Seagate 1tb Click Of Death
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Seagate 1tb Click Of Death
    Originally posted by Scenic
    Seems like it really depends on your luck how long a HDD lasts.
    For example, I've got 2 identical Seagate Barracuda 7200.7 120GB SATA HDDs (Model ST3120026AS).
    One has 2285 power on hours (95 days .. almost nothing) and 1 pending + 1 bad sector, the other has 42102 power on hours (1754 days.. that's almost 5 years! ) and no bad sectors at all.
    The UDMA CRC error is from a flaky connection (crappy SATA cable)
    Temperature difference is because one was running for over an hour, the other was just connected for a few minutes.
    Although the "raw read error rate" and "hardware ECC recovered" (the same?) raw values are absurd, the normalized values show that both drives are experiencing a huge number of read (and seek) errors, and only the error correction code is keeping things looking OK.
    You might also want to check what's with the left one having 3180 power cycles in 95 days... power cycling over 33 times a day on average is not at all good for the drive.
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Seagates are known for reading out abnormal values on those two attributes. Every Seagate drive I've had, even my new 2TB drive, read like that out of the box.
      Ludicrous gibs!
        master hoarder
        • May 2008
        • 12175
        I can confirm that as well.
        Seagate probably uses those parameters to measure something else.
          master hoarder
          • May 2008
          • 12175
          Originally posted by momaka
          I just saw one like that 2 weeks ago at work. It was a Seagate SATA drive, not quite sure what model and size... most likely a 160 GB 7200.8. The drive wasn't clicking but rather beeping randomly. At first I thought it was something else, but then I went to plug in my flash drive with my utilities and noticed the noise was coming from the computer. When I checked the SMART log, the bad sector count was sky-high, up in the 1000 range as was the current pending sector and event count. My boss wasn't there that day, so I told another co-worker of mine to tell him about it. However, chances are that if that computer is working, the drive is probably still in it. If it's still there next week, I'll grab a copy of the SMART log.
          Just to report that hard drive has now failed. I'm not really surprised, though. Actually it failed about 4 weeks ago, but I forgot to post about it. Only remembered now after I saw the smart logs on my flash drive. The bad sectors finally reached the files for the operating system.
          You can see the results in the Seagate ST3160812AS (3).txt file.
          Particularly, have a look at the Reallocated Sector Count under Raw Value.
          When it was still working way back, I ran a HDTune test on it. Anytime I did a big read or write operation, the bad sector count would go up. The HDTune test alone increased the bad sector count by 1000. Probably a bad head stack. I've saved the hard drive. Will open it (if I don't forget) the next time I go to work (don't know when that will be, though).
          Also, while I was browsing my flash drive, I found SMART logs of 2 other identical hard drives as the failed one above. Those haven't failed yet, but looks like they might soon too.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            ...And now you see why I bought a 320GB drive for my desktop...
            I still do not fully trust these larger drives... they seem to die quick.
            sigpic
            (Insert witty quote here)
              master hoarder
              • May 2008
              • 12175
              #26
              The drives I posted about above are all 160 GB.
              I used to think that Seagate and WD are about the same, but after seeing quite a few dead Seagates lately (both old and new), I'm now leaning towards WD just being better.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                sorry about that.
                sigpic
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  #28
                  these are all old drives with lots of hours on them and unknown treatment history.nothing to base quality or lack of on any brand.the seagate 1tb 7200.11 did have serious issues though.
                  sorry about that.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    I've been saying that for years but I always get flack for saying so.
                    I think there's been 3 1Tb-up fails show up here just this week....
                    Mid last year I figured they'd been around long enough to try some 1TB WD Blacks in the wife's media server just to see how well they work out.
                    I got six.
                    One has completely shit itself and another drops out of RAID every few days for no particular reason. [Passes all tests after.]
                    That's basically a 16-33% failure rate [depending on how you look at it] in the first year..
                    Yeah, they can be RMA'ed but it's a PITA and a big honkin' waste of my time.
                    Compare that to the roughly 40 WD 250gb and 500gb I have in service with zero fails for 2+ years now. [Some have been in use for 4 years.]
                    I'm going back to my 500gb Max policy for as long as that's possible.
                    Bigger drives are just too unreliable and too much trouble.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • mockingbird
                      • Dec 2008
                      • 5484
                      #30
                      I don't touch Caviar Green drives, though I think there is a way to disable head parking on them...
                      so far, I have had zero failures with blues on customers PCs, but I did have one failure with a black. Blacks do have problems with quality control though.
                      I also have an RE2 I took out of a WD external enclosure, though never got a chance to use it yet... Wonder how those drives are.
                      Regarding Seagate, someone just bought a system with a 1TB 64MB cache Seagate (That's the only thing available due to the shortage). The drive did have some kind of head parking going on, but I was darned if I could figure out how to disable it. Seagate claimed that it's not the parking, but there WAS this odd clicking every so often that irked me. The customer INSISTED on a 1TB drive, otherwise I never encountered one before.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        A number of my 250gb and 500gb are RE2.
                        Had no problems with them at all.
                        Some need a firmware update. [Which is easy.]
                        Those have model numbers ending in "YS" as so WDxxxxYS.
                        Only the ones with -just- YS at the end need the update.
                        For example WDxxxxABYS doesn't need it.
