Dropped laptop
  • mockingbird
    • Dec 2008
    • 5488
    Re: Dropped laptop
    You can resell it for at least double. And that is a huge underestimation.
    • stevo1210
      • Oct 2006
      • 4156
      Re: Dropped laptop
      how long of a battery life do you get on it? keep your old battery in your bag, as these units have a backup battery that if stock varta (german made, not a chinese knockoff), will keep the unit in sleep mode while you switch batteries. this makes the somewhat short battery life last a good deal longer.
      I wouldn't have a clue about battery life on the new battery as it just came today. $45 for a genuine Dell battery, and I've verified it's genuine as well. Seems to be using Sanyo cells, but comes with a 3 year warranty... I will see how long this one lasts for!
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Re: Dropped laptop
        good score. how many w/hr? the good ones are 42 iirc. some of the smaller genuine ones were 34.
        definitively keep the old one as well then... having a 2nd battery come in handy.
        sigpic
        (Insert witty quote here)
        • stevo1210
          • Oct 2006
          • 4156
          Re: Dropped laptop
          It says 42w/hr on the new one, exactly as the old one.
          The old one is completely knackered... in fact when you press the button on the old battery, it just flashes 3 lights continually.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Re: Dropped laptop
            ouch. and i thought my old one with 60% wear was bad...
            be sure to do a few full charge/discharge cycles on it.
            sigpic
            • stevo1210
              • Oct 2006
              • 4156
              Re: Dropped laptop
              Ok this is so ass. Brand new genuine Dell battery was full one minute, then gradually went down to 80% as per normal... then went down to 3% and died. What the hell?!
              • stevo1210
                • Oct 2006
                • 4156
                Re: Dropped laptop
                oh what now? 3% charge and now 15 minutes later on the charger it's at 100%? I think the thing needs to be calibrated!
                • mockingbird
                  • Dec 2008
                  • 5488
                  #28
                  Re: Dropped laptop
                  That battery is dead. Kapoot. The last time I saw an actual "calibration" tool for lithium batteries was in an old Compaq Armada.
                  I think all calibration is is draining and charging.
                  If you want to rebuild the battery, let me know. I found a good source, $20 for 6 cells, and free shipping.
                  • stevo1210
                    • Oct 2006
                    • 4156
                    Re: Dropped laptop
                    oh joy.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Re: Dropped laptop
                      sounds like you might have been sent a dud with bad cells... sudden drops indicate individual faulty cells...
                      what you should do is set it so when the charge reaches a critical level it does nothing... and run it till it runs out of juice (it may say 0% for a long time). then do a full recharge. see if that makes a difference (this is how you calibrate a d400 IIRC)
                      edit- i was beaten to the punch i see. if my method above doesn't work, do not rebuild it. return it under warranty since you paid that much... besides, the d400 battery is not of standard construction.... it has some sort of a clipped in cover and a shell, not two glued halves like most batteries. I have yet to figure out how to open my old battery... so far, all i know is the front of the battery has a long clip on its edge that is not glued.
                      sigpic
                      • stevo1210
                        • Oct 2006
                        • 4156
                        Re: Dropped laptop
                        Okay, so I've decided to buy it after some guidance from this thread. I'm not too over;ly worried if it doesn't turn out to be easily fixable, there's always ebay to resell it.
                        • stevo1210
                          • Oct 2006
                          • 4156
                          Re: Dropped laptop
                          Hold on a minute here... seems like I've been mistaken!
                          The laptop is a Medion MD96420. It has a Core 2 Duo, not a Core i7.
                          Specs are...
                          * Intel® Core™ 2 Duo processor T5800 (2.0GHz, 2MB L2 Cache, FSB 800MHz)
                          * 17" TFT WXGA Widescreen Display 16:10 cinema format 1440 x 900 Pixels
                          * NVIDIA® GeForce® 8600M GS DirectX 10 graphics with 512MB GDDR2 memory with HDMI digital audio/video output
                          * 500GB hard drive
                          * 4GB DDR2 SDRAM**
                          * Wireless LAN 802.11b/g/draft-n with up to 300Mbit/s
                          * DVI & HDMI Digital AUDIO/VIDEO out
                          * Blu-ray Player
                          * Integrated webcam
                          Medion Akoya MD96420 | $1,499
                          • stevo1210
                            • Oct 2006
                            • 4156
                            Re: Dropped laptop
                            Shit. 8600M graphics, is that the one affected with dying chip sets due to overheating? Yes or no to buying this thing home? :S
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Re: Dropped laptop
                              yes, nvidia doomsday graphics.
