Problems extracting from Dell Bios Update.Inspiron 3793
  • Caimano
    • Nov 2020
    • 54
    • Italia
    I am trying to repair a Dell Inspiron 3793 which has problems with start up, no battery charging and fan not running. I believe the Bios (probably the EC Region) is corrupted.
    The board is FDI45-LAJ091P REV 1.0 A00
    Processor i7 1065G7 with GPU
    This MB has 2 Bios Chips (one 8MB and one 16MB chip).
    I am trying to reload a new Bios with clean ME region, new main region and new EC region.
    I attach the dumps of the 2 chips.
    I successfully used ME analyzer to identify ME, PCH and PMC versions and used Flash Image Tool to install ME, PCH and PMC cleaned regions.
    I am having problems in extracting with DellPfsExtract the Main Bios region and EC region from the Dell update EXE file downloaded from Dell's site.
    I tried different versions of DellPfsExtract.exe (from 3.6 to 5.1) but with all of them it says "Done! " but no folder is created. Python is installed and working fine also with ME Analyzer.
    Can somebody help or try to extract files from update executable? Thanks
  • hoaca388
    Badcaps
    • Jan 2022
    • 12423
    Re: Problems extracting from Dell Bios Update
    Here
    • Caimano
      • Nov 2020
      • 54
      • Italia
      Originally posted by hoaca388
      Here
      Thanks for your help! I spent hours trying to extract the files, but could not make it. I launched Dell_PFS_extract.exe, a new windows opened asking to enter the path of the exe file, dragged and dropped the file, pressed enter, Done!, but no new folder was created.
      Any idea what could be the problem?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12423
        Re: Problems extracting from Dell Bios Update.Inspiron 3793
        Drag ang drop exe bios file to Dell_PFS_Extract file
        • JoWed
          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
          by JoWed
          Hello Community,
          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
          07-01-2025, 09:32 AM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • grimacelord
          Latitude E6530 - Trouble Extracting BIOS Image From EXE
          by grimacelord
          Hi folks,
          I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
          Service tag number for this model is: "JYDWYW1".
          Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
          I have tried:
          • Simply extracting with 7zip
          • PFSExtractor
          • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
          • Check Temp folder
          10-26-2023, 08:15 AM
        • Lexsmash85
          Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
          by Lexsmash85
          Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
          Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
          USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
          08-06-2025, 03:41 AM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