                        - Dr Seuss
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          RE drives are specially made for RAID. Non-RE western digital drives have tremendous issues wit RAID. If you want to do any sort of raid with them you have to get. RE versions!
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Not really.
                            Standard drives like Blacks work fine.
                            [As I recall BCN runs on Blacks in RAID now.]
                            RAID was around long before WD came up with RE and WD worked fine on RAID.
                            I've used zillions of WD__BB and WD__JB in RAID and never had issues.
                            The drives with problems are usually those with firmwares designed to save power. [Like the Greens.] They will spin down to a low power state too soon and just at the wrong time, the RAID chip thinks they are dead because they aren't available, and they get marked 'bad' by the RAID.
                            Drives that are optimized for other things can possibly also be a problem. Depends what they did to the firmware.
                            RE -are- better because their firmware is optimized for RAID, but drives with standard firmwares work fine too.
                            - Dr Seuss
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5037
                              • New Zealand
                              #34
                              I still have a DTLA-305040 (40GB 5400rpm) deathstar that makes a click-feep sound every time it has to read a lot of files. Especially a bunch of small ones. It refuses to die completely though.
                              I had a couple deathstars that made that sound sometimes. They got continually worse over a period of months and eventually wouldn't show up in the BIOS.
                              Originally posted by Krankshaft
                              I ended up buying a replacement Seagate 2tb too ! Got it for 125 shipped blew the local prices out of the water I figured due to the shortage which some are estimating will last from mid to the end of 2012. That prices were only going to get higher. The drive is made in China with a 3 year warranty.
                              Is it a ST2000DL003?
                              There's a thread on Seagate's forums which seems to suggest those may have a firmware issue.
                              I think that will end up being a useless exercise though, because now that we can get 500GB+ onto one platter, any new drive which is 500GB or less will potentially be a new type one with just 1 platter and capacity reduced in firmware, still the same higher areal density and same problems (if that is what causes the problems)
                              -David VanHorn
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Not really because with a single platter there are fewer issues with keeping all the heads on different platters simultaneously aligned to the smaller target zones.
                                - Dr Seuss
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  #36
                                  Ah, thanks for the info. It's an ABYS, so I am safe. How's the performance compared to newer Caviar Blue for regular desktop use?
                                  All RE drives do is *officially* support TLER/CCTL SMART commands... I wouldn't be surprised if they're the same on the inside as blacks (but the firmware IS different to allow TLER/CCTL commands to be accepted and remembered on cold reboots).
                                  Not really.
                                  They're not supposed to, but if they're working they're working.
                                  That's because those drives properly supported TLER/CCTL commands until WD intentionally REMOVED them from newer series to propagate another profit sector for themselves.
                                  There is no such thing as *good* hardware RAID with Windows... Someone made a great thread on StorageReview a while back explaining the whole thing. I think I linked to it on this forum in one of our other threads discussing RAID. The only good implementation of RAID is ZFS, and that runs in software and can be used with regular drives that do not support TLER/CCTL commands.
                                  Having said that - I'm going to have to agree with you that bios/hardware/software RAID in Windows or otherwise works just fine sometimes out of the box. I have a customer that insisted on setting up a RAID 1 mirror with two Caviar Blue drives on the AMD SB850 Chipset... Worked just fine. I wouldn't do it though.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I dunno. I don't buy the Blues.
                                    I only buy RE or Blacks since I went to SATA.
                                    - Dr Seuss
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      If we're talking about RAID I may as well pitch in that I use RAID on two Seagate Barracude drivers. They're the entireprise versions (forget what they're called )...They're 250GB SATA drives, attached to the built in controller on the mobo with Windows software mirrored RAID...
                                      The boot drive is a 100GB Maxtor...
                                      This is the Windows Server 2003 PC that's my network file server, backup server, and Minecraft server
                                      PS: just noticed on Newegg they carry Lenovo hard drives. They any good?
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5037
                                        • New Zealand
                                        #39
                                        I always read that this was the case.
                                        In fact, that is what people used to do - and they just changed some parameters with a firmware settings tool to allow to use the drives in RAID.
                                        Western Digital of course figured this out and disabled the modification, forcing people to pay more money for the RE models.
                                        -David VanHorn
                                        • kc8adu
                                          • Nov 2003
                                          • 8832
                                          • U.S.A!
                                          #40
                                          lenovo would most likely be hitachi.
                                            HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                            This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                            09-12-2024, 02:00 PM
                                          • reformatt
                                            Intel iMacs, 3rd party SSD failures and Fusion setups
                                            by reformatt
                                            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                            12-18-2024, 10:34 PM
                                          • federalhouse
                                            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                            by federalhouse
                                            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                            **Background:**
                                            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                            **What I've Tried So Far:**
                                            1. I accessed
                                            08-01-2024, 07:03 PM
                                          • perfm2
                                            HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                                            by perfm2
                                            So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                                            Steps taken in my usual process.
                                            Reset security settings in the BIOS
                                            Ensure existing HD comes up into the OS
                                            Shut down the laptop and disconnected the main battery
                                            Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                                            Replace battery connector and close up the laptop
                                            Insert my USB drive with my Windows 10 image I've...
                                            03-21-2023, 08:45 PM
                                          • karto95
                                            Repairing a Seagate hard drive with damaged logic board
                                            by karto95
                                            I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                                            I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                                            If anyone has any suggestions or experience with this...
                                            03-21-2023, 04:05 AM
