Need to build a super budget htpc
  • stevo1210
    • Oct 2006
    • 4156
    I want to build a super dooper budget HTPC from rummaging around with whatever shit I have here. The only "new" thing I will get is a desktop case (the type where you pop the monitor on top) and that's it.
    Only problem is that they only take mATX boards and not ATX boards, so I'll probably need a second hand one of those things too.
    So far I have...
    * An Intel P4 775 3.6GHz CPU 2MB 800MHz FSB & L2 cache I think it is. Supports 64 bit codes if I am not mistaken.
    * 1.5GB of DDR400 RAM
    * A HIS dual slotted HD4670 AGP 1GB graphics card
    * LG Blu-Ray & HD-DVD drive combo thing
    * Creative X-Fi sound card
    * 200GB Seagate ATA HDD
    Now to the board... as you can see, I'm stuck with AGP and DDR400 so I'll have to find an AGP/775 board. Tossing around VIA or SiS chipsets...
    VIA or SiS? Gigabyte or Asus?
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • stevo1210
    • Oct 2006
    • 4156
    Re: Need to build a super budget htpc
    Three board models I am considering... cost is $55 each.
    Gigabyte GA-8I865GME-775
    Foxconn P4M800P7MB-RS2H
    Gigbyte GA-8S661FXM-775
    • ncovert
      • Feb 2011
      • 291
      Okay, I found a decent combo deal on Newegg (shortened with Bitly)
      http://******/yL3Cih
      This is good if you're looking to build with newer components
      • Scenic
        o.O
        • Sep 2007
        • 2642
        ASRock 775i65G or 775i65GV. Socket 775, AGP, DDR-RAM, µATX.
        The 775i65G Rev. 2.x supports Core 2 based CPUs as well, which is unique to this board because it uses the i865G Pentium4 chipset which pre-dates all Core 2 CPUs by a couple years..
        I could look around locally to get one cheap. Shipping would be ~20aud with DHL
        • Newbie2
          • Sep 2005
          • 885
          ncovert, stevo1210's in Australia. Newegg does not ship out to Down Under, plus stevo1210's looking at reusing as many older parts as he can.
          stevo1210, out of the three motherboards that you listed, I would strongly recommend the Gigabyte GA-8I865GME-775. You want to stick to an Intel chipset, since VIA and SiS chipsets are just downright horrible (from my experience with them on ECS/PCCHIPS motherboards)
          My gaming PC:
          AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
          ASUS M4A77TD AMD 770 AM3 Motherboard
          PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
          G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
          TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
          WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
          ASUS Xonar DG 5.1 Channel PCI sound card
          Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
          Antec Three Hundred Mid-Tower Case
          Microsoft Windows 10 Pro 64-bit
          Microsoft Windows 7 Ultimate SP1 64-bit
          • ncovert
            • Feb 2011
            • 291
            I knew that, but for anyone else who wants it, thats why I posted it.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              I suggest finding a p4 HP evo Dxxx in the mintower format... they can be converted into a desktop quite easily (can be used as a tower or desktop) and albeit bulky make decent HTPCs.
              sigpic
              (Insert witty quote here)
              • brethin
                • Dec 2008
                • 1907
                I have a new in the box Mercury PI865GVM7 Micro ATX Intel 865GV/ICH5 Chipset.
                http://www.mercury-pc.com/product-sp...?productid=580
                I can part with for $35 you pay shipping.
                • stevo1210
                  • Oct 2006
                  • 4156
                  Thanks for the offer, but I need a board with an AGP slot unfortunately.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    It DOES have an AGP slot... look at the spec page.
                    Most boards of that generation had PCI-E. this one is a rare exepetion.
                    sigpic
                    • MORETTIGIAN
                      Capacitor detached from PCB – RTX 2070 Super Founders Edition
                      by MORETTIGIAN
                      Title:
                      Description:
                      During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                      I did not notice it detaching, so I am unsure of its original location on the PCB.
                      Procedure performed:
                      - Removed backplate
                      - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                      - Reapplied thermal compound
                      - Reassembled card
                      Observed behavior after reassembly:
                      - GPU powers on and operates normally under...
                      09-18-2025, 12:14 PM
                    • Destroyer-Br
                      [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                      by Destroyer-Br
                      I'm working on an Acer Nitro 5 unit with the following specs:
                      • Motherboard: LA-J871P Rev: 1B
                      • Model: Acer AN515-55-59MT
                      • S/N: NHQ7JAL00403906A973400
                      • SNID: 03902728734
                      Initial Issue
                      The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                      After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                      04-17-2025, 08:18 PM
                    • AJ847.63e
                      Playstation 3 phat, slim and super slim resource search
                      by AJ847.63e
                      Hi All,
                      I recently got a bunch of faulty/partially faulty PS3s and wanted to get some advise on them. Models are:
                      X4 are PS3 slims with disc drive errors.
                      X1 is a PS3 slim with the 8002F1F9 update error.
                      X1 is a ps3 slim with no display.
                      X1 is a slim with RLOD
                      X1 is a super slim with a missing disc drive and receiving the same update error 8002F1F9 (I'm assuming because it needs it's drive)?
                      X1 is another super slim with no power (board number MPX-001).
                      Does anyone know of any good resources that list parts interchangeability?...
                      Yesterday, 05:39 PM
                    • ratdude747
                      AV/HTPC Build/Purchase.
                      by ratdude747
                      Per some issues I've run into with a new AV setup at Chuch, I'm thinking in the long term I need to look into buying/building an AV (HTPC) machine to work around the misbehaving laptop.
                      The rest of the AV system is currently built around HDMI: there is a switch and splitter to a projector (which feeds stereo RCA to the existing audio mixer) and monitor (which has headphones; the monitor is for previewing with the projector off/blanked). OS wise I'm thinking either Windows 10 or (less optimally) OSX, mainly since I'd like to eliminate the fiddly blu-ray player (which is causing...
                      12-05-2022, 09:04 AM
                    • ongobongo
                      Asus ROG Ally - Super IO Chip replacement
                      by ongobongo
                      anyone here who has experience with replacing the super IO chip of an ROG ally?
                      I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
                      Ongo
                      11-17-2024, 11:27 AM
