Does Changing Out Caps In A Tuner Effect FM Reception
  • Mark R
    • Oct 2023
    • 92
    "TQ" Subject at hand is a Marantz 120 tuner. The tuner lit up but no output. Recapped the entire unit. Before it was working fine tuning in Stereo and Mono. Now it just about tunes Stereo and some of the mono stations are weak. Nothing else was changed. When you do hit a stereo station the stereo lamp will come on but flickers as it's trying to hold the MPX signal.
    I don't see how bringing the unit back with new caps checked by my Sencore LC103 would effect the FM section. Every Value is as it was from the factory?
    Any Thoughts?
    sigpichttps://www.badcaps.net/forum/image....ine=1697924519
    • 31304
    tuners work by mixing a signal from a local oscillator with a filter to select the incoming frequency,
    if you change the caps related to the local oscilator or the filter/mixer you will need to ajust it after.
    a service manual helps
    • Mark R
      • Oct 2023
      • 92
      Thanks... Yep all caps were changed... If I had known that I would have left those caps along. I don't have any AM/FM alignment equipment. I have everything else but. I was looking to pick up a SENCORE SG80. But they are none around. I do have the Service manual but that procedure is very involved. I was going to spend the money for a Alignment unit but I think I'll pass.
      Since I have never done an alignment but have seen it done on Youtube, It's involved. In all my years of electronic repair I have never done an AM/FM alignment. I think I'll pass. The unit is now on Ebay for Repair or Parts.
      So now if I have to recap the Marantz 150 tuner... I'll have to locate those caps that work with FM reception.
        • 31304
        i would just put the display on a known frequency of a station and then tweak each of the variable capacitors for the strongerst signal.
        it takes a while because they effect each other, so you have to go over it several times.
        • Mark R
          • Oct 2023
          • 92
          Yeah that's one way.. But I rather have the SENCORE SG80....But they are no where to be found for sale in the world.... Real Hens Teeth.
            • 31304
            or use a mini sig-gen like shango66 on youtube does.
            go watch his video's!
            • Mark R
              • Oct 2023
              • 92
              Well I found a Sencore SG165 with the original Box and manual and test leads on Flea Bay. Also downloaded the full manual which has calibration and skids and well as operation ... 71 pages. Looks clean Except it does power up. He had pics of the insides which looked very clean. I'm guessing the power supply is farked. Probably caps or something minor in the supply.
              So I gave it a shot and pulled the trigger. When I get it working and calibrated which looks simple I might learn something. I'll put my self thru school and try to do the Marantz 120 and do my first alignment. I know I'll be pulling my hair out trying to make it work. But it'll be fun.
              This is the part where you Laugh....L.O.L.
                • 31304
                how much is the sencore?
                the chinese pocket device is 70-130$ and can probably do far more than the sencore
                it has a color spectrum analyser and a generator that can do AM/FM and subcarrier etc.
                if i did much radio i'd probably get one.
                • Mark R
                  • Oct 2023
                  • 92
                  Sounds like a winner... Not up on the Chinese devices. But it has to do modulation Pilot freqs and all the stuff that a Standard alignment generator would have to do. I picked the Sencore up for cheap about $140.00 not counting shipping.. I collect old Vintage test gear. I'm still looking for the Digital Version which was the newer model. The SG 80. That unit is sought after by most techs and are like hens teeth.
                  One went up on Ebay and lasted 10 Min. I missed it as it sold before Ebay could notified me as I have it on my Favorite List and it went fast before I could get the notified.
                  Check out the SG80...this one sold 6 years ago....
                  https://offerup.com/item/detail/6ae7...d-0fb3482f6ff8
                  See if you can pick a unit for me that does what the SG80 does above. Give me a Part Number and Make... I don't know enough about them.
                  Also..took some pic's of that possible Solder bridge you caught. It's close but not shorted... Unit is still working great. Click image for larger version
ID:	3294277 Click image for larger version
ID:	3294278 Click image for larger version
                  • Mark R
                    • Oct 2023
                    • 92
                    Disregard the above pic's I posted them hear by mistake.
                    • Xenon-Codex
                      Luxman T-230 tuner missing stereo
                      by Xenon-Codex
                      I got it partly working, but it mostly stays mono, or goes very distorted stereo if I turn the separation trimmer more. What else needs to be adjusted? Mono sounds clean. I think it may have cold joints as the L-channel drops also off at times.
                      01-25-2024, 12:22 PM
                    • Mark R
                      Marantz Model 120 Tuner Craziness I am Stumped!
                      by Mark R
                      My Marantz 120 Tuner stopped receiving Stereo signals. It works fine other then Stereo. I have a fully loaded shop here with all test equipment except and RF signal Generator.
                      I get great reception on FM so I have used that signal troubleshoot. I have been all over the MPX board and replaced all caps. Also the entire power supply caps were replaced.
                      All Voltages on the MPX board are good... all Transistors Good...All Diodes Good and other components.
                      The stereo lamp is good as I powered it up and it lights. The signal flow to that lamp is unbelievably...
                      10-20-2023, 01:25 PM
                    • DXseekerMO
                      Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
                      by DXseekerMO
                      I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
                      As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
                      09-15-2021, 05:15 PM
                    • kodiac
                      rx-750 pioneer stereo memory
                      by kodiac
                      I have rx-750 pioneer stereo and the stored radio stations in the memory does not stay in the memory very long.
                      Does anyone know where the memory is located in this stereo and how it is powered up?
                      It does not have a battery backup.
                      Does the memory use a capacitor for its power supply?
                      thank you
                      11-22-2025, 05:49 PM
                    • jean luc ferre
                      display screen problems after changing motherboard
                      by jean luc ferre
                      First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                      I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                      Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                      Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                      09-11-2025, 10:28 AM
