Dell WebPC mouse problems
  • gorr35
    • Nov 2010
    • 127
    I found an old Dell WebPC with Win98 on it at Goodwill for $5 and it boots up fine, but just after the welcome screen appears I get a message saying "Windows did not detect a mouse attached to this computer" "You can now safely attach a serial mouse now" well I can't do that because there are no serial or ps/2 connectors on this thing....just usb. I tried starting in safe mode and deleting the usb controller and mouse driver in hopes that windows would reinstall them correctly after re-boot but nope. The bios has very limited settings for the controllers so no go there either....any ideas?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Dell WebPC mouse problems
    Is this 98 first edition or second edition? a lot of usb mouse drivers are no good for first edition.
    sigpic
    (Insert witty quote here)
    • gorr35
      • Nov 2010
      • 127
      It is 98SE
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        Does the BIOS have the "Enable USB Legacy Support" option?
        "pokemon go... to hell!"
        EOL it...
        All style and no substance.
        guilty,guilty,guilty,guilty!
        guilty of being cheap-made!
        • gorr35
          • Nov 2010
          • 127
          Yes it does and it is enabled.....I can only boot in safe mode and then I have to navigate using the keyboard, the cd-rom drive is absent in safe mode so I can't install drivers that way.....there is no floppy drive nor an empty bay to put one in and it uses 3 usb ports and NO ps/2 ports, in safe mode no usb devices will be detected if plugged in so I can't use my external floppy drive either.
          • Old Thrashbarg
            • Jan 2010
            • 20
            Try the Maximus-Decim Native USB driver (latest version is 3.5, available here). It's basically a third-party replacement for the whole Win98 USB stack, works much better and has native support for most USB devices.
            That still leaves the issue of how to get it onto the machine, though. Does it have ethernet?
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • DProf.
              Dell Inspiron 7586 The mouse not showing on the windows
              by DProf.
              Good day great minds, please I have this Dell Inspiron 7586 2 in 1 Laptop, anytime I put the SSD In it and it load to window the mouse will not work but if I enter bios settings the mouse will work fine, if I go back to window it will not work and if I remove the SSD also the mouse will work well, but the issue is no with the SSD because I have tried several other SSD but the issue remain.
              Please can anyone help with a solution?
              God bless you.
              01-20-2025, 01:20 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • Caimano
              Problems extracting from Dell Bios Update.Inspiron 3793
              by Caimano
              I am trying to repair a Dell Inspiron 3793 which has problems with start up, no battery charging and fan not running. I believe the Bios (probably the EC Region) is corrupted.
              The board is FDI45-LAJ091P REV 1.0 A00
              Processor i7 1065G7 with GPU
              This MB has 2 Bios Chips (one 8MB and one 16MB chip).
              I am trying to reload a new Bios with clean ME region, new main region and new EC region.
              I attach the dumps of the 2 chips.
              I successfully used ME analyzer to identify ME, PCH and PMC versions and used Flash Image Tool to install ME, PCH and PMC cleaned regions....
              05-04-2022, 11:19 AM
            • stakrzysiu
              Dell Vostro 15 5501 BIOS Problems
              by stakrzysiu
              i have here a Dell Vostro 15 5501
              REG Model: P102F
              SN: 1WD5103
              there is a problem that it shows screen after 1 min.
              Is this caused by me?
              Can someone clean me for me? Then i will try.
              Thank you very much
              Best regards...
              01-25-2025, 05:36 AM
