024, 08:41 AM
