Presscott vs. Northwood
  • stevo1210
    • Oct 2006
    • 4156
    I know these are both "ancient" CPUs for todays standards, but I have a friend who has a pair of these in 478 format. Both are 3.2GHz in speed. He is unsure of what to use in his office PC. I believe the Northwoods run cooler and faster than a Prescott but the Prescott has SSE3 and a bigger cache?
    I have this concern for heat as the case he is using is one of those desktop ones you have on the desk and pop a monitor on top... looks quite cramped in there. Motherboard is an AsRock P4i65G and supports both chips... just looking to upgrade from a 2.66GHz Celeron D. LOL
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Presscott vs. Northwood
    Depends on who you ask and what your intentions are.
    Presscott runs hotter but OCs a lot better.
    Northwood runs cooler but OCs worse.
    All I can say is to try each one and see...
    sigpic
    (Insert witty quote here)
    • Scenic
      o.O
      • Sep 2007
      • 2642
      Go for northwood, especially in a crammed case. Performance difference is not enough to actually feel it. Only visible in benchmarks.
      The point about OCing is moot (it's an ASRock board lol)
      edit: you can directly compare the specs of the two CPUs if you want.
      Go to http://www.cpu-world.com and type the SSpec number (like SL6WG, SL7PN etc.. it's engraved in the CPU's heatspreader) into the "identify" field on the right.
      • mariushm
        • May 2011
        • 3799
        Look them up at http://cpubenchmark.net/cpu_list.php
        Intel Pentium 4 3.20GHz 522
        Intel Pentium D 3.20GHz 888
        I guess these are the 2 3.2 Ghz but I'm not sure. Yeah, if I remember correctly the Prescott is better.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          Uhm.. you compared a Pentium 4 3.2GHz with unknown core (Prescott/Northwood) against a Pentium D (Pentium 4 Prescott x2).. no wonder the latter seems faster :P
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Originally posted by stevo1210
            He is unsure of what to use in his office PC. I believe the Northwoods run cooler and faster than a Prescott.
            Nope.
            Most Northwood are cooler but not all and faster depends on FSB and cache.
            Northwoods went up to 89 watts and Prescotts started at 89 watts [because of the smaller die] so this is another place where you can't make a generalization like that.
            You have to look at the specific CPU.
            Mann-Made Global Warming.
            - Dr Seuss
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              I've used both, and also had a Northwood which OC'ed like a dream (1.8GHz @ 3.6 undervolted), but also had crap OC'ers. My first Pentium 4 system (3.0GHz HT) was the last one my dad built for me, and it suffered from a lack of RAM. From there on i built my own and went for less powerful CPUs but plenty of RAM, and have never gone wrong with this mindset.
              Clock by clock, the Prescott HT is faster. If you have a big cooler sitting around, use a Prescott. If you're using a SFF case, go for Northwood, otherwise it'll be in thermal throttling all the time and running like a Pentium II.
              A working TV? How boring!
              • severach
                • Aug 2007
                • 1055
                Any Pentium 4 with HT is faster than any Pentium 4 without. FSB 800 FTW!
                sig files are for morons
                • stevo1210
                  • Oct 2006
                  • 4156
                  Alright, so I suppose a Northwood is the go then? I'm not sure what the exact model numbers on each CPU are... so won't be able to provide a wattage TDP for each. However I do have to agree that in a cramped little shuttle case it's going to get hot and the OST caps in there don't look like they will cope with a Prescott!
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    For socket 478 3.2Ghz TDP..
                    Northwood = 82w
                    Prescott = 89w
                    With a difference that small since the Prescott will finish tasks sooner (and so spend more time at idle) the net effect on system heat will probably be no difference at all.
                    It's definitely not enough difference to be getting your nickers in a bunch like that.
                    - Dr Seuss
                    • brethin
                      • Dec 2008
                      • 1907
                      Go with the fastest FSB speed cpu first (which most of the time will be the Prescott). If heat is a issue use better cooling.
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        Like I said before, the SSpec number is engraved into the heatspreader. With that, you can look up the detailed specs on CPU-World.
                        It's like a part number, with every intel CPU having it (always a 5 letter/number code that starts with "S")
                        On cpu-world, put the Sspec number in the "Identify part" field on the right and click go.
                        This will bring you to a page showing the basic specs. To get all the details, you have to click on any of the part numbers shown.
                        You'll end up on a page with every single detail about that CPU (see 3rd attachment.. won't post it inline cause it's huge)
                        edit:
                        All 3.2GHz Northwood P4s on Socket 478 (SL6WE, SL6WG, SL792) are 800MHz FSB :P
                        And only one of them (SL792) does not have HT (or at least the info is missing).
                        • ugamazing
                          Procedural question about BGA rework and removal of CPUs
                          by ugamazing
                          I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
                          I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
                          I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
                          07-12-2022, 03:11 PM
                        • Nebukadnerzar_V
                          Dell Optiplex 760 USFF BIOS Mod Request for QuadCore CPUs
                          by Nebukadnerzar_V
                          Hi guys!
                          I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
                          It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
                          I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
                          Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
                          Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
                          I have attached the Dump of my machine.
                          S/N: SRW2K4J
                          Reg Model: DCTR...
                          09-27-2024, 02:43 AM
                        • ducky29
                          Working with Bga chips especially CPUS
                          by ducky29
                          Hello. I mostly do small electronics and tv repairs. I am confident with small bga chips but I never was successful with removing large chips especially cpus. Is it possible to remove them just using a preheater and hot air gun or I need something more advanced like a bga machine with temperature profiles, cooling fans, etc etc.
                          Any suggestion on aliexpress/ebay are welcomed. I am on a tight budget, max I can do is about 200$. Please anyone with more experience can give me some suggestions?
                          Thanks in advance.
                          09-23-2024, 03:56 PM
                        • Windows8RTMUser
                          Repair knowledge for -55c CPU temperature on AMD Ryzen CPUs in bios, the AMD Sideband temperature sensor interface (SB-TSI)
                          by Windows8RTMUser
                          Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
                          In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
                          I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
                          tags:...
                          07-28-2025, 07:26 PM
                        • Dan81
                          "Netburst Mercedes" - a rather simple yet "exotic" build
                          by Dan81
                          Figured I should make a own thread so as not to hijack Topcat's thread.
                          Just as the title says, this machine is basically a "Netburst Mercedes". From the case, all the way to the innards, IMO.
                          First, let's take a look at the specs:
                          Mobo: Gigabyte GA-8IG1000 Pro w/ FGx BIOS (special BIOS revision made by AGFA for their dlab.1 MPU machine.)
                          CPU: Pentium 4 HT 3.00GHz Prescott - will probably replace it with a Northwood HT as this Prescott is literally HELL incarnate. Wish I'd be joking, but it's absolutely true.
                          PSU: revamped Deer/L&C...
                          03-08-2022, 11:50 AM
