My oh my WHAT A DIFFERENCE!
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    I never realized until today how slow 5400RPM laptop drives are!
    In my bedside PC, I went from a 40GB 5400RPM 2.5" SATA drive to a 320GB 7200RPM 3.5" SAT (WD Caviar Blue)...
    holy cow this shit is fast!
    Only thing is that Windows 7 and 8 aren't compatible with my motherboard for some reason and I don't have a Vista install CD/DVD so I had to use XP.
    BUT IT FLIES!!!!!!!!
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: My oh my WHAT A DIFFERENCE!
    well... yeah
    laptop drives are slow anyway... atleast it wasn't a dreaded 4200RPM Travelstar... those are slow.
    for desktop use, yeah, use 7200RPM.
    for laptops and externals, 5400RPM has benifits (lower power consumption, less heat, better durability/shock resistance, etc.)
    sigpic
    (Insert witty quote here)
    • Scenic
      o.O
      • Sep 2007
      • 2642
      I bet it's a singleplatter one..
      http://de.hardware-wiki.org/wiki/Wes...iar_Blue-Serie
      Select the model (my guess is WD3200AAKS). It'll show a list of firmware/hardware revisions and the amount of platters/heads (platter/köpfe ; abbreviated as p/k) that specific revision has. If it's listed under "Unbekannte Konfigurationen" (Unknown configurations) you're out of luck :|
      1-platter drives are generally faster (higher areal density) and cooler running.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        It's a few years old by now, but I bought it brand new and it doesn't have a lot of hours on it, and it was now extra, so I used it - no point in having a great hard drive gathering dust in the closet!
        Oh and scenic, I know German so it's OK
        • mariushm
          • May 2011
          • 3799
          I don't know why you'd had to post a wiki link, when the specs are on WD's site, just a bit harder to find:
          https://cdn.badcaps-static.com/pdfs/...92de3f1af1.pdf
          They're 2 platter - 4 head design. They don't say explicitly but you can figure it out by looking at smaller drives in the series and the number of sectors on the smaller drives compared to newer ones.
          • Scenic
            o.O
            • Sep 2007
            • 2642
            That pdf doesn't mention platters/heads anywhere. And it's not consistent per drive model either..
            For example the 500GB WD5000AAKS has anything from three 167GB platters (early models) to a single 500GB one (late models) all under the same model number.
            It's easy to look up, as the firm/hardware revision is always displayed after the main model (for example WD10EVDS-63N5B1).
            Shows up everywhere where it shows the HDD model (device manager, HDTune, Everest/Aida64, ...)
            I've contributed to that wiki myself.. (one last use for bad HDDs.. find out what's really inside lol)
            • severach
              • Aug 2007
              • 1055
              I switched my laptop from a 500GB 5400 WD to a 500GB 7200 WD Black. Substantially faster, especially because the electronics on the WD 5400 was defective and made the computer halt for several seconds on disk access every minute or so.
              I warrantied the 5400 WD complaining that the performance was poor. They thought I didn't like the slow 5400 speed so they subbed the Black for the return. It was the constant pausing I didn't like but the extra speed is nice.
              sig files are for morons
                master hoarder
                • May 2008
                • 12175
                The RPM is not the only reason why your 7200 RPM drive is faster. The data density of the platters matters a lot too.
                Let's imagine the drives had the same rotational speed and same number of platters. If the heads of both drives were reading a track (let's say 20 mm away from the center of the platter), since the 320 GB has much greater data density, a lot more data passes through any given point on the platter than the 40 GB drive.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Nice one!
                  Do you know exactly what was wrong with the original WD?
                  • severach
                    • Aug 2007
                    • 1055
                    Nice one!
                    No but I think it wasn't a media problem but an unlikely electronic problem that snuck by factory tests. I never seen a drive do that before. The drive only halted for about 5 seconds every minute or so. The drive never caused errors or failed so few would notice the fault. I find faults in a lot of computers by noticing that they are performing slightly under what they should. The drive was in a Compaq HP with the ill fated nVidia chip so I blamed the only likely suspect, the SATA chip on the motherboard. Then I transferred it into a Fujitsu E8110 with all Intel and the drive halted just as much.
                    • yyonline
                      • Jul 2009
                      • 692
                      It's not a problem, it's a "feature"... Intellipark as WD calls it was first introduced in the Caviar Green desktop drives. It parks the heads after a ridiculously short period of inactivity. Then it started showing up in laptop drives. So far, I've only seen it in Caviar Blue drives larger than 320 GB. There is a wdidle3 utility that is sometimes successful in disabling the head parking. I've had it work for some drives, and fail to work for others. The aggressive head parking is more of a problem for some systems than for others. Some handle it flawlessly. Others freeze every time the drive wakes up.
                      • gjlpereira
                        MacBook Pro A1708 - CPU extremely slow, locked @ 0.39ghz; fan full speed
                        by gjlpereira
                        Hi forum.
                        I'm working on a macbook pro, model a1708, that is running extremely slow.
                        Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
                        One other symptom of the problem with the machine is that the fan is always running at full speed.
                        This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like...
                        09-06-2022, 07:45 PM
                      • nissimezra
                        HP Notebook 15-dy1731ms VERY SLOW
                        by nissimezra
                        Hi to everyone.
                        I never seen something like this. I have HP Notebook 15-dy1731ms motherboard: DA0P5DMB8CO REV C that is very very slow. I tried all the basic, updating the bios, replacing ssd, replacing ram, soldering all coils, reflow CPU power supply but the laptop is still very very slow. Never seen a motherboard that is slow. CPU power suppliers 1.8 volts, the cpu barely getting hot.
                        What left for me to do is reflow the CPU and try manually programing the bios chip with programer.
                        Anyone have any idea what it can be?
                        04-13-2023, 02:45 PM
                      • EthanMai
                        DELL PRECISION 3440 SFF X4N41 10th ST-3L0GZB3 25Q256 Slow startup, needs cleaning.
                        by EthanMai
                        DELL PRECISION 3440 SFF X4N41 10th 25Q256 Slow startup
                        ST-3L0GZB3
                        needs cleaning.
                        Please help me clean up the slow startup dump if you have time. Thank you....
                        07-05-2024, 11:43 AM
                      • mo000
                        ACER CONECPT D VERY SLOW
                        by mo000
                        Hi
                        acer concept d intel i7 11th GH67G LA-L211P REV 1A 17-03-2021
                        the laptop dead by water on keyboard
                        i open the laptop i don't find any water on the motherboard or any damage
                        the laptop turn on without battery
                        i found shorted mosfet on smbus battery i remove it the laptop turn on with a battery but not charging
                        the big problem is the laptop is very slow
                        cpu works with low speed almost 0.7ghz
                        i do clean me bios but samething
                        what make laptop works with low profile and very slow the display takes long time.
                        06-10-2024, 04:27 AM
                      • resistor83
                        Macbook pro 15" 2011 A1286 stuttering and slow
                        by resistor83
                        hi all, I have a problem with my macbook pro 15 inch, late 2011 with SSD, AMD Radeon HD 6770M dedicated video card and Intel HD 3000 integrated card.
                        I use the computer occasionally at home and a few weeks ago I noticed that the battery was charging very slowly, I changed the power supply with a new original one and the problem remains. I also changed the battery to a compatible one and the problem persists. Now for a few days I have also noticed that the computer after a few minutes from starting it jerks and becomes very slow. However, this problem arises in several ways:
                        02-09-2023, 03:19 AM
