So when recapping, or rebuilding of a piece of equipment fails, what components are worth the time to desolder and save? Not just for future repairs, but for mad scientist projects as well.
What (if anything) to save when a piece of electronic equipment dies
Re: What (if anything) to save when a piece of electronic equipment dies
fets and heatsinks is about all I salvage from broken motherboards.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
fets, heatsinks, bios chip(s) and sometimes caps (if they're good ones)
I know.. reusing old caps isn't the greatest idea, but spending 15-20 bucks total w. shipping for a full recap of an old (Socket A/370/478 etc.) board which is pretty much worthless doesn't really make sense (if it's for yourself or non-critical applications).
That's what I usually re-use them for.Last edited by Scenic; 02-11-2012, 04:04 PM.
I only take BIOS chips if the motherboard is socketed for it, which is almost non-existent today. If its a hard soldered ROM, I don't bother.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
^ same, but most modern mainboards use 8pin SOP BIOS chips, so it's not that hard.
The common 8MBit EEPROMs actually aren't as cheap as one might think..
http://search.digikey.com/scripts/Dk...keywords=25L80
I often scavenge heat sinks. I then use them either to replace heat sinks which are too small, or if I build up a big enough box full of them, the metal recyclers will give me $20 or so for it.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
SOIC-8W BIOS chips come off in about 30 seconds. That's creeping up on the removal time for a socketed DIP-8. SOIC is really nice to work with good equipment.
I like to reclaim high quality caps I can't buy cheaply, MOSFETs, heatsinks, ram slot handles, batteries, EEPROMs, and oft damaged rear sockets. What I take depends on how much it would cost to buy and stock, how easy it is to remove, and how many I have already.Comment
A blast of hot air and they do pop right off....but I'm already overstocked on them, so I don't mess with them anymore.
I forgot about the batteries though, yes, I bilk those too.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
I forgot about CMOS batteries. If they're still good then I re-use them, but if they're flat, they make excellent fireworks.I love putting bad caps and flat batteries in fire and watching them explode!!
I save pretty much everything. If it's a bulky piece of equipment (such as a large printer), I toss the plastics and the case for metal/plastic recycling and only save the electronics (boards, motors, gears, clutches, heating elements, wires, etc.). I also always save the screws as well.Comment
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by SolomonManAll,
Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor... -
by RayblasterHello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011.... -
by sam_sam_samThis is a new item at Electronic GoldMine that has arrived within the last few weeks
Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
https://theelectronicgoldmine.com/products/g28392
One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...11-24-2024, 01:25 AM -
by KYBOSHPicked this one up today.
In addition to falling LED diffusers there is a single line here that maybe a deal breaker.
From my reading on these boards it is said that the issue is likely a sign of failed tab drivers, ribbons or tab bonding to the panel.
Wanted to get a 2nd opinion from you guys before I gave up the ghost.
Great looking TV otherwise.
Is there any tricks I can do to try to save this one?
If so, i'll gladly order a set of backlights and save this one from the landfill..
Thanks in advance
... - Loading...
