I found an old Dell WebPC with Win98 on it at Goodwill for $5 and it boots up fine, but just after the welcome screen appears I get a message saying "Windows did not detect a mouse attached to this computer" "You can now safely attach a serial mouse now" well I can't do that because there are no serial or ps/2 connectors on this thing....just usb. I tried starting in safe mode and deleting the usb controller and mouse driver in hopes that windows would reinstall them correctly after re-boot but nope. The bios has very limited settings for the controllers so no go there either....any ideas?
Dell WebPC mouse problems
Re: Dell WebPC mouse problems
Is this 98 first edition or second edition? a lot of usb mouse drivers are no good for first edition.sigpic
(Insert witty quote here) -
Does the BIOS have the "Enable USB Legacy Support" option?"pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
Yes it does and it is enabled.....I can only boot in safe mode and then I have to navigate using the keyboard, the cd-rom drive is absent in safe mode so I can't install drivers that way.....there is no floppy drive nor an empty bay to put one in and it uses 3 usb ports and NO ps/2 ports, in safe mode no usb devices will be detected if plugged in so I can't use my external floppy drive either.Attached Filesif you find these attachements useful please consider making a small donation to the site
Try the Maximus-Decim Native USB driver (latest version is 3.5, available here). It's basically a third-party replacement for the whole Win98 USB stack, works much better and has native support for most USB devices.
That still leaves the issue of how to get it onto the machine, though. Does it have ethernet?Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by DProf.Good day great minds, please I have this Dell Inspiron 7586 2 in 1 Laptop, anytime I put the SSD In it and it load to window the mouse will not work but if I enter bios settings the mouse will work fine, if I go back to window it will not work and if I remove the SSD also the mouse will work well, but the issue is no with the SSD because I have tried several other SSD but the issue remain.
Please can anyone help with a solution?
God bless you. -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by CaimanoI am trying to repair a Dell Inspiron 3793 which has problems with start up, no battery charging and fan not running. I believe the Bios (probably the EC Region) is corrupted.
The board is FDI45-LAJ091P REV 1.0 A00
Processor i7 1065G7 with GPU
This MB has 2 Bios Chips (one 8MB and one 16MB chip).
I am trying to reload a new Bios with clean ME region, new main region and new EC region.
I attach the dumps of the 2 chips.
I successfully used ME analyzer to identify ME, PCH and PMC versions and used Flash Image Tool to install ME, PCH and PMC cleaned regions....-
by stakrzysiuHello,
i have here a Dell Vostro 15 5501
REG Model: P102F
SN: 1WD5103
there is a problem that it shows screen after 1 min.
Is this caused by me?
Can someone clean me for me? Then i will try.
Thank you very much
Best regards...-
- Loading...