                              if you plan to keep, then think long and hard before you buy. my laptop with similar graphics does alright... but it was well taken care of. yours, perhaps not. I would not buy to keep since it is already damaged... understand that you are gambling if you buy.
                              if you plan to sell, check prices on ebay AU first. if the prices are decently higher than what you have, sell it in whole as-is, if you try to open and part it it might fall apart since it was dropped...
                              sigpic
                              • mockingbird
                                • Dec 2008
                                • 5488
                                #35
                                Re: Dropped laptop
                                Not worth $100.
                                • toastygoodness
                                  • Jul 2005
                                  • 813
                                  Re: Dropped laptop
                                  Originally posted by mockingbird
                                  Not worth $100.
                                  +1. That guy's ooooooollllddddd....
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Re: Dropped laptop
                                    sounds like my laptop (dell latitude d630) with beefier graphics, an older cpu, a flimsier case, a bigger hard drive, HDMI, and blueray.
                                    I paid $250 for mine in fully working and A grade condition (one invisible scratch).
                                    If it had a working lcd but nvidia 8xxx graphics, ok, it might work
                                    if it had a non-nvidia graphics but a bad lcd, then that could also work out.
                                    Both is too much...
                                    sigpic
                                    • stevo1210
                                      • Oct 2006
                                      • 4156
                                      Re: Dropped laptop
                                      ok so this isn't a good deal, looks like i'll skip it then
                                      • timmyy
                                        Banned
                                        • Aug 2011
                                        #39
                                        Re: Dropped laptop
                                        The problem is common when any laptop gets fall. my hp laptop also get fall like this and i repaired it from service center. i think the screen of the laptop is changed. so if anyone will buy this he will buy on very cheap rates cause the rate of repairing is gonna be very high.
                                        • stevo1210
                                          • Oct 2006
                                          • 4156
                                          Re: Dropped laptop
                                          OHHHH YEAH. I haven't seen this guy for nearly 6 months now. I turn up to his house to use the bathroom (because I was around the corner) and his brother tells me he's moved far away from home and doesn't come back up here any more.
                                          Anyway, his brother asked me if I wanted anything from his brother otherwise he'll be throwing them out as the brother cleans out the home. Low and behold the laptop is still there! Obviously I took it as the brother was going to chuck it out with Friday's garbage anyway.
                                          It's in the boot of my Civic right now so I'll fish it out in the morning and see what's going on
                                          ... and yes, I got to use the bathroom.
                                          EDIT: got it out of the boot and it works okay? I swear I saw lines on it earlier today. I even drove like a maniac and I heard the thing fly around in the boot! err...
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
                                          • jean luc ferre
                                            laptop hp g72 b52sf screen problems
                                            by jean luc ferre
                                            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                            i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                            06-07-2025, 03:27 PM
                                          • Admin
                                            Other Useful Threads - Laptop Screen Compatibility, Useful ICs, BGA Chip Suppliers, NVidia bumpgate
                                            by Admin
                                            Some sticky topics have been moved to this thread:
                                            - finding a compatible laptop screen with LED-backlight.
                                            Most Common ICs - a list of the most common ICs (Integrated Circuits) required for repairing a laptop
                                            MOST COMMON IC FOR LAPTOP YOU SHOULD HAVE IN STOCK
                                            Let's Talk About BGA Chip Suppliers - anyone who repairs computers at component level has had to order chips from China at some point. Large BGA chips like graphics chips, chipsets and now CPUs are in increasing demand, due to their...
                                            12-27-2023, 03:43 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • almarhum
                                            To fix laptop screen vertical line by working on its EDP cable
                                            by almarhum
                                            Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                                            As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                                            05-07-2024, 02:12 PM
