Newby here, Intel D865 board needs several pushes of the power button to boot
  • henrys
    • Aug 2011
    I feel a complete novice in this present company, although I'm an experienced tinkerer in some other areas (high quality bicycles, some car stuff). I have also had some success repairing water damaged cell phones.
    I love the best dumpster finds thread already, it's right up my alley! I hate perfectly repairable stuff going to landfill, or even recycling stuff for materials, when reuse would be 1000 times better.
    The query is, I've assembled a PC based on an Intel D865PERL from 2003 with a P4 2.8GHz, and it's going great. But to boot it up it frequently takes 3 or so pushes of the power button. It just "bumps" the PS and fans momentarily on the first couple of goes. No bad caps as far as I can tell but I'm now alerted to the Nichicon HM and HN problems from that time by this forum.
    I've looked in the forum but can't see anything relevant, surely it's well known to someone on here?
    Many thanks
    Henry
    Perth
    Western Australia (winter now)
  • shadow
    • Feb 2007
    • 732
    Re: Newby here, Intel D865 board needs several pushes of the power button to boot
    Others can probably help you more. However what power supply are you using with the system currently?
    It is surprising how many motherboard problems originate from the power supply.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      +1 on the power supply issues. the psu could be a junker (cheapo units = fire hazard, can you say powmax?), or the caps could be bad.
      how about pictures of any HM/HN caps. they generally swell when they fail (not always)... unlike most crap the seals are good so they don't dry out or lead at the bung.
      last, try a different case or switch the reset and power switches (if your case has them). use the new power switch to start and see if the issue changes... I have seen finicky power switches that would short twice per press and cause such a symptom.
      sigpic
      (Insert witty quote here)
      • Koda
        • Aug 2011
        • 317
        • Macedonia
        I'd advise you to take look at the motherboard (BIOS) battery, sometimes, when a battery fails it takes a few pushes on the power button to gain some energy and let the pc boot. I actually have seen this problem on numerous occasions. Second you should check for bulging caps on the motherboard and inside the PSU. Those two problems are the most likely cause for your problem. Also try replacing the power cord just for the heck of it and see what it does.
        Guns don't solve problems. I'll take 12
        • henrys
          • Aug 2011
          Thanks all,
          Yes it appears to be bulging/bad caps on the mobo, specifically only the 5 longer ones beside the CPU socket:
          C3C3
          C2C2
          C2C4
          C1C2
          C1C3
          Intermittent starting and hang ups, now replaced mobo with another of the same.
          Would a bad Power Supply have caused these caps to fail? One thing I notice having just started using the Intel Active Monitor is that some of the voltages seem to bounce around a bit (momentarily). Particularly the +3.3V and the CPU I/O +1.5V) readings.
          • c_hegge
            • Sep 2009
            • 5219
            Yes, a bad PSU can kill caps. What brand and model of PSU are you using?
            No, because he's from Australia, like me. Powmax PSUs don't exist here.
            • henrys
              • Aug 2011
              Well the voltage readings bouncing around seems to be a spurious effect arising from an interaction between "speedfan" and the "Intel Active Monitor".
              So hopefully with the replacement mobo I now have a stable system.
              Thanks for the tips guys.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                so? there are crap brands there too *cough* codegen *cough*
                sigpic
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Those wouldn't cause the issue at the switch.
                  More likely you have other blown caps or a PSU problem.
                  Blown caps in the PSU are possible too.
                  Intel sometimes uses 85C caps for the small 4 & 5 mm caps.
                  Those start going bad from dry-out after 4 or 5 years - depends a lot on heat and run-time hours.
                  They can cause a sundry of odd problems including an unresponsive switch.
                  You are expecting sensors that cost 5 cents to be fast and accurate.
                  Could also indicate a PSU problem or bad caps. [Large or small.]
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • privato89
                    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                    by privato89
                    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                    Let's begin:
                    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                    03-26-2024, 06:37 AM
                  • Luke Anders
                    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                    by Luke Anders
                    A few details about the laptop itself:
                    Name: Lenovo Legion 5
                    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                    BIOS Version: GKCN60WW
                    EC Version: GKEC65WW
                    Serial Number: PF39AQ7Z
                    Board Model: NM-D562 Rev 3.0
                    RAM: 16GB Installed, DDR4 (brand new)
                    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                    I bought this laptop recently from eBay as a faulty device....
                    10-12-2024, 05:13 AM
                  • hinisa
                    Xiaomi router freezes at boot after re-capping
                    by hinisa
                    I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                    When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                    After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                    Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                    07-08-2023, 05:58 AM
                  • NolesFan
                    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                    by NolesFan
                    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                    10-24-2024, 06:36 PM
                  • praveenramavath
                    Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                    by praveenramavath
                    Hello All,
                    I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                    https://www.hifivision.com/threads/m...-screen.98243/
                    Troubleshooting Summary: Majority Internet Radio - Flash Chip
                    04-26-2025, 09:08 AM
