Dropped laptop
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    #41
    Re: Dropped laptop
    Then the screen is fine - you have the classic nvidia GPU failure instead.
    A working TV? How boring!
    • mockingbird
      • Dec 2008
      • 5484
      #42
      Re: Dropped laptop
      Did you clean the toilet seat after you were done?
      • stevo1210
        • Oct 2006
        • 4156
        Re: Dropped laptop
        Would that explain the "code 43" error I keep getting after installing the nVidia drivers?
        It seems to work okay without the driver working. I'm watching high definition movies and everything on it. No lines or artefacts either.
        • mockingbird
          • Dec 2008
          • 5484
          #44
          Re: Dropped laptop
          There's no problems with the GPU.
          Be more specific with the model, I can point you to the correct driver.
          • stevo1210
            • Oct 2006
            • 4156
            Re: Dropped laptop
            The GPU is an nvidia 8600GS M. The laptop is a Medion 97310. I'm running Windows 7 64 bit on it. I downloaded and installed the newest Windows 7 x64 nvidia driver for the 8600GS M and well, I got an error code 43. Irony is that I'm running it full resolution at 1440x900 and I'm able to watch movies on it and let it function like a flawless normal computer. I'm just annoyed because I can't get Aero to run because obviously the drivers won't load.
            Other than that issue of aero, every thing else is sweet!
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              #46
              Re: Dropped laptop
              Yes. Working without the nVidia drivers installed is also a common issue when the GPU is on its way out. But now that you mention - don't get drivers from nVidia directly, they won't work on mobile chips. Try here: http://laptopvideo2go.com/ If those don't work either then the GPU is bad.
              • stevo1210
                • Oct 2006
                • 4156
                Re: Dropped laptop
                Oh really? I thought nVidia would at least make an effort to make their mobile drivers proper =.=
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #48
                  Re: Dropped laptop
                  No, it's the computer maker's responsibility to provide driver updates. Which they usually don't.
                  For that GPU i recommend 185.85 Dox Optimized if it's still up there on laptopvideo2go, else google it and you'll likely find it. It's been working fine for over 2 years with my 8400M and has better performance than all other drivers i've tried (including other modded ones).
                  • yyonline
                    • Jul 2009
                    • 692
                    Re: Dropped laptop
                    Nvidia has been providing generic mobile drivers for the GeForce 8 and up.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      #50
                      Re: Dropped laptop
                      When i last checked they weren't providing any. Admittedly, i've been out of the GPU game for 3 years already.
                      • mockingbird
                        • Dec 2008
                        • 5484
                        #51
                        Re: Dropped laptop
                        Ah, I stand corrected. That GPU is indeed part of a defective generation.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Re: Dropped laptop
                          Bad generation GPU? yes. Junk? no (if it is working).
                          Just be sure to keep the cooling clean, once every 6 months you should do a heatsink/fan cleaning (2-4 months if you have cats/dogs in the house). You should probably clean it NOW before you use for anything.
                          sigpic
                          (Insert witty quote here)
                          • stevo1210
                            • Oct 2006
                            • 4156
                            Re: Dropped laptop
                            Okay, tried those drivers and still doesn't work. Looks like the nvidia issue is there. What's required to fix it? just get it reflowed right?
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Re: Dropped laptop
                              ("WRONG!" buzzer)
                              the chip itself is toast. RIP.
                              you got a free "for parts" laptop. as in the drives, battery, RAM, CPU, and odds/and ends for that model/series like the all valuable Drive caddies, display hinges, keyboard, etc.
                              sigpic
                              • stevo1210
                                • Oct 2006
                                • 4156
                                Re: Dropped laptop
                                I managed to grab the 160GB HDD in there (still okay, no bad sectors etc.) and also the 4GB of DDR2 SODIMM for my iMac desktop so that I can run OSX Lion
                                No problems with either one.
                                Now I have a simple question. Laptop still works albeit for the graphics driver issue. If I use it just to play music every now and again it should be okay right? The inbuilt laptop speakers are awesome! Even has a little sub underneath... saves me from bringing speakers to seminar events...
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Re: Dropped laptop
                                  not relaible. the problem could worsen to no video at all (black screen).
                                  sigpic
                                  • stevo1210
                                    • Oct 2006
                                    • 4156
                                    Re: Dropped laptop
                                    Hmm... okay. Not that I care about that since it's a freebie. Better than sitting in the corner doing nothing I suppose.
                                    I might wait and see how long it takes to die and then destroy it in some inhumane way. :P
                                    • stevo1210
                                      • Oct 2006
                                      • 4156
                                      Re: Dropped laptop
                                      I've got Vista Home basic on there now... so I'm just wondering... what's a good media player that's not itunes or WMP? Prefer something with a play list so I can just chuck this on the table at our stall on universities open day.
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        #59
                                        Re: Dropped laptop
                                        Foobar or winamp.
                                        • shovenose
                                          Send Doge Memes
                                          • Aug 2010
                                          • 6575
                                          Re: Dropped laptop
                                          Windows Media Player is actually quite good...
                                          Great iTunes replacement.
