My poor Bedside PC :'(
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    having some problems with my "bedside PC"
    Issue:
    -once it freezed up on my in the middle of using cPanel File Manager on my website... nothing resource-intensive was running otherwise.
    -occassionally, when I get home, it's off, even though I swear it was on when I left the house.
    other than that, I haven't had any problems at all with it...
    other information:
    -folding@home SMP 24/7 (some nights it's off, some nights it's on, even though it's like a foot from my head I engineered it from the ground up to be silent)...
    specs:
    -ECS motherboard with intel G31 chipset (LGA775)
    -Core 2 Duo E6600 2.4GHz
    -2GB DDR2 (2x1GB)
    -40GB 2.5" SATA laptop HDD, screwed into the PCI slot hole on the case... pretty but it works fine.
    -Seasonic Tornado 300W APFC PSU
    what could be wrong?
    thanks...
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: My poor Bedside PC :'(
    Not much to go on there... overheating?
    Ludicrous gibs!
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      I don't think so; it's a Core 2 Duo so it doesn't use a lot of power, additionally, the case fan is blowing out barely-warmed air.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        ecs mobo?
        I'd begin there... ECS hasn't been known for being the best quality (but they sure beat ASUS).
        sigpic
        (Insert witty quote here)
        • Agent24
          I see dead caps
          • Oct 2007
          • 4973
          • New Zealand
          I hate to say it but... ECS?
          -David VanHorn
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            BESIDES my $30-newegg-special-several-years-ago motherboard, what else could be el problemo?
            thanks
            • Agent24
              I see dead caps
              • Oct 2007
              • 4973
              • New Zealand
              Probably just about anything, but I'm sure you already knew that.
              Probably time to start removing non-essential parts and swapping parts out and see if you can stop the freezing and narrow it down a bit.
              -David VanHorn
              • c_hegge
                • Sep 2009
                • 5219
                thanks
                Nothing. ECS are pure junk.
                Extremely Cheap <You know what goes here>
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Extremely Cheap Shit
                  Lol.
                  Yes but that wouldn't cause it just to shut off or something right?
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Lol.
                    no. thats like saying a cheap part in a car would only cause it to not start...
                    sigpic
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      I'd think it would show some physical signs of failing.
                      Unless it's got a mild form of Asus death syndrome
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        I kind of remember a thread from not too long ago (couple months?!) where someone had a ECS G31 µATX board which was completely dead to the world, without any visible signs of failure.
                        edit: turned out to be almost a year ago . Board was a ECS G31T-M
                        https://www.badcaps.net/forum/showth...hlight=ECS+G31
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          Mine's a G31T-M7
                          And it still froze up on me once a few days ago, I haven't used it since, until now...
                          I don't think (even with a new PSU and HDD) that my issues is resolved.
                          Here's a stock image of a G31T-M7 for your viewing pleasures...
                          http://www.ascendtech.us/mmASC/Images/G31TM7V10-001.jpg
                          Any ideas?
                          • c_hegge
                            • Sep 2009
                            • 5219
                            It could have bad caps OST as well as bad "elite" polies will fail without bulging.
                            EDIT: It looks like the 3 VRM high polies might only be 270uF (they should be 470uF when there are only 3) ECS
                            • alltvrepairs
                              Samsung S22 plus reboots and heats up occassionally or after use
                              by alltvrepairs
                              I’ve noticed that my S22 occasionally freezes and shuts down—about once a day. I’ve already done a factory reset, installed only the essential apps, and updated the software. I also tried enabling power-saving mode to limit the CPU to 70%. This reduced the frequency, but the issue still occurs from time to time.
                              When it shuts down, the casing becomes hot and stays that way. I then need to restart the phone by holding down Power and Volume Down.
                              I’ve run diagnostics and enabled Developer tools to monitor CPU, GPU, and refresh rate. Unfortunately,...
                              Today, 06:00 AM
                            • harp
                              can fanless heatsink replace poor original on RX26PG2
                              by harp
                              I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                              06-25-2025, 10:56 AM
                            • madan1
                              Diesel heater emergency power supply / poor man's UPS
                              by madan1
                              Hello everyone.
                              Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
                              12-18-2022, 08:05 PM
                            • howardc64
                              Fixed Sceptre U435CV-U Another bad cap from poor cooling
                              by howardc64
                              39uF 160V cap bulging (see pic). Replaced (temporarily with one thats too tall for the space) and fixed.
                              But root problem is once again high heat density (18mm between board and back cover). Combined single board main+PSU and no fan.
                              While shopping for Nichicon replacement, all 10k hr @ 105C was 17.5mm height which barely clears the rear case. Failed cap was 13mm tall with much fewer choices.
                              Seeing so many newer TVs die by heat (BGAs etc) Need to figure out an easy way to mount fans ...
                              08-05-2022, 11:03 AM
                            • barry wilkins
                              Citreon C3 car radio poor reception
                              by barry wilkins
                              I have a problem with the radio in my car ,its been going on for some time now.
                              Just poor radio reception,it has got a small aerial at the back of the car .
                              I can see a nut head holding the aerial by looking through a hole where the rear light dome is ,but it looks as if I will have to remove the roof lineing to get at it.
                              What I dont know if there is an amplifier any where ?
                              I think its a Bosch radio but it does not have a name on it.
                              Does any body have any info on this?
                              Barry
                              01-05-2020, 01:31 PM
