ATI + WinTV2000 = FAIL
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    I have a Shuttle ST61G4 and I mace the mistake of trying to use xp with it...
    The thing has both an ATI chipset and an ATI GPU:
    specs:
    Pentium 4 HT 2.8ghz
    ATI Radeon RS300 Chipset
    ATI Radeon x1300 GPU
    and I installed a hauppauge wintv-go card in it. it has a brooktree 878 chip in it
    I installed all the drivers and updated directx.. but whenever I start WinTv200 (the tv viewer/recorder), the audio from the tuner starts and immediately after, the system locks up.
    I had no trouble using the card under ubuntu 11.10 using TvTime and some ALSA settings... unfortunately there is no way to RECORD from the card under linux w/o mythtv (which I have never been able to make work), hence why I am trying to make windows work.
    any suggestions or am i looking at getting a different tuner card?
    sigpic
    (Insert witty quote here)
  • mockingbird
    • Dec 2008
    • 5488
    Re: ATI + WinTV2000 = FAIL
    VirtualDub is what you need.
    Record to lossless like huffyuv, and then encode into whatever you want (And apply whichever filters, deinterlace, brightness adjustments, etc...). Make sure you are not getting any dropped frames when recording. Might want to disable system restore or things like that that use the HDD.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      tried it once, didn't like it.
      if this were my dazzle, then it would be one thing. this is a tuner... last i tried, virtualdub didn't have port selection/ channel tuning support. granted, it is an old analog tuner, but by default it goes to the tuner and not the composite input... which for my setup is a bit useless ( I plan to do all my stuff via the composite input).
      sigpic
      • mockingbird
        • Dec 2008
        • 5488
        My suggestion is to first capture the video with VirtualDub, and then use whatever you want to do the post-processing. WinTV-GO is probably the one of the best-supported cards in VirtualDub, so there must be a way to select the desired input. This is what everybody uses.
        Heck, people are even using VirtualDub today for low-cost 1080i capture, but that's a different story.
        • toastygoodness
          • Jul 2005
          • 813
          you will either need to use virtualdub or vlc, you probably don't have a choice unless you switch operating systems (a box like that should have badass mythtv support right?)
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            well, If I could figure out mythtv, that is. I never have been able to... I have never gotten past getting mysql to play nice...
            the stock hauppage program has never given me issues until now; the recording quality seemed ok. I was kinda looking for advice to get it working, but obviously that's not what the answers have been.
            I may retry virtualdub, as at the time I was trying to use it with a webcam and I wasn't paying attention to any tuning settings or the like...
            unrelated- were there ever any QAM tuners for PCI or are they only found as PCI-E tuners?
            sigpic
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              its not a viewer issue. when I tried to access the card with virtualdub the same thing happened.
              the drivers are up to date...
              must be an issue with the ATI chipset... I used to use the card+wintv2000 on a HP mini-tower with nearly identical specs (identical CPU, same ram, nvidia GPU, Intel chipset).
              so, what cards do play well? suggestions? (I may also look to upgrade the tuner in my main rig as well, which uses a PCI-e tuner).
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                tried an open source driver, no improvement.
                maybe an IRQ issue?
                sigpic
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  fixed it
                  http://www.hauppauge.com/site/suppor...8.html#lockups
                  it was in the FAQ... and their advice worked (I went back to the OEM driver too).
                  I feel a bit dumb...
                  sigpic
                  • Sus256
                    HISENSE 65E7KQ PRO - no boot
                    by Sus256
                    Hi all!
                    HISENSE 65E7KQ PRO
                    RSAG7.820.13512 - chassis
                    MT9618BAATAB - cpu
                    RSAG7.820.12059 - power
                    HD650Y3U77 - panel
                    KLM8G1GETF - emmc
                    Replaced emmc.
                    Terminal log
                    UART
                    AC_ON
                    E-B
                    FDE enabled
                    06-01-2025, 02:11 AM
                  • dragometin
                    Hitachi 40HYC42
                    by dragometin
                    TV Model: Hitachi 40HYC42
                    Power Supply: 17IPS71
                    MainBoard: 17MB95M
                    Panel: VES400UNDS-2D-NO3
                    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                    Is there any variants on 17IPS71 power supply's?
                    UART output pins 10 and 12 on scart connector:
                    Code:
                    12:24:04.595
                    08-08-2024, 05:53 AM
                  • DXseekerMO
                    Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
                    by DXseekerMO
                    I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
                    As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
                    09-15-2021, 05:15 PM
                  • Mark R
                    Does Changing Out Caps In A Tuner Effect FM Reception
                    by Mark R
                    "TQ" Subject at hand is a Marantz 120 tuner. The tuner lit up but no output. Recapped the entire unit. Before it was working fine tuning in Stereo and Mono. Now it just about tunes Stereo and some of the mono stations are weak. Nothing else was changed. When you do hit a stereo station the stereo lamp will come on but flickers as it's trying to hold the MPX signal.
                    I don't see how bringing the unit back with new caps checked by my Sencore LC103 would effect the FM section. Every Value is as it was from the factory?
                    Any Thoughts?
                    06-11-2024, 07:04 PM
                  • Perry Babin
                    Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
                    by Perry Babin
                    This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
                    04-03-2024, 10:40 AM
